Old 08-06-2004, 05:44 PM   #1
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
anybody ever install an arc fmic,
I was just wondering because I had a couple questions, Ive never installed an fmic before and I know the common answer is its easy jsut line the pipes up, Yah Ive pretty much got that idea, but I have a pipe that pretty much fits the hot side of the ic and goes up into the hole wehre the airbox was, and even has a bracket taht has a hole that lines up perfect for mounting, my question is, how come it has a nipple, about 1" coming out the side, If mounted like this, the nipple is like way up in there where the resonator box was and seems like if it was meant something, should be more up by the engine, You cant even access it from engine bay, you have to get up under the car, also if anybody had any instructions for arc fmic that would be cool, I know I could figure it out myself but directions make it easier.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 08-06-2004, 08:31 PM   #2
s14alex
s14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of light
prolly for a stock bov. my greddy had the same thing.
s14alex is offline   Reply With Quote
Old 08-06-2004, 09:07 PM   #3
mjjstang
hmm guess im a newb, another newbish questoin is how might I plug this, must I weld it.
Old 08-07-2004, 12:06 AM   #4
SirWarrior
SirWarrior is an unknown quantity at this point
try a expandable freeze plug. they are cheap and autozone has them.
92 FastBack - Project
98 SE - Daily Driver
SirWarrior is offline   Reply With Quote
Old 08-07-2004, 02:41 AM   #5
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
Sounds like a nipple for a wastegate.
driftingisgay.com
nrg is offline   Reply With Quote
Old 08-07-2004, 02:05 PM   #6
mjjstang
um isnt a wastegate like 3 inches away from the turbo, this is like 3 feet, maybe im wrong, this is the first time ever really dealin wit turbos and shit so im new but i didnt know wastegates were so far away from the turbo.
Old 08-07-2004, 02:06 PM   #7
rupertaker1
rupertaker1 is an unknown quantity at this point
Send a message via AIM to rupertaker1
Do you have instant messanger? I can help you with the install if you want.
rupertaker1 is offline   Reply With Quote
Old 08-07-2004, 02:15 PM   #8
Propagandhi41
Propagandhi41's Avatar
Propagandhi41 is an unknown quantity at this point
Send a message via AIM to Propagandhi41
no it's definitely not for a wastegate and iirc bov are on the cold side of the intercooler... i don't have turbo nor do i know much of anything about them but i think that's correct...a wastegate controls the flow of air into the turbo so why would it come after the turbo....it doesn't make sense. my two cents.. can't help you with the nipple though
Propagandhi41 is offline   Reply With Quote
Old 08-07-2004, 02:18 PM   #9
mjjstang
hmm ill just try the autozone thing or weld it, and as far as the bov, Im purchasing a hot pipe, with the flange and bov already on it, so yah some people have their bov on cold pipe that ive seen and most that ive seen are on hot though.
Old 08-07-2004, 02:42 PM   #10
s14alex
It was on the hot side of my vspl....
Old 08-08-2004, 12:05 PM   #11
nrg
My bov is on the hotside of the intercooler. HKS piping too. hot side, cold side, it doesnt mather. some have said you get a better responds on the cold side. IIRC. s13 sr, bov is on hot side. s14 and s15, bov are on cold side. hehe
I didnt say it was a wastegate. I said it's a vacum line to the wastegate. Unless there's already a line for the wastegate. This is also called a source line, air line, etc.
driftingisgay.com
Old 08-08-2004, 01:12 PM   #12
mjjstang
I kinda figured afterward that you had to be talkin bout a line, problem is ive never seen a vacuum line that is 1" in diameter. Im guessing that it is for the stock bov. but im just going to plug it.
