Old 08-03-2004, 09:42 PM   #1
TheSparo
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
TheSparo is an unknown quantity at this point
Send a message via AIM to TheSparo
so if you use seafoam on an SR...
would it totally fuck up your turbo? bc ive heard seafoam takes all the carbon buildup off of the top of the pistons... but it goues out the exhaust... and when you have a turbo...
any input?
89 240 SR powered...
ummm i promise its stock
TheSparo is offline   Reply With Quote
Old 08-03-2004, 10:44 PM   #2
mrmephistopheles
mrmephistopheles's Avatar
it'd go out the exhaust side of the turbine.. dunno!
Old 08-03-2004, 11:42 PM   #3
ftrs13
ftrs13 is an unknown quantity at this point
Send a message via AIM to ftrs13
it would probably be like running rich for a while, people run rich all the time with turbos ... so Im guessing not, but wait for some more input
ftrs13 is offline   Reply With Quote
Old 08-04-2004, 10:35 AM   #4
240sxconversion
240sxconversion is an unknown quantity at this point
if seafoam is the same stuff as the used on 2 Guys garage, they used it on a grand national which is turbo. http://www.run-rite.com/ this is the stuff i am talking about.
240sxconversion is offline   Reply With Quote
Old 08-04-2004, 10:54 AM   #5
noahrexion
noahrexion is making a name for him/her selfnoahrexion is making a name for him/her self
Send a message via AIM to noahrexion
It wont hurt a dang thing.... <---- 3 bottles in SR 4 me
noahrexion is offline   Reply With Quote
Old 08-04-2004, 11:06 AM   #6
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
stuff is awesome. i'm going to run another can through mine this weekend.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 08-04-2004, 07:03 PM   #7
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
arent you supposed to change plugs and oil immediately after using it? Ive used it on my Z. My neighbors were pissed with the smoke cloud covering the street. (condo)
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 08-04-2004, 07:12 PM   #8
TheSparo
ok, so it wont hurt?
how much do you put everywhere again? a bottle through the gas tank, bottle in oil, and how much in the brake booster ?
Old 08-05-2004, 07:36 AM   #9
uiuc240
uiuc240's Avatar
it's all written on the side of the can. when you pop the brake booster line off, have someone in the car ready to apply throttle, as it will stall the car. also, i found that a good way to get the fluid in there was to use a small glass measuring cup, tip it slightly toward the vacuum hose, and then just let the hose suck the fluid in slowly. yes, the cloud was nasty...but it was worth it. and by the way, you only need one can to get the job done. do it again in a couple of weeks if you need more.
2002 Mazda Protege5
Old 08-05-2004, 01:07 PM   #10
TheSparo
im guessin i should remove my exhaust? or not
Old 08-05-2004, 07:07 PM   #11
kidinthehall
kidinthehall's Avatar
kidinthehall is an unknown quantity at this point
you're making this way too complicated
90 S13:............fitter, happier, more productive.
04 Yamaha R1: 210rwhp on gas/161rwhp on motor
kidinthehall is offline   Reply With Quote
Old 08-05-2004, 08:51 PM   #12
TheSparo
no i understand everything but im just saying so i dont get all that shit in my exhaust limiting the flow...
Old 08-06-2004, 01:09 PM   #13
msaskin
msaskin is an unknown quantity at this point
Send a message via AIM to msaskin
You won't get any shit in your exhaust, turbo, manifold, etc. The carbon all burns off, creates the smoke, then disappears.
Think of it as magic. Just do it, don't do anything special, and forget about it. Enjoy the smoke show
~matt
it's not turbo lag...it's foreplay
'01 Ford Excursion Limited.
Powerstroke Diesel
Coming in spring: ???
msaskin is offline   Reply With Quote
Old 08-06-2004, 03:44 PM   #14
Mr. Badlose
Mr. Badlose is an unknown quantity at this point
Send a message via AIM to Mr. Badlose
uiuc240: What were the benefits to doing this that you could feel/see?
Mr. Badlose is offline   Reply With Quote
Old 08-06-2004, 05:38 PM   #15
knightrider
knightrider's Avatar
knightrider is an unknown quantity at this point
the only precaution i took when using it was i installed a old o2 sensor i have laying around, i know the seafoam says its o2 sensor safe, i just like my sensors clean but i wouldnt worry if you dont have one laying around, just pour the shit in, i found it helps if you stick a small flat screw driver in the throttle stop, it raises the revs a little so the motor wont stall as easy because the throttle is partly open, this prolly isnt as easy to do on a dohc or SR cuz of where the throttle is, but it works on my sohc and my ca18, hehe. just do 1/3 of the bottle in the gas tank before you fill up, 1/3 in the oil, and the last of it through the brake booster, then just wait for ppl to come out of thier houses ready to call the FD
Drift_ Into A Mountain
Jim Wolf Technology
Stock CA18DET-SR T25-greddy FMIC-JWT SR Lightened FLywheel-300zxTTclutch-SR20DET JWT tuned Ecu
knightrider is offline   Reply With Quote
Old 08-06-2004, 08:18 PM   #16
kickertu
kickertu is a well-known jackass
any advantages to this, besides knowing you have a clean motor?
kickertu is offline   Reply With Quote
Old 08-06-2004, 09:45 PM   #17
Bryants95240sx
Bryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the rough
in any yall do put it in the OIL DONT DRIVE let the car just idle for about 20 mins with it in the oil then change the oil.(for the noobs)
Bryants95240sx is offline   Reply With Quote
Old 08-07-2004, 02:15 PM   #18
Spdrules5
Spdrules5 is a well-known jackass
Where can one buy the seafoam or run rite? (In so-cal.)
Spdrules5 is offline   Reply With Quote
Old 08-07-2004, 09:22 PM   #19
TheSparo
if you have an O Rileys (sp?) thats where i got it
Old 08-07-2004, 10:15 PM   #20
mrmephistopheles
an alternative method to putting it in the brake booster, is have vinyl tubing with the 'arrowtip' fitting at the end. dip one end of tube in bottom of can, and jam the fitting into the brake booster tube.
