Old 06-20-2013, 07:29 AM   #1
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
FS: R32 Skyline GTR, R34 swap. *NSFW*
**READ THIS BEFORE GOING ANY FURTHER**
Please contact me by e-mail ONLY!
E-mail: [email protected]
PRICE: $21,700 (negotiable)
*NO CAR TRADES*... I need the money.
*****Please keep all negative comments off my F/S thread*****.
DO NOT COMMENT ON THE LEGALITY OF THIS CAR. IT'S 100% legalized in the state of NEW YORK, and HOLDS A REAL NYS Title, Registration, Inspection & insurance.
You can register this car like any other in your state. That's how I did it, and that's how the guy before me did it, NEVER A PROBLEM. So don't believe all the BS you read on the net,
Please don't ask me how to import cars I DON'T KNOW. If you're not serious about buying this car PRESS THE BACK Button on your browser, thank you...
1990 Nissan skyline GTR
62k miles (100k Kilometers)
R34 Skyline GTR Rb26dett engine. (cost $5000)
Estimated millage on engine: 27,000
All work was performed by trained professionals, rest assure the highest level of precision and care was taken at all times.
Resurfaced cylinder head, tested&checked, exceeded oem RA texture on mating surface,
Replaced valve stem seals and all other gaskets and seals. all valves lapped, and head was vac. checked. Bottom rotating assembly was never touched or disassembled as it was 100% perfect in every aspect.
All new gaskets and seals from top to bottom & front to back
> HKS gt2540 x2 (precision rebuilt 5k miles ago)
> HKS Wastegate actuators
> HKS oil cooler&filter relocation
> HKS timing belt
HKS Highpower silent 4" exhaust (3.92OD)
> Cometic headgasket
Cometic metal intake manifold gaskets
> ARP studs
> Tomie pon cams type B
> Tomei oil pan baffles
Tomei oil block-off and restrictor
> Nismo water pump
> Nismo thermostat
> Nismo fpr
> Nismo down pipe
> 3" dump pipes
> Welded "twin turbo" pipe
> Nitto oil pump
> ATI harmonic balancer
> Chromoly flywheel
> Competition Clutch stg4
> Custom 10an head oil "drain back"
> Custom 3" intake k&n filters
> Nissan quest 120amp alternator
> AEM water&methanol injection
> AEM widband
> Greddy FMIC kit
> Greddy radiator
> Greddy type S ebc
> ATESSA awd controller
> Cusco brake master cylinder stopper
> Blitz twin BOVs
> Blitz boost/vac. Gauge
> Rebuilt front and rear axles
> New ball joints (4 front)
> Ams front camber adjusters
> BC racing coilovers
> Driftworks front tension rods
> Driftworks rear lower control arms
> Stainless steal brakes lines
> 14" Brembo front calipers
> Hawk HP+ pads
> SPL outter heim outter tie rods
> SPL aluminum subframe bushings
> Project Silvia RUCA
> Nismo rear traction rod
> Nismo front strut brace
> NISMO 2 way locking diff. (rebuilt 5k miles ago)
Nismo GT shift knob
> Cusco rear strut brace
> Tomei inner tierods + 7mm spacer
> Sparco champion steering wheel
> HICAS lock out bar
> HICAS removed (entire system)
Mines ECU
Rota grid 18x10+25 wheels pictured, (i can remove is necessary)
THIS CAR IS NOT FOR THE SIMPLE MINDED or for an inexperienced driver. On 14lbs of boost the car is an absolute ANIMAL! pulls butter smooth and shifts perfectly.
The whole build was intended for 25+lbs of boost will require tuning to achieve this. The Oil was changed every 2000 miles with mobil1 15w50. I've used redline in the gearbox and diff.
the car drives great!, all accessories work, lights, wipers, radio etc...
NO TIRE KICKERS or test pilots, sold as is. If you're seriously interested in owning this car you know what you're getting into. ** Please come check it out **
but PLEASE DON'T WASTE MY TIME, If you have no intention in buying
The car is NOT tuned so it hasn't been dyno'ed to get the HP number.
Now the bad:
***Car requires an engine management and tuning (power FC) example: Engine will stall, when coming to a stop light unless you tap the throttle a few times to "keep it alive"***
Paint- The paint isn't so great, many nicks, scratches and chips. NO dents or accident damage. Signs of re-painted panels are visible!
A/C isn't charged. it works (most of the time) BUT, might require a new high pressure switch.
Chrischeezer is offline   Reply With Quote
Old 06-20-2013, 07:51 AM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
I just got fired. Reason: car porn.
Thanks a lot asshole.
Old 06-20-2013, 09:08 AM   #3
Phantogram
Phantogram's Avatar
Phantogram is an unknown quantity at this point
Saw this car in person... so freaking jealous. GLWS and bump for staten islander
Phantogram is offline   Reply With Quote
Old 06-20-2013, 12:28 PM   #4
Chrischeezer
LOLOL!!
Old 06-20-2013, 11:08 PM   #5
Shatzen
Shatzen is an unknown quantity at this point
Y U label NSFW and there no boobies?
Shatzen is offline   Reply With Quote
Old 06-21-2013, 01:02 AM   #6
jsaviour84
jsaviour84's Avatar
jsaviour84 is an unknown quantity at this point
What a amazing fucking skyline! What dreams are made of for sure
EVO X GSR and R32 GTR
jsaviour84 is offline   Reply With Quote
Old 06-23-2013, 08:36 AM   #7
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Did you really just put Ray's stickers on Rota Grids?
CLICK HERE!!!
Old 06-23-2013, 09:15 AM   #8
Chrischeezer
Yes, did it 5 years ago. i don't care its just a wheel, If i wanted the real thing I'd get it but i rather spend money on more important things... like my engine set-up. ( cost me over 10k alone)
Old 06-23-2013, 03:25 PM   #9
jsaviour84
jsaviour84's Avatar
out of all the boss that went into this car, you are worried about stickers?
Old 06-23-2013, 10:08 PM   #10
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
It calls into question the legitimacy of other parts, yeah he may have listed them as grids but it still makes people think. Plus its pretty tacky, now queue the hate and discontent towards this post.
With that said it is a nice looking car and the price is still less than you would find at an importer.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 06-23-2013, 11:59 PM   #11
jsaviour84
jsaviour84's Avatar
No hate from me, everyone has their own feelings about things. I can't tell you are wrong to feel that way.
Old 06-24-2013, 01:34 AM   #12
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
NSFW in thread title and zero female nudity. I am disappoint.
In all seriousness though, good price for a nice car. GLWS.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
Old 06-24-2013, 01:37 AM   #13
zerodameaon
It still looks great, and even if half of it were fake(not saying one way or another) it is still a pretty legit car and a genuine driver selling the car not a reseller hoping to make a buck. I apologize if it seems as an attack on the car, more of just an observation. That and the no step decal/paint made me chuckle and adds a nice touch.
Old 06-24-2013, 01:41 PM   #14
Chrischeezer
you really just posted that...
you must be mistaken me with someone else
My heart and soul were put into this build I've sacrificed more then anyone ever would. You have some nerve... Don't sleep on this car, its everything listed. I'm not a fly by night guy trying to sell my car... I've been in this community for a very long time.
Old 06-24-2013, 02:49 PM   #15
cschepp
cschepp is an unknown quantity at this point
First thing stop shitting in his thread. The car is a unreal car by any standards and looks exceptionally clean! Anyone who buys this is getting a hell of a deal at this price! Your knocking him because he put different stickers on the rims lol, try building a car and then let's see how much cash you have left over.
Nice car Chris. It's sad you have decided to sell
cschepp is offline   Reply With Quote
Old 06-25-2013, 02:42 PM   #16
Chrischeezer
^Thank you
!!! I NEED TO SELL THIS CAR RIGHT NOW !!!
IF YOU HAVE A SERIOUS OFFER PLEASE LET ME KNOW, COME GET IT BOYS
Old 06-25-2013, 03:16 PM   #17
EVL-FD3S
EVL-FD3S's Avatar
EVL-FD3S is an unknown quantity at this point
give me a call/text its in your pm's im gona come take a look at it 26 or 27th if you lived in Albany area ect it would have been sold 4weeks ago!!
EVL-FD3S is offline   Reply With Quote
Old 06-27-2013, 02:35 PM   #18
gippy87
gippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-known
trade you a 2000 corvette + some cash on my end haha
gippy87 is offline   Reply With Quote
Old 06-27-2013, 07:20 PM   #19
raph82
raph82 is an unknown quantity at this point
NICE Skyline
nicely put together!
raph82 is offline   Reply With Quote
Old 06-29-2013, 05:15 PM   #20
NAVY-ET
NAVY-ET's Avatar
NAVY-ET is an unknown quantity at this point
I'll take it send me a pm so we can get in touch. I have money in hand
NAVY-ET is offline   Reply With Quote
Old 06-29-2013, 11:00 PM   #21
raph82
Wrong guy, sorry
Old 06-30-2013, 12:12 PM   #22
NAVY-ET
NAVY-ET's Avatar
I emailed him twice but I never got a response. I have a pocket full of cash all I need to know is it the car is sold or not.all I need to know if you're still up there I'm going to go get it
Old 06-30-2013, 01:03 PM   #23
cschepp
I have a r32 gtr if you want it. I'm located in Canada though. From what I remember he still ha it for sale and if I had the cash I would buy this too!
Old 06-30-2013, 01:04 PM   #24
maxroach
Location: Simi Valley - California / Perth - Western Australia
maxroach is an unknown quantity at this point
If you ever get this, you hit a jackpot! I really like this car..
Goodluck!
maxroach is offline   Reply With Quote
Old 06-30-2013, 01:10 PM   #25
EVL-FD3S
EVL-FD3S's Avatar
sellers a busy guy has a few events this weekend which is why cars not in my driveway yet! also seller speaks with true professionalism and seems to be a real nice guy to deal with =) hope to take this home soon
Old 07-04-2013, 12:29 AM   #26
Johnny Quest for Boost
Johnny Quest for Boost is an unknown quantity at this point
So is this thing still for sale or what? PM was sent several days ago without any response. Very interested.
Johnny Quest for Boost is offline   Reply With Quote
Old 07-07-2013, 12:55 PM   #27
Still trying to reach you...
Old 07-07-2013, 04:24 PM   #28
EVL-FD3S
EVL-FD3S's Avatar
I be leave cars still for sale....I just picked up a car from upstate ny and had to pass on this true find (sick deal for the money hands down)
Old 07-09-2013, 12:09 AM   #29
Yeah, I dig this this thing but can't begin to understand who supposedly needs money enough to put their car up for sale, and then ignores people with money trying to buy it.
Still waiting on you, Chris.
Old 08-28-2013, 09:48 AM   #30
STR8 H8N
STR8 H8N is an unknown quantity at this point
Sold sold sold sold
STR8 H8N is offline   Reply With Quote
