Old 08-02-2004, 04:00 PM   #1
nissantuner22
nissantuner22's Avatar
Trader Rating: (-1)
nissantuner22 is on a distinguished road
Feedback Score: -1 reviews
Send a message via AIM to nissantuner22
Car runs better with no TPS!?
My car is back to its old tricks. Extreme bucking under acceleration. Stomp the gas, RPM's stay locked at whatever RPM I'm at, than *maybe* all of a sudden rev up like crazy. I have no idea wtf is going on. So I disconnect the TPS, which is brand new, and the car runs and drives almost like normal. explain.
Current Project: Operation: N/A SR: 93 Silvia Q SR20DE Engine with go fast goodies. ,
"Common problems 240sx's suffer from are curbs, trees, ditches, and other immovable objects."thx247
"on the tounge... there is no guardrails."- citizen
nissantuner22 is offline   Reply With Quote
Old 08-02-2004, 04:11 PM   #2
orion::S14
orion::S14's Avatar
Similar issue on my S13 (not nearly as severe, though), and it's a random thing. Happens every once and awhile, but never happens if the TPS is disconnected...
I've tried MAF cleaning, new plugs and wires, checked all the other likely culprits...to no avail.
I actually get better gas mileage with it unplugged, so I leave it that way.
Haven't tried a known-good MAF...and that's the next thing I'll do...as the MAF and TPS work together when the ECU is in closed loop.
Anyone know what the ECU defaults to with no TPS input...back to the "maps"...?
- Brian
Old 08-02-2004, 04:58 PM   #3
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
With tps disconnected can you rev past 4500 rpms?
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 08-02-2004, 05:03 PM   #4
nissantuner22
Trader Rating: (-1)
yep, took it to redline. was fine.
Old 08-02-2004, 07:39 PM   #5
mrmephistopheles
mrmephistopheles's Avatar
perhaps it could be that you never properly set the 'NEW TPS'. They aren't just plug and play.
Old 08-03-2004, 12:00 AM   #6
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
had the bucking problem
unplugged O2 sensor
runs great, awesome mileage too
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 08-03-2004, 11:16 AM   #7
nissantuner22
Trader Rating: (-1)
interesting point on the, it not being set thing, but the car ran great for about a month. will try the O2 thing after I reconnect the TPS.
Old 08-04-2004, 02:16 PM   #8
intrexin
intrexin is an unknown quantity at this point
whats the proper way to set them? Do you have any links or how to guides?
intrexin is offline   Reply With Quote
Old 08-04-2004, 05:41 PM   #9
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
I bet you something (wire going to, or plug) on the TPS is fucked! Or you could have a bad ground. Dam nissans are notorious for those things.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
Old 08-04-2004, 06:24 PM   #10
mrmephistopheles
Nissan Factory Service Manual for your model year.
Look around. There's online versions of FSMs all over. Or, you can do like alot of folks and buy one from Dyment.
No, I won't give you their number or anything more about them, nor will I give you any links to online FSMs. sorry.
-Kevin
Old 08-05-2004, 06:58 PM   #11
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
very helpful.
andrave is offline   Reply With Quote
