Old 03-18-2013, 08:57 AM   #121
Chad Dugan
Chad Dugan's Avatar
Chad Dugan is an unknown quantity at this point
Originally Posted by Sleepy_Steve View Post
Love the switch panels, and the rear quarter windows.
I may have to copy those rear quarter windows. Any idea how much weight was saved with them? Are they water tight?
Thanks man,
They are fairly water tight, I have strips of 3M foam tape lining the back, also I don't think the corner windows save too much weight, I changed these to prevent breaking glass in case of an impact.
Chad Dugan is offline   Reply With Quote
Old 03-18-2013, 09:57 AM   #122
Oakville
Oakville's Avatar
Oakville is an unknown quantity at this point
Hey Chad, where did you get those switches?
BNR32 connoisseur // 1990 GT-R
Oakville is offline   Reply With Quote
Old 03-18-2013, 06:21 PM   #123
kudii
kudii is an unknown quantity at this point
what color code gear is that??
kudii is offline   Reply With Quote
Old 03-18-2013, 07:11 PM   #124
Dolph_KYAS13
Dolph_KYAS13's Avatar
Dolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond repute
You can probably get them from digikey
-Jordie Lewis
'93 Skyline Type M
Dolph_KYAS13 is offline   Reply With Quote
Old 03-18-2013, 08:00 PM   #125
Blu813SD
Blu813SD is an unknown quantity at this point
Subbed, awesome stuff. Keep it up.
Blu813SD is offline   Reply With Quote
Old 03-21-2013, 07:57 AM   #126
Chad Dugan
Chad Dugan's Avatar
Thanks man!
Not sure what your question is?
Local Performance Improvements
I spent some time grinding and cleaning the inner wheel wells and removing any surface rust. I also needed more clearance for steering so I hammered the inner pinch welds back and test fit some wheels. I still need to do this to the rears before I paint the chassis. The wheels in the pics are 18x10.5 so they still hit the frame rails and back of the wheel wells but 9.5 should fit fine.
Old 04-08-2013, 10:44 PM   #127
Turbo Nismo
Turbo Nismo's Avatar
Trader Rating: (18)
Turbo Nismo is an unknown quantity at this point
Feedback Score: 18 reviews
Originally Posted by Chad Dugan View Post
What's the size of the tubes you use for the front bumper bars? Sketch and diameter? Thanks!
IG: chris___s14
Turbo Nismo is offline   Reply With Quote
Old 04-08-2013, 10:47 PM   #128
Chad Dugan
Chad Dugan's Avatar
I used 1.5 tube but again that is all preference, as long as it's strong that's what matters.
Old 04-09-2013, 10:04 AM   #129
Turbo Nismo
Trader Rating: (18)
Thanks a lot for the quick response.
IG: chris___s14
Old 04-16-2013, 09:13 AM   #130
Chad Dugan
Chad Dugan's Avatar
So I forgot to slip the transmission spacer on when I last put the motor in, so I had to pull everything out do that and while I had the engine out I thought I would paint the bay again since it was scratched and ruined from a brake fluid leak and tool marks. I even made new corner windows out of stronger less brittle lexan, much cleaner than before. Heat wrapped the downpipe, throttle cable, made a catch can and plumbed 95% of the lines.
-10 oil return to 1/2 NPT for the block
1st coat
I had this piece of 3'' stainless left over from my exhaust and these 3'' die cuts a friend made for me so I made this catch can. I think I might paint it textured black with a rubber coating I found.
Wrapped the upper portion of the downpipe that runs close to the booster
Cut and ran these lines for the catch can and for the fuel cell
These new windows are much more resistant to cracking and scratching
These lines come pretty close to the exhaust housing but I think I will use a smaller radius bender and tuck them closer to the master
Almost there
Old 04-16-2013, 09:23 AM   #131
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
Awesome work dude
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
Old 04-16-2013, 09:46 AM   #132
mewantkouki
Trader Rating: (36)
mewantkouki will become famous soon enoughmewantkouki will become famous soon enoughmewantkouki will become famous soon enough
Feedback Score: 36 reviews
Top notch fabrication! Everything looks really good, but at the same time I can't help feeling upset a kouki in such good shape had to get hacked up.
mewantkouki is offline   Reply With Quote
Old 04-18-2013, 11:35 AM   #133
Chad Dugan
Chad Dugan's Avatar
Originally Posted by Nissansota240 View Post
Awesome work dude
Thanks man!
Haha thanks man, dont be upset it's only a car! There's plenty of clean koukis left to mod!
Old 04-18-2013, 11:48 AM   #134
mewantkouki
Trader Rating: (36)
I used to have one just like it, that got wrecked. Every time I see one it brings back a soft spot. lol
Old 04-18-2013, 02:33 PM   #135
Purestock240
Purestock240 is an unknown quantity at this point
whats your plans once its finished? cscs, just drive it, topp days?
Purestock240 is offline   Reply With Quote
Old 04-18-2013, 05:58 PM   #136
tricky_ab
tricky_ab's Avatar
I always look forward to seeing your build thread updates It's looking great! I can't wait to see it out and about...
Old 04-18-2013, 07:11 PM   #137
pigeon
pigeon is an unknown quantity at this point
I really like all of the clean fab done on this. Did you order the lexan online? if so where?
pigeon is offline   Reply With Quote
Old 04-18-2013, 07:25 PM   #138
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
Dude! You are gonna melt your BMC!!!
Everything else looks good though :bigthumb:
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 04-19-2013, 09:03 AM   #139
onehundredoctane
onehundredoctane's Avatar
SHIT IT CLEAN! Love it, keep it up!
Old 04-19-2013, 09:24 AM   #140
Royal_T
Royal_T's Avatar
Royal_T is an unknown quantity at this point
Looking good bro
http://zilvia.net/advertise.html
Royal_T is offline   Reply With Quote
Old 04-19-2013, 01:13 PM   #141
Chad Dugan
Chad Dugan's Avatar
I'll probably do a few track days this year, lots of pictures and videos while the car is still one piece, I'd like to get some fun out of it before I move on to my new car.
Thanks!
I made them out of a large industrial sheet from a plastic supply company in Toronto we ship with. The previous windows were made from garage door lexan from Home Depot.
I know there will be huge heat generated but I think I'm far enough away from the bmc, I will need to shorten the radius oh the first bends out of the master though, and I also have a heat shield wrapped with gold tape that should help a little bit.
Originally Posted by Royal_T View Post
Looking good bro
Thanks a lot guys!
Old 04-22-2013, 09:54 AM   #142
Purestock240
some s14s came with a thinner brake booster, forget if it was zenkis, or non ABS cars or what.
Old 04-23-2013, 08:37 PM   #143
Blu813SD
Can you pm me more info on your headlight mounting bar and brackets ?
I might be getting into the same thing here sometime and wanted a similar removable setup.
The car has tubes on the front but no upper radiator mounting brackets or headlight enclosure brackets yet.
Can you send me some close up pics of the removable area for the upper radiator mount bar / headlight bracket bar and also the actual headlight mounting rods as well ? Greatly appreciate it if you can.
Old 04-23-2013, 09:44 PM   #144
jp69
jp69 is an unknown quantity at this point
Clean work man
jp69 is offline   Reply With Quote
Old 05-20-2013, 01:50 PM   #145
Chad Dugan
Chad Dugan's Avatar
Yeah ABS, I have considered changing with a friend and going this route before i have any serious melting issues.
I think if you check back a few pages there are some clear pics of when we built it but here is some to give you an idea.
Originally Posted by jp69 View Post
Clean work man
Thanks a lot!
Old 05-20-2013, 02:31 PM   #146
Chad Dugan
Chad Dugan's Avatar
I ran into some issues with the -10 oil return line rubbing on the steering column so I had to re route it up front directly into the pan. This is such a better way of routing the line, it created more room behind and under the turbo and allows the heat to escape better.
First I had to drill and tap the pan with a 1/2'' NPT
I then test fit a plug I would be using for the block since that location would no longer used
Re sealed the pan and put it back on the motor to dry
Then I had to shorten the -10 line so it would fit in its new location
I also had made a catch can earlier and wanted to finish routing all the vents so I used the existing block vent under the exhaust manifold and ran a hose to -8/barb fitting and wrapped it behind the motor.
Plugged the block
Hose to barb to -8
Old 05-20-2013, 04:25 PM   #147
Snatch'D Factory
Snatch'D Factory is an unknown quantity at this point
Awesome build! This will be awesome on the track or street.
Alex Bailey|Snatch'D Factory|(651)-333-7392|Instagram-snatchdfactory
Snatch'D Factory is offline   Reply With Quote
Old 05-21-2013, 09:07 PM   #148
PLAYERO_LOKO
PLAYERO_LOKO is an unknown quantity at this point
Wowl! This thing ls awesome... everything coming together like butt cheecks!
PLAYERO_LOKO is offline   Reply With Quote
Old 05-21-2013, 10:07 PM   #149
smdodgers
smdodgers's Avatar
smdodgers is an unknown quantity at this point
I love this build
A drift a day keeps the Hondas away.
smdodgers is offline   Reply With Quote
Old 05-30-2013, 12:27 PM   #150
Chad Dugan
Chad Dugan's Avatar
Thanks guys, appreciate all the comments! I should have some more updates soon.
