Old 04-30-2013, 10:30 PM   #91
ZenkiZenki14
ZenkiZenki14's Avatar
ZenkiZenki14 is an unknown quantity at this point
Originally Posted by Pinggg View Post
Koyo Radiator
ISIS Fans And Shroud
ISIS Thermostat
ISIS Hoses.
- Been running these on my car for about a year with about a bunch of trackdays, never once overheated. My car also sounds like a damn hurricane up front from these fans pulling so much air!
Took the words right out of my mouth, I have the same fans and shroud, and he's not lying when he says they sound like a hurricane, cause they really do.
I'm running
Mishimoto radiator
Mishimoto hoses
Isis duel electric fans and shroud (same ones as pictured)
Stock thermostat
Also I have a PBM HMIC so I get more direct air to my radiator.
No overheating or high engine temp issues whatsoever!
ZenkiZenki14 is offline   Reply With Quote
Old 04-30-2013, 11:34 PM   #92
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
running oem clutch fan on my dd rb25 s14, no shroud, havent had the luck of finding one, maybe will have to build my own, anyway, never once overheated, im even running a stock thermostat, and that's in the texas' heat where we see 100's daily during summer
feito is offline   Reply With Quote
Old 05-01-2013, 09:16 AM   #93
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
My new SR build runs too cool. It hovers at 130 degrees and only gets up to 150 when driven hard for a prolonged amount of time. I am changing out the thermostat to ensure that it isn't stuck open. My oil never gets to or above 140 degrees. I have a DIF fan controller I have yet to install. I suspect that the thermostat has a pin-hole drilled in it to ensure that it always flows a small amount of fluid, which helps it stay cool, and I will confirm this in the next couple days after the thermostat is swapped for a Mishimoto unit.
Koyo Radiator | Blitz radiator cap | Circuit Sports reservoir | Samco hoses | dual Altima electric fans with one disconnected | Stance water pump pulley | S14 water neck with AN turbo line welded in | GTX turbo wrapped with a thermal blanket |Circuit Sports oil block adapter | Pirtek fabricated AN lines | Offenhauser remote oil filter mount | Permacool oil thermostat | 13 row oil cooler | intercooler hoses are all stainless custom fabricated | Greddy R Spec intercooler
Mazworks | HKS | Greddy | T4 GTX3076r | Full Race | Tial | SPL | Feal
Seraphim38 is offline   Reply With Quote
Old 05-01-2013, 09:34 AM   #94
BlewByYou
BlewByYou's Avatar
BlewByYou is an unknown quantity at this point
What part of Texas?
BlewByYou is offline   Reply With Quote
Old 05-01-2013, 10:06 AM   #95
InsTanCeZ
InsTanCeZ's Avatar
InsTanCeZ is an unknown quantity at this point
GKTech Replacement Engine fan - Nissan S13/S14/S15 SR20DET
This looks good. It's supposed to be better than an RB25 fan.
ACE マジック HEART
InsTanCeZ is offline   Reply With Quote
Old 05-01-2013, 10:07 AM   #96
Edwin562
Edwin562's Avatar
This is on my next to buy list.
Old 05-01-2013, 11:37 AM   #97
jr_ss
Proper ducting would be the best cooling mod... People running around without the lower splash guard complaint of over heating issues, need to fab or reinstall theirs.
Old 05-01-2013, 04:25 PM   #98
feito
feito's Avatar
Originally Posted by BlewByYou View Post
What part of Texas?
San antonio
Old 05-01-2013, 09:28 PM   #99
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
I'd love to see some pics of some under guards that everyone has built? I'm thinking about doing a PBM one, but I'm honestly not sure if its worth it, or if I can built one better. Would be cool to get some ideas based on what everyone else has done.
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 05-01-2013, 09:31 PM   #100
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
I've been thinking about the same exact thing.
zombiewolf513 is offline   Reply With Quote
Old 05-13-2013, 07:44 PM   #101
MrSanchez925
MrSanchez925 is an unknown quantity at this point
For the people who run the Isis fan and shroud set up,
What are you temps just normal driving?
MrSanchez925 is offline   Reply With Quote
Old 05-13-2013, 10:28 PM   #102
PandahZ650
PandahZ650 is an unknown quantity at this point
Send a message via AIM to PandahZ650
For those overheating with a stock/oem thermostat should definitely try running a lower temp thermostat, or even no thermostat. All these big radiators, fans, ducting, etc. can only do so much if the thermostat isn't opening up at a low enough temp. for your motor.
PandahZ650 is offline   Reply With Quote
Old 05-13-2013, 11:29 PM   #103
aga
aga's Avatar
aga is an unknown quantity at this point
nobody mentioned a vented hood. sucking in air is all nice, but it's gotta go somewhere... i noticed improved temps on my previous car with a vented hood... i'm gonna make a mold for one for the sx as soon as im finished with more pressing stuff.
my setup:
driftworks aluminium rad
samco hoses
oem stat
dual e fans, nissan , i don't remember what car
havent installed the rad yet, the car now has a radiator what the previous guy says its from an s14, but it seems tiny to me, like 2cm thick, single core.
aga is offline   Reply With Quote
Old 05-13-2013, 11:50 PM   #104
Drift_FX
Drift_FX's Avatar
Drift_FX is an unknown quantity at this point
have you not read this thread at all? no thermostat can result in coolant flowing too quicly through the radiator to cool the liquid effieciently..... dont offer your 2 cents if you dont know what your talking about please....
Drift_FX is offline   Reply With Quote
Old 05-14-2013, 12:40 AM   #105
PandahZ650
A couple of my friends have used no thermostat/drilled out thermostat at the track and their temps were fine. So i guess my own two eyes and previous posts in this thread are not good enough to verify that it can work in some situations depending on your setup.
I'm not trying to get in an argument here but I was trying suggest that those with oem thermostat that are overheating/high temps could try to run a lower temp thermostat to cool the temps with a secondary less recommended choice of a drilled out/no thermostat, my intentions of the sentence was to focus mainly on running a lower temp thermostat. I guess i just worded it badly. Just offering my thoughts and opinions on what i think is one of the best cooling mods(opinionated topic). Just my opinion and 2c , take it or leave it.
Old 05-14-2013, 01:52 AM   #106
PeaceOnesxWai
PeaceOnesxWai's Avatar
Trader Rating: (34)
PeaceOnesxWai is an unknown quantity at this point
Feedback Score: 34 reviews
Swirl pot and expansion tank. The radiator i was gonna use was a 3 pass MR2 Radiator
Got the idea from this.
PeaceOnesxWai is offline   Reply With Quote
Old 05-14-2013, 01:59 AM   #107
PeaceOnesxWai
Trader Rating: (34)
This is pretty cool, uses 4 radiators (welded L-Shape) and rear mounted.. high mounted expansion tank
This thing probably uses 2 gallons of coolant
Old 07-19-2013, 02:46 PM   #108
Te37
Te37's Avatar
Te37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choices
Where is everybody getting your water temp reading from? I run in the 180-200 range, but my temp gauge is on the water neck output. Is that too hot?
Te37 is offline   Reply With Quote
Old 07-19-2013, 03:02 PM   #109
jr_ss
My car uses 2.5gals of coolant and all I have is a Koyo radiator on an SR20VET...
Old 07-19-2013, 03:07 PM   #110
jr_ss
Mine is on the coolant outlet and I saw temps between 195-220ish... SR's tend to run hot and I've heard of dudes running 240* while tracking their car.
Old 07-19-2013, 03:43 PM   #111
jamg
jamg is an unknown quantity at this point
which is a better fan? altima dual fans or a single ford taurus?
does the ford fan blow harder?
jamg is offline   Reply With Quote
Old 07-19-2013, 04:12 PM   #112
jr_ss
Did you not read the CFM's posted in the first post of that fan thread? The Taurus fan on low(2500CFM's) flows more than the Altima fan on high(2200CFM's). So yes, it "blows" harder.
