Old 03-10-2013, 09:56 PM   #1
Guilty1s
Guilty1s is an unknown quantity at this point
Sunroof Delete Panel
Does anybody still make them. Only one I could ever find was the Kognition and they stopped making them long ago.
Guilty1s is offline   Reply With Quote
Old 03-11-2013, 11:52 AM   #2
gambit420s
gambit420s is an unknown quantity at this point
gambit420s is offline   Reply With Quote
Old 03-11-2013, 11:54 AM   #3
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
I made a delete bracket that reuses the sunroof glass.
It bolts directly to the rack mount and to the bottom of the sunroof.
Here is the fitment on the top.
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
Old 03-11-2013, 11:54 AM   #4
jds
jds is making a name for him/her selfjds is making a name for him/her self
just took my sunroof out a few days ago, going to cut out a piece of sheet metal and weld it in.
jds is offline   Reply With Quote
Old 03-11-2013, 12:01 PM   #5
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
My friends that hated their sunroof have always swapped the entire roof skin lol. Kind of extreme though.
om3ga is offline   Reply With Quote
Old 03-11-2013, 12:11 PM   #6
Chaluska
use a bunch of painters tape on the inside and fill in the entire sunroof panel (sticky side up), and fiberglass on top of the painters tape, whenever is hardens, peel off the tape, and enjoy your new form fit block off panel.
painters tape doesnt stick to fiberglass, so you can peel it once it hardens.
Old 03-11-2013, 12:18 PM   #7
Sleepy_Steve
Sleepy_Steve is an unknown quantity at this point
I just riveted in a steel panel from Lowes. It makes a good place to store my track number magnets, doesn't leak, and now I can fit in the car with a helmet on in the stock seats. Total cost was like... $30 or so?
'95 240 | @SleepySteve72
Sleepy_Steve is offline   Reply With Quote
Old 03-11-2013, 12:19 PM   #8
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
^ thats a good idea
I had sheet metal welded in place, but it will deform even if you get a roof support welded along with it. the fiberglass is probably the best idea if you can remember not to bang on your roof.
If you weld, make sure you go slow as fuck because the metal is so thin uptop.
collegekid is offline   Reply With Quote
Old 03-11-2013, 01:46 PM   #9
Sleepy_Steve
I do track weekends, so I wanted something that would be at least as safe as the factory non-sunroof car would be in a roll over event. Fiber glass (esp my DIY skills with that material) didn't fit that bill, but a decently thick sheet of steel at Lowes did once I went a little heavy on the rivet count.
The roof IS curved, and the sheet IS flat, so there will be some humps along the edges that need to be filled with RTV. I riveted it from the center front and finished it at the back to place those humps where they would bother me the least. I also found I needed to cover the tops of the rivet heads to stop all the leaks. Used about half a tube of black RTV in a caulk gun to do it.
Old 03-11-2013, 03:05 PM   #10
Guilty1s
I really like this, Im going to attempt to do this as I love my sunroof, I just don't fit in it with a helmet and brides...
If that don't work, this will do just fine for me.
Thank you all.
Old 03-11-2013, 03:26 PM   #11
itsdboy
itsdboy is an unknown quantity at this point
you guys are all trying to delete your sunroof while im wishing my coupe had one.
itsdboy is offline   Reply With Quote
Old 03-11-2013, 03:39 PM   #12
andrew600
ill tongue punch her fart box
andrew600's Avatar
andrew600 is an unknown quantity at this point
i fucking hate my sunroof. has someone welded a plug in? ive always felt it will pull apart the roof welds by doing so. anyone have a few pics from swapping roof skins?
andrew600 is offline   Reply With Quote
Old 03-11-2013, 05:11 PM   #13
rage
rage is an unknown quantity at this point
Send a message via AIM to rage
you should consider making these brackets, definitely a clean way to delete the sunroof
rage is offline   Reply With Quote
Old 03-11-2013, 08:33 PM   #14
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I hate to say it but that looks like poopies.
The solid brackets wont really fix the issue you'd have with the sunroof, which is the fiberglass trim breaking apart, not sealing the edges and leaking like a muffo.
CLICK HERE!!!
Old 03-11-2013, 09:28 PM   #15
Nissansota240
My plan for the bracket was to also make a sealant strip that would go in between the roof and the sunroof, creating a water tight seal on the entire piece. Also the plastic trim is not broken on mine, so basically I really only have to worry about making sure that the sunroof glass is sealed. Doesn't seem like it will be to big of an issue.
DLG - DIRTYLOVE
Old 03-11-2013, 09:31 PM   #16
fliprayzin240sx
Thats the thing, the fiberglass piece is not broken...yet. Itll happen eventually. Once that piece starts chipping away, a chunk of it will just fly off one day while youre driving. When that happens, welcome to the same issue that every S14 sunroof owner dreads. You cant replace that trim, that piece holds the rubber sealant in place, so you'd have to figure out another way of sealing it without making it look like absolute poop.
Keep an eye on the edge of that trim. If you start noticing it delaminating off the glass on the inside corners, its roh-roh time.
CLICK HERE!!!
Old 03-11-2013, 09:43 PM   #17
Nissansota240
Which is why I'm a bit surprised that no one has come up with a fiberglass piece that would work similar to the brackets I made. Would look similar to an RX7 sunroof from the outside.
DLG - DIRTYLOVE
Old 03-12-2013, 12:35 AM   #18
EliteGTR
EliteGTR's Avatar
Trader Rating: (18)
EliteGTR is an unknown quantity at this point
Feedback Score: 18 reviews
EliteGTR is offline   Reply With Quote
Old 03-12-2013, 12:41 AM   #19
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
^__^
msglength
Old 03-31-2013, 07:26 AM   #20
240sxrb30
240sxrb30 is an unknown quantity at this point
Do any of y'all still have the glass part. I figured this would be the best way to get one.
240sxrb30 is offline   Reply With Quote
Old 03-31-2013, 08:09 AM   #21
fliprayzin240sx
Glass part is easy to find. Find one with the fiberglass trim/rubber seal intact is a different story.
CLICK HERE!!!
Old 03-31-2013, 12:09 PM   #22
240sxrb30
The trim is the only reason why I'm looking for a new one. Since that's the only part we can't buy seperate from the rest. Wish somebody would make a cf trim piece.
Old 03-31-2013, 12:34 PM   #23
SuperBlackS14
SuperBlackS14's Avatar
SuperBlackS14 is an unknown quantity at this point
You'd think someone would re-engineer these things eventually...
"Power Is Nothing Without Control"
SuperBlackS14 is offline   Reply With Quote
Old 03-31-2013, 12:59 PM   #24
andrew600
andrew600's Avatar
I'm really surprised there isn't a delete panel made. I would so buy one.
Old 05-21-2013, 05:37 PM   #25
zenkiZ
zenkiZ is an unknown quantity at this point
Older thread but thought I'd share my delete panel from fiberglass..
zenkiZ is offline   Reply With Quote
Old 05-21-2013, 06:54 PM   #26
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
A buddy of mine is actually in the process of making these. Very similar to Kognition. Real CF and strong as all hell.
Both S13 and S14.
-Jspec-
Instagram/CrimsonRockett
Old 05-21-2013, 06:57 PM   #27
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Someone please replicate the OEM sunroof out of carbon fiber. I want a carboon fiber sunroof that I can keep popped open.
Old 05-21-2013, 07:02 PM   #28
KiLLeR2001
Trader Rating: (46)
http://www.youtube.com/watch?v=j45x9ranFH0
Old 05-21-2013, 07:03 PM   #29
AngryPanda
AngryPanda is an unknown quantity at this point
i will have s13 and s14 available this summer
We do "Awesome"
AngryPanda is offline   Reply With Quote
Old 05-21-2013, 08:28 PM   #30
towlie
Both S13 and S14.
Hmm more info?
