Old 04-25-2013, 03:54 PM   #1
T0fuman
T0fuman is an unknown quantity at this point
sr20 dies when coming to a stop at lights
Like the title says my Sr20 swap dies when I come to a dead stop. It runs alright and when it starts idles fine, But when I drive it down the road and hit any lights or signs the darn thing just dies. I have to keep reving it to keep it alive. Any suggestions?
T0fuman is offline   Reply With Quote
Old 04-25-2013, 03:56 PM   #2
OutlawLui
OutlawLui's Avatar
OutlawLui is a well-known jackass
Adjust the super tiny screw that is on the throttle body's left side to slightly open the butterfly
ill see if i can find a pic. But this is the easiest way to get a higher idle
OutlawLui is offline   Reply With Quote
Old 04-25-2013, 04:08 PM   #3
Prozac
Prozac is an unknown quantity at this point
Most people have that problem when running a bov , I had the same , recirculate your bov and should fix your problem.
Prozac is offline   Reply With Quote
Old 05-11-2013, 01:36 AM   #4
33jrod33
33jrod33 is an unknown quantity at this point
Lol don't stop
33jrod33 is offline   Reply With Quote
Old 05-11-2013, 02:27 AM   #5
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
Originally Posted by 33jrod33 View Post
Lol don't stop
lmao.
seriously though, if youre venting to atmosphere, it usually just dies when you come to a quick stop, it shouldnt need to be revved if you cruise to a stop with the clutch in.
if you do adjust that screw - make sure you reset your tps. i did mine last year and i vent to atmosphere and it hardly ever dies at stops any more. rock solid 800 rpm idle too.
AsleepAltima is offline   Reply With Quote
Old 05-11-2013, 02:35 AM   #6
Thomas0zero
Thomas0zero's Avatar
Thomas0zero is an unknown quantity at this point
couldnt you put your MAF before the TB and fix the issue all together?
Thomas0zero is offline   Reply With Quote
Old 05-11-2013, 10:39 AM   #7
beems240sx
beems240sx's Avatar
beems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant future
Yes you can run blow through maf, I did it. However nissan mafs are terrible and two exploded on me due to boost pressure.
beems240sx is offline   Reply With Quote
Old 05-11-2013, 10:42 AM   #8
ultimateirving
ultimateirving's Avatar
Ok if the bov is opening at idle and decel thats kinda a problem, if its adjustable tighten the spring a little it shouldnt be popping open unless your getting into boost.
Next the IACV is designed to catch the Rpm's on decel to keep it from stalling, It sounds like yours may be malfunctioning. Try cleaning it first, Remove it to clean and make sure you check the gasket before you replace it. Then search online how to set idle in SR20 because it is set thru the iacv
Z32 with lq4 swap
Old 05-11-2013, 11:48 AM   #9
Thomas0zero
i agree with this about the Idle air control valve. But not all BOV's idle in the closed position. Off brand junk is notorious for this. Its a big thought when deciding what BOV to put in your car. HKS has a second diaphragm so you cant build enough vacuum to pull it open at idle. Thats also why HKS needs to run those little air filters.
