Old 07-30-2013, 09:16 AM   #1
MrSlappy
MrSlappy is an unknown quantity at this point
Question SR20 IACV Delete
I'll be putting my SR back in soon and was thinking about deleting the IACV to reduce clutter in the engine bay. Before I did anything drastic I was wondering if any experienced SR guys could chime in. I don't want to make the car run like shit, but I wouldn't mind if the idle's rpm bounced around a little. I tried to find potential videos of cars with deleted IACVs, but only found a couple that showed two very different outcomes. Anyone ever done it before? If so, how did it turn out?
MrSlappy is offline   Reply With Quote
Old 07-30-2013, 11:14 AM   #2
cotbu
cotbu's Avatar
I've done it before, many times! The outcome is always the same every time, Idle's like stock, higher vacuum.
This is what I do after the IACV has been blocked off and intake pipe modified. Go into timing mode, adjust base idle via throttle plate, leave timing mode. Rev engine, to about 4500rpm, apply brakes to try and make engine stall. Test drive same test, real world. done. This my experience with SR's though and most had atmospheric BOV's.
Last edited by cotbu; 07-30-2013 at 11:16 AM.. Reason: Or was it lower vacuum damn! ICR!
Old 07-30-2013, 11:41 AM   #3
Mikester
Mikester's Avatar
Mikester is a well-known jackass
With an aftermarket intake manifold, the clutter factor is minimal... However, there is beauty in simplicity~
Mikester is offline   Reply With Quote
Old 07-30-2013, 01:41 PM   #4
MrSlappy
That's encouraging! Please excuse my ignorance, but what exactly is 'timing mode'? I'm assuming some sort of ecu mode??
Old 07-30-2013, 05:12 PM   #5
TheRealSy90
TheRealSy90's Avatar
Also considering this since I live in a place that is always hot. I know in places that have 4 seasons it's not really a good thing to do.
Such a good signature.
Old 07-31-2013, 07:22 AM   #6
Mikester
Mikester's Avatar
I would think the opposite would be true in this case. Always hot means AC is important to have. AAC/IACV adjusts the idle for when the compressor kicks on. I'm sure there is a way around that, but still might be less ass pain to keep it. If you don't have AC, then yea nothing to consider.
As far as 4 seasons goes, this tells me that AC is only needed in the summer; and running the heater won't affect the idle to the degree of the AC compressor. Unless I have this backwards, it seems to me that a milder climate would be the optimal place to delete the AAC valve.
delete, iacv idle control valve, sr20
