![]() Join Date: May 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
S14 Tranny oil capacity?
Used the search...couldn't find it. Look at these unsure answers:
http://www.zilvia.net/f/showthread.p...fluid+capacity by DuffMan http://www.zilvia.net/f/showthread.p...fluid+capacity this seems like he's talking about ATF. anyway...couldn't find it in my owners manual either. any help would be great. thanks. |
2.5 quart. redline mt-90
That's what i have. You fill it up to the point where it overflows out of the filler plug. This is what the FSM says.
![]() driftingisgay.com |
![]() Join Date: Jan 2003
use a lift(if you have access), or jack the car up and put it on jack stands, so that the car is level, remove the fill plug on the side of the transmission first, this will allow air into the trans when you remove the drain plug so that it wont splash, trust me, gear oil is nasty stuff, you dont want it on you. then remove the drain plug, leave it sit for 10 minutes or so, let all the crap out, clean off all the metal pieces off of the magnet on the drain plug, and find your trusty dif oil pump, if ya dont have a pump, you can fill it by removing the shifter and filling it from the top, just have someone under the car so that they can tell you when its full, and reinstall the fill plug. oh yea, and buy fluid in cases, its always good to have extra and not have to run to the store every time you need to change fluids.
Drift_ Into A Mountain Jim Wolf Technology Stock CA18DET-SR T25-greddy FMIC-JWT SR Lightened FLywheel-300zxTTclutch-SR20DET JWT tuned Ecu |
![]() Join Date: Mar 2003
an simpler way to do it is just get a long hose and a funnel. with the car on stands, run the hose through the engine bay and stick it into the tranny fill plug. put the funnel in the hose and start pouring it in. it goes faster if you stand on a chair or something.
