Old 05-07-2013, 01:46 PM   #1
Kennybhybrid
Kennybhybrid's Avatar
Kennybhybrid is an unknown quantity at this point
turn signals not working
Hi guys. I have a 95 240sx se. Its an auto to manual swapped car. My hazard lights are working just fine but the turn signals arent. I replaced the stalk, bulbs and fuse. I changed the relay but the problem still persist. Is there a seperate relay for the turn signals independent of the flasher? If so where is it located. Trying to get this car on the road asap. Please help if you can. Thanks in advance
Kennybhybrid is offline   Reply With Quote
Old 05-07-2013, 02:21 PM   #2
SuperBlackS14
SuperBlackS14's Avatar
SuperBlackS14 is an unknown quantity at this point
It was an Auto-Manual Swap? I'd curl up with your factory service manual and check wiring diagrams. You may need to do some soldering... The Engine Bay Harness is different between auto/manual, base/se and abs/non, as is the transmission harness. These things can be a bit temperamental in cars our age. I'm currently looking for one to swap over because mine was done with like an S13 trans and harness instead of just removing the AT stuff...
Also search if you haven't yet.
"Power Is Nothing Without Control"
SuperBlackS14 is offline   Reply With Quote
Old 05-07-2013, 06:03 PM   #3
Kennybhybrid
Dude ive searched endlessly for the past 2wks. Each forum says something different. Ive replaced everything the forums have said to replace. Everything in the car works fine except the signals n heat but idc for heat. Its a street strip car and i have a g37s daily. Ive read its a flasherjust for the signals but i have yet to find it. Anybody else have suggestions
Old 05-07-2013, 06:13 PM   #4
SuperBlackS14
If you've replaced everything else, it's probably wiring related...
Old 05-07-2013, 07:23 PM   #5
JBPUSA
JBPUSA is an unknown quantity at this point
did they ever work? are you saying they stopped working after the 5 speed swap?
I have done 5 speed swaps and have never encountered this problem, did you buy the car this way?
seems like you replaced everything.
___________
Check out our website www.jbperformance.net
JBPUSA is offline   Reply With Quote
Old 05-07-2013, 07:26 PM   #6
JBPUSA
also , Im aware you said the Hazard lights work, but try another hazard light button, as they are connected to each other in wiring.
___________
Old 05-08-2013, 09:17 AM   #7
Kennybhybrid
Yes the hazards work. My question is, is there a 2nd relay for the turn signals? I bought the car without them working, it was a rolling chassis and im fixing all the problems with the car. So does anybody know if s14s have a 2nd relay just for the turn signals. Its gonna be a track car but it will see the streets and i would like to use the turn signal switch and not stick my arm out the window.
Old 05-08-2013, 09:46 AM   #8
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
If your car is lowered, check the harness over the front wheel arches.
Ilya is offline   Reply With Quote
