Old 05-28-2013, 08:04 PM   #751
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
I don't see an ingredient list. Does this have Silicone in it?
Couldn't tell ya, you would have to call the company.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 05-28-2013, 08:12 PM   #752
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
Originally Posted by Broadfield View Post
That is by far the easiest question I will probably ever answer in this thread: Hoosier Metal Polish. There is nothing like it and I have tried pretty much everything. I have been using it for around 20 years. You will not believe the results.
W.T.I Fenders - Add the finishing touch - Kentland, Indiana - Tractor Trailer Truck Fenders - Hoosier Metal Polish
Haha, I will have to look into Hoosier.
Next question, I have a cluster lens in pretty damn good shape. Very light scratches. Now I have seen your wet sand and pinnacle 1-4 method in this thread.
Is there an of the shelf product that can help me with the "last" step or two of the polishing process? Such as 'plastx' or some other vatozone item you'd find acceptable?
@UpshiftEngineering
KoukiMonsta is offline   Reply With Quote
Old 05-29-2013, 09:06 AM   #753
Ros7.exe
Ros7.exe's Avatar
Ros7.exe is an unknown quantity at this point
Hey Broadfield,
I searched on how to do the LED DCC swap and came across page 15 on your thread. Pictures are not loading anymore. If you could re upload them or send them to my email: [email protected] that would be awesome. Please and Thank you.
Ros7.exe is offline   Reply With Quote
Old 05-29-2013, 06:56 PM   #754
Broadfield
Broadfield's Avatar
I couldn't really tell you, I simply use standard polish. Nothing is going to work as well as various levels of polish. Because one product can't remove different levels of scratches. With each level of sandpaper or polish, you are essentially just creating finer and finer scratches each time you step to a finer paper or polish. So if you have a couple "level-3" scratches on the lens, then level-1 polish cannot take those out. You would need to use the level-2 polish to get the level-3 scratches out, then use level-1 polish to get the level-2 polish scratches out. Then use glaze to get the level-1 polish scratches out. So unless the PlastX has a couple different levels of product included in the kit, then you are stuck with whatever "level" of polish is in the kit. I hope that makes sense.
Originally Posted by ReneRos92 View Post
Hey Broadfield,
Pictures restored!... direct link below:
http://zilvia.net/f/off-topic-chat/4...ml#post4873458
My Portfolio
Please Share
Check Out My Builds
Old 05-30-2013, 02:07 PM   #755
georgegto
georgegto's Avatar
georgegto is an unknown quantity at this point
Hi Toby, what would be the minimum battery ah for a stereo system of 2x4ch amps to run it? Im thinking of buying a smaller battery but I'm unsure for the ah..
georgegto is offline   Reply With Quote
Old 05-30-2013, 05:15 PM   #756
Broadfield
Broadfield's Avatar
You didn't post how many watts the amplifier is? I need to know RMS wattage... or the fusing on the amplifier would actually be a better indicator. So you plan on running the stereo with the engine off a lot?
My Portfolio
Please Share
Check Out My Builds
Old 05-31-2013, 07:19 AM   #757
danny92
danny92's Avatar
danny92 is an unknown quantity at this point
Hey Toby. What audio setup would you recommend for my 180sx? My stock head unit i've been using recently broke so i'm keen to fork out some $$ and get a decent head unit, speaker, amp and sub setup. The music i listen to is usually Drum n bass, Dubstep & Electro house. It would be great if you could give me couple of options and i'll see if those units are available where i live(NZ). Preferably a single din setup for the head unit!
danny92 is offline   Reply With Quote
Old 05-31-2013, 07:35 AM   #758
Broadfield
Broadfield's Avatar
Can you get the brands Alpine, Hybrid Audio and ARC Audio over there? I can simply ship you the stuff if not... but I'm not sure on the radio if the tuner section would be correct. Regardless you could the rest from me if the price works in your favor to do so.
My Portfolio
Please Share
Check Out My Builds
Old 05-31-2013, 07:41 AM   #759
danny92
danny92's Avatar
The audio shops near my area sells alot of Fusion, sony & pioneers stuff which i've never really been a fan of.. They do stock some Alpine and JVC headunits such as kd-x50, kw-av61, KD-r90 etc. How much do you reckon the shipping would be? I've never seen any Hybrid audio or ARC audio components being sold here in NZ im afraid
Old 05-31-2013, 07:45 AM   #760
Broadfield
Broadfield's Avatar
If you can, please email me and we'll continue there.... because we may be replying back and forth a lot. You can email me at:
[email protected]
My Portfolio
Please Share
Check Out My Builds
Old 05-31-2013, 03:30 PM   #761
georgegto
georgegto's Avatar
Each of the amps is 200watt RMS..no im not planning to run the stereo with engine off but if I use a 30 Ah battery and play loud when driving will it stress the alternator? I have an LS2 in my s13 if that's any help to advice me for a battery..thanx in advance
Old 05-31-2013, 03:45 PM   #762
Broadfield
Broadfield's Avatar
So 400 watts RMS total?
Battery won't matter then. The battery is only if you are listening to the stereo when the engine is not running. And since you are running a V8, the alternator will have a higher output than the alternators used on typical 4-cylinder engines. 400 watts RMS is very little in the grand scheme of things and will only have around 30 amps of max draw.
My Portfolio
Please Share
Check Out My Builds
Old 05-31-2013, 07:49 PM   #763
gbaby2089
gbaby2089's Avatar
gbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfection
I finally feel that my daily Fit needs an audio upgrade. I recently picked up a Pioneer AVH-3100DVD to replace the OEM h/u and I wonder what else I should pick up to complete an entry level audio setup?
I'm not a crazy bass head or audiophile by any means, just want something better than the stock trash.
gbaby2089 is offline   Reply With Quote
Old 06-01-2013, 07:35 PM   #764
Broadfield
Broadfield's Avatar
What is your budget?
My Portfolio
Please Share
Check Out My Builds
Old 06-04-2013, 04:09 PM   #765
mad-ass
mad-ass's Avatar
How are you doing nowadays man?
Old 06-05-2013, 01:32 PM   #766
xZxCORE
xZxCORE is an unknown quantity at this point
Hey Toby. Have you had/heard of any issues concerning condensation in gauges mounted in HVAC vents? Any electrical problems? Im not having them but just a curiosity question... I know down south every time I have my AC on water pretty much drips out of my vents. Thanks man.
xZxCORE is offline   Reply With Quote
Old 06-06-2013, 06:23 PM   #767
Broadfield
Broadfield's Avatar
Nothing much has changed man. My girls are growing up right before my eyes, my wife is awesome, I still love my job even after 20 years and I still don't have time to work on the S13
I have had no problems reported. If you are doing a setup that doesn't retain any sort of vent... like in my S13 center gauge plates that I sell that still have vent slots in the aluminum plate, then you can simply seal off the duct behind it.
My Portfolio
Please Share
Check Out My Builds
Old 06-07-2013, 01:17 PM   #768
e5s4y
e5s4y is an unknown quantity at this point
Hey Toby, if this is easier for you to email to talk about it i dont have a problem with it.
I just want to finally wire up the remote start on my viper 5904v, do you happen to know which wires go where off the top of your head?
also, I may be in the market for a new head unit relatively soon. Something bluetooth capable, that will pair well with the ARC audio xdi804 and HA Mirius' I got from you around January.
BustedS13: anything you can hide on your person is free. junkyard law.
e5s4y is offline   Reply With Quote
Old 06-07-2013, 06:07 PM   #769
Broadfield
Broadfield's Avatar
I kind of need to know what car you have!?!
My Portfolio
Please Share
Check Out My Builds
Old 06-07-2013, 06:10 PM   #770
e5s4y
Before I started typing I told myself to make sure I mentioned that, and. Still forgot! Ha
91 s13 hatch
Old 06-07-2013, 09:57 PM   #771
Zac--SRS13
Zac--SRS13's Avatar
Zac--SRS13 is an unknown quantity at this point
I'm starting to hate my car because it seems like the simplest things are becoming 20 times harder then it should be.
I wired up a DIF PWM fan controller to my 90 S13 hatch with SR and its straight forward yet it's giving me problems.
I have it wired as follows.
BA -> Battery
IG -> Blue wire off the ignition
AC -> not yet connected
MA -> not yet connected
S+ -> to temp sensors positive wire
S- -> not connected because for some reason it only works with it disconnected.
Black ground -> ground
White ground -> fans ground wire
Fan+ -> battery
Sitting in my drive way I set the controller to 162F and let it warm up. My temp gauge hits 162F and the fans turn on. Perfect.
Would you happen to have any idea why my stupid controller would loose power when I'm under load though?
Sitting and idling the controller works perfect. Start driving or rev the engine and the controller shuts off completely. Then once I stop or the car idles agains the controller turns on.
This thing has been a pain in my ass the whole time I've had it and its driving me nuts. I'd hate to ditch it because it cost me a pretty penny.
Any input from anyone with any ideas would be extremely appreciated.
Zac--SRS13 is offline   Reply With Quote
Old 06-07-2013, 11:57 PM   #772
Broadfield
Broadfield's Avatar
91 s13 hatch
Can you PM me your email and I'll send you a tech sheet.
BA -> Battery
Fan+ -> battery
Where do you have it grounded?
My Portfolio
Please Share
Check Out My Builds
Old 06-07-2013, 11:59 PM   #773
Zac--SRS13
Zac--SRS13's Avatar
Just sanded a part of the chassis near the wiper motor and bolted it down there
Old 06-09-2013, 09:00 PM   #774
xZxCORE
Ok cool. What are the steps required to actually block of the center vents (In s14) and still retain function of other vents properly? It will probably be nice when blocked of due to the increase of air flow out the other vents..
Old 06-09-2013, 09:34 PM   #775
xZxCORE
Also is in possible to talk XRP into doing different colors for there clamshell's?
Old 06-11-2013, 03:01 PM   #776
Konster
Konster's Avatar
Konster is an unknown quantity at this point
I'm thinking of dyeing the carpet in my Vert. Do you have any suggestions on what product I should use?
Thanks in advanced.
Hyer.
Konster is offline   Reply With Quote
Old 06-11-2013, 07:28 PM   #777
Broadfield
Broadfield's Avatar
You would simply block off the opening right behind the vent that you are utilizing for gauges etc. The easiest way is to use duct tape. Or you can cut a piece of wood or ABS the shape of the opening in the duct and pressure fit it in.
They only have the purple and the bright nickel plated. You would have to anodize them yourself or pay a place to do it. I have plated things myself and it's really cool. You would need to reverse the plating procedure to strip the purple off, then anodize it whatever color you want. This is where I bought my Zinc plating kit from:
Plating Kits Electroplating Kits Aluminum Anodizing Kits Powder Coating Systems Metal Polishing And Buffing Supplies - Caswell Inc
Thanks in advanced.
I have zero experience with dyeing material.... sorry.
My Portfolio
Please Share
Check Out My Builds
Old 06-11-2013, 08:12 PM   #778
Konster
Konster's Avatar
No prob, thanks.
Hyer.
Old 06-12-2013, 09:45 PM   #779
sidewayz240
sidewayz240's Avatar
sidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nice
Hey Toby, I've been working on a cluster surround similar to the one you just posted in the interior thread. I'm painting it with SEM color coat. The first time I painted straight onto the plastic, there was a very slight difference in how the paint took to the plastic vs. the body filler texture. So I got some plastic primer (not SEM product), primed it on the weekend and just tried laying on the SEM today and as I expected it lifted the primer slightly in spots. Any suggestions? Do you use any sort of primer normally?
-Trevor
sidewayz240 is offline   Reply With Quote
Old 06-12-2013, 10:55 PM   #780
Broadfield
Broadfield's Avatar
Well, I never use primer and I never use filler.
My Portfolio
Please Share
Check Out My Builds
broadfield, toby
