Old 08-09-2004, 02:58 PM   #1
augimatic
augimatic's Avatar
augimatic is an unknown quantity at this point
Send a message via AIM to augimatic Send a message via MSN to augimatic Send a message via Yahoo to augimatic
Car is stalling when in a drift
I was messing around the other day, and got the car to go sideways. Well actually I do this a lot. But this time the car stalled. I had a really good slide and I was on E and then the car just stalled out. I think I know what is it but just to make sure I'm not missing anything I was wondering if you guys had any thougts. I'm pretty sure it's cause my tank was almost empty. But not sure.
Super Asians Need Love too
Augie
augimatic is offline   Reply With Quote
Old 08-09-2004, 03:10 PM   #2
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
check your power steering fluid level. drifting on e, sounds fun
WheelsDirty
Old 08-09-2004, 03:15 PM   #3
augimatic
augimatic's Avatar
Funny you should mention that cause I'm leaking PS fluid, found that out not to long ago. Why would that make the car stall.
Augie
Old 08-09-2004, 03:18 PM   #4
RpSinner
RpSinner is an unknown quantity at this point
fuel pump? one guy had a problem with this...whenever he would slide a certain way his car would stall because of a bad fuel pump
RpSinner is offline   Reply With Quote
Old 08-09-2004, 04:17 PM   #5
s0ldats
s0ldats is on the path to ruins0ldats is on the path to ruin
yessiree check FP. could be a totally different thing but this is what was happeneing on my friend's fc.
s0ldats is offline   Reply With Quote
Old 08-09-2004, 04:43 PM   #6
mikespeed95
mikespeed95 will become famous soon enoughmikespeed95 will become famous soon enoughmikespeed95 will become famous soon enoughmikespeed95 will become famous soon enough
Send a message via AIM to mikespeed95
apparently s13 has a fuel slosh problem, when my car is near E it will lose power drifting. but some gas in the car shoudl solve your problem, mine does the same thing.
i like drift racing
mikespeed95 is offline   Reply With Quote
Old 08-09-2004, 04:54 PM   #7
augimatic
augimatic's Avatar
well hasn't happened again but I have gas in the tank now so, oh well, maybe just a fluke.
Augie
Old 08-09-2004, 06:57 PM   #8
citizen
citizen's Avatar
citizen is making a name for him/her selfcitizen is making a name for him/her selfcitizen is making a name for him/her self
Send a message via AIM to citizen
momentum + low fuel = fuel pickup problems. physics, the more you know!
citizen is offline   Reply With Quote
Old 08-09-2004, 10:21 PM   #9
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
dont go sideways?
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 08-10-2004, 12:07 AM   #10
INeedNewTires
INeedNewTires's Avatar
INeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond repute
mine does the same thing, its not the FP but rather the gas tank is dented to hell so the pump doesnt pick up the lowest part on the tank anymore, so when i get to E, im screwed
also when my gas light comes on, i have like maaaaby 1/5 gal.... not much time to fill up
INeedNewTires is offline   Reply With Quote
Old 08-10-2004, 12:13 AM   #11
knightrider
knightrider's Avatar
knightrider is an unknown quantity at this point
maybe you guys should make it a point to fill up at a 1/4 tank instead of when your cars start studdering from fuel starvation, it will be better for everything in the long run, running the pump dry will wear it out because the pump uses the gasoline to cool the motor, and also lubricate the bearings.
Drift_ Into A Mountain
Jim Wolf Technology
Stock CA18DET-SR T25-greddy FMIC-JWT SR Lightened FLywheel-300zxTTclutch-SR20DET JWT tuned Ecu
knightrider is offline   Reply With Quote
Old 08-10-2004, 12:30 AM   #12
stinky_180
stinky_180's Avatar
Trader Rating: (26)
procedure 10 - engine stalls when turning...
1. check fuel level
2. disconnect each injectory harness. is there a cylinder that doesn't make the idle drop?
-if so check fuel pressure (34 psi with fuel regulator connected, 43ps when not)
3. check injectors
4. check ignition spark.
5. check fuel pressure.
check ecu pin terminals.
check ground circuit and power supply.
(rarely the cause but good to check anyway)
WheelsDirty
Old 08-10-2004, 12:31 AM   #13
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
yeah uh, keep gas in ur car, its that simple.
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
Old 08-10-2004, 07:46 PM   #14
96twofourty
96twofourty is an unknown quantity at this point
now what in the hell would any of this have to do with drifting?
3. check injectors
96twofourty is offline   Reply With Quote
Old 08-10-2004, 08:09 PM   #15
WhiteNissanS13
WhiteNissanS13 is an unknown quantity at this point
Send a message via AIM to WhiteNissanS13 Send a message via Yahoo to WhiteNissanS13
you shouldna drift when your on drugs. jk
WhiteNissanS13 is offline   Reply With Quote
