![]() Join Date: Sep 2011
![]() Feedback Score: 20 reviews
350z ABS LIGHT ON HELP!!!!!!!!!
i have 2003 nissan 350z that has the ABS light on
have tried replacing the wheel speed sensor the wheel hub the abs module the body control module and the light still comes on brake fluid level is ok. any help i tryed looking on gooogle and the search bar but no one has come across this issue ![]()
GO DUCKS!!!!!!!!! ![]() |
#4 | |
![]() Join Date: Oct 2011
![]() Feedback Score: 15 reviews
Why are you shot gunning parts at your car? You need to pull the code. You probably are running the wrong size rim or tire and it's throwing a code |
#5 | |
![]() Join Date: Jul 2013
95 S14 se RB25DET 348whp ![]() |
#6 | |
I guess i should feed you some info 1. Not my car its a car that was picked up as a trade in 2. Codes where pulled for ONE Fault code the left wheel speed sensor checked the sensor for continuity and it had none 3. We have a SPARE wrecked 350z that we use for parts has rear damage same year we checked for continuity in that sensor and it works places it into the other z and light comes on rigjt away even after you test drive , when you read the live data that sensor that "works" doesnt read, checked for a short in the cable nothing conected to the sensor and the wire is fine swapped out another abs module and the light comes on right away put everything back on probed the wire once the new wheel speed sensor plugs in it emediatly grounds itself when the sensor isnt conected it stays power n ground The other mechanic tryed to replace a wheel hub thinking that could have been the issue it obviously wasnt so when we have a spare donor car we use it Now do you have any input
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
How is anybody supposed to tell you why your ABS light is on without any detailed information? Don't be a dumbass...
Did you check the individual wiring for that sensor to the computer for continuity? It could have a damaged wire somewhere... |
#9 | |
Checked it from the sensor to the abs module and the wire is fine
