Old 07-31-2013, 05:06 PM   #2551
Magnoliarichj
Magnoliarichj is an unknown quantity at this point
G35 19s -3.5 camber in the rear -1.5 front no rub at all super flush no rolled fenders. 255/30/19 and 225/35/19 fronts
Sent from my iPad using Tapatalk HD
File Type: jpg ImageUploadedByTapatalk HD1375311869.534817.jpg (323.0 KB, 42 views)
Magnoliarichj is offline   Reply With Quote
Old 07-31-2013, 05:55 PM   #2552
Trap Star
Trap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant future
Send a message via AIM to Trap Star
On my s13 I'm running s14 lca's in the front and an s14 rear subframe. Basically I just need to know the difference in length on each side front and rear. I've read the fronts are either 10mm or 15mm longer (searching didn't really help with that). Is the difference the same out back?
86 300zx/90 240sx/97 240sx/96 LS400/03 350z
-Shake N' Break Racing-
Trap Star is offline   Reply With Quote
Old 07-31-2013, 06:06 PM   #2553
PeaceOnesxWai
PeaceOnesxWai's Avatar
Trader Rating: (34)
PeaceOnesxWai is an unknown quantity at this point
Feedback Score: 34 reviews
^S14 is about 3/8th" wider both front and rear.. its very minimal difference, but surely not 10-15mm per side. Fender wells have different size on S14
PeaceOnesxWai is offline   Reply With Quote
Old 07-31-2013, 07:50 PM   #2554
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Originally Posted by collegekid View Post
Hey guys I just wanted to get a little input on something just to get an idea of any necessary items like spacers that I would need.
So I have an S14.5 with Origin +20mm fenders up front and stock metal rear. I am set on buying a set of 19 x 10 +19 wheels. I have z32 front and rear as well, which I know just a spacer will fix that if my barrel design is not able to clear. I also do not have coil overs yet.
There will be almost no drifting on these wheels so im not worried about full lock rubbing and stuff like that. I just wanted to make sure that the fronts will be okay, since the origin stuff takes a few months to arrive if I mess up my fender. What other coilovers would clear the fronts besides apexi N1s? I might be set on bc type br coils and I assume they are the same thing essentially.
front
Cant really judge the rear lol
Btw, ive been reading up to page 15 so far to see if anyone else has this problem
Edit- read all 85 pages so far. so far I understand from flips repetition that
9j +9 and 10j +10, 1* camber =8mm, don't go wider than 9.5 in front, do whatever you want in rear.
I'm not gonna be slammed herraflush, so my 19 x 10 +19 should be good all around with some minor camber up front and a small spacer to clear whatever coils I get.
Rear should be okay will a roll and some camber if I need it.
Anyone care to suggest some wide wheel friendly coils? I know flipz said his aragostas cleared a lot and I'm not running any Megan stuff.
Wow...you actually read and listened to what I said...
You're trying to run 19x10 +19 all around? Honestly, 19s on don't belong on these cars, they just look too big even on S14s. Also what size tires are planning on running? Do you already have an idea on which wheels?
Here's a set of 19x9 +19 and 19x10 +20...IIRC tires were 235/35-19 all around.
Since you want 19x10 up front, imagine these sticking out an extra 12mm closer to the fenders. Since my front fenders are pulled, they should be nearly the same as 20mm wider fenders.
As far as coilovers, Fortune Autos are pretty skinny since they use 60mm ID springs vs the 65mm standard (my Aragosta's are 65mm).
Just shoot me a message directly if you got a specific question.
CLICK HERE!!!
Old 08-02-2013, 01:42 AM   #2555
Trap Star
Thanks. I'm running some 17x9 +25 bee*r b5s on the rear right now. Need to get my fenders rolled so I can go lower but it'll be damn near flush when I do. Iirc I'm running 215/45's on them right now.
Old 08-02-2013, 02:47 AM   #2556
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
I was in the same boat as your for the s14 flca, i actually picked up a set. then i realized they were 15mm extension total front track, 7.5 each side.
DODOlogic.ca
ILoveJDM is offline   Reply With Quote
Old 08-03-2013, 03:55 AM   #2557
bosoS14russ
bosoS14russ is an unknown quantity at this point
Hey i was searching around and i found what i was looking for but not on the car i was looking for. Im looking for a s14 with a 18x11 -22 up front running about a 235/40 tire all on stock metal fenders, has anyone see anything like this on a 14? please show me =) thanks guys.
bosoS14russ is offline   Reply With Quote
Old 08-03-2013, 02:46 PM   #2558
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Not the thread to be asking this. Please find and search for the Picture Request thread or use Google.
zooopreme is offline   Reply With Quote
Old 08-03-2013, 03:31 PM   #2559
fliprayzin240sx
Considering you can't fit that in the rear of an S14 without lots of pulling and camber, sure as hell wont fit up front if you plan on turning the wheels. Thats even before you figure out how to fit it under the fender since it'll poke out atleast 2 inches past the fender.
CLICK HERE!!!
Old 08-05-2013, 09:47 PM   #2560
HipHopHippo
HipHopHippo's Avatar
HipHopHippo is an unknown quantity at this point
does anybody know the specs for the wheels on this car
https://fbcdn-sphotos-b-a.akamaihd.n...22669900_n.jpg
HipHopHippo is offline   Reply With Quote
Old 08-05-2013, 09:48 PM   #2561
zooopreme
Trader Rating: (38)
That's shanelach's car, try PM-ing him or being a lurk and search through his posts or threads.
Old 08-05-2013, 09:54 PM   #2562
HipHopHippo
oh ok, cool. thanks
Old 08-05-2013, 10:16 PM   #2563
ktm47
ktm47 is an unknown quantity at this point
Couldnt really find the answer I am looking for so Im wondering if anyone knows how much camber I will need out back on my s13 coupe to fit 17x9.5 +12 wheels with 245/40s on them? My fenders are rolled but not pulled. If its going to be too much camber I just wont run them, i hate pulled fenders
ktm47 is offline   Reply With Quote
Old 08-06-2013, 09:51 AM   #2564
fliprayzin240sx
Kick the tires down to 225/45-17 so you wont have to worry about putting camber or pulling the fenders.
CLICK HERE!!!
Old 08-10-2013, 02:34 AM   #2565
Ryan_1
Ryan_1 is an unknown quantity at this point
I have vskfs they are 18x9.5+2 front and 18x10.5 +1 rear ive got 235 40 for the rear not sure what size front i should go with 215 or 225?
Ryan_1 is offline   Reply With Quote
Old 08-10-2013, 03:03 AM   #2566
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
I'd go with 215s. My wheels are the same size as yours and i have 225/40s in the front and I'm switching. I'm pretty low and it rubs at full lock.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
Old 08-10-2013, 05:10 AM   #2567
fliprayzin240sx
Either one, all a matter of personal preference. Here's mine for a reference. 18x9.5 -1 effective (+14 with 15mm spacer to clear brakes since they're O-disk) with 225/40-18s up front and 18x10.5 +1 O-disk 235/40-18 rears.
Didnt rubbed at full lock since I wasnt super low up front. Would probably have rubbed if I went down a few more inches, but nothing a big ass hammer wouldnt have fixed.
CLICK HERE!!!
Old 08-11-2013, 02:25 AM   #2568
Kuma
Kuma's Avatar
Kuma is an unknown quantity at this point
I've been looking at wheels and I am lost.
I've got 2 choices that I THINK might work.
16x10 -0 (all around)
OR
17x9 -12 (all around)
Which ones would fit better on an s14? I know negative offest is going to poke them out... But I'm having hell trying to find what either offset look like (since one is 9" wide and the other is 10". Depending on poke, I plan on running over fenders (probably the origin 50mm rear, 20mm fronts)
Will they fit without trouble? anyone have experience with either offset?
Kuma is offline   Reply With Quote
Old 08-11-2013, 03:00 AM   #2569
revat619
Retired General
revat619's Avatar
1. Go with the 17s. You'll get tired of the 16s REAL quick.
2. You don't need 50mm rear overs with those sizes. Completely overkill. Depending on tire size and ride height, just dial in some negative camber and you're good.
Rule of thumb: Get the wheels and tires first. If they don't fit with your desired camber settings, THEN get over fenders. Don't just go hacking up your car for no reason.
www.Jspec.com
Old 08-11-2013, 03:20 AM   #2570
Kuma
Kuma's Avatar
Was definitely not going to get the fenders until I saw how much poke I'd have. I was leaning towards the 17"s, but the negative offset made me consider the 16's. Thanks a ton!
I'm fairly low, nothing crazy because our roads suck. Currently with CV meshies. Which I like them, but I'm going to need wider wheels after my swap is complete.
Old 08-11-2013, 09:06 AM   #2571
fliprayzin240sx
^^^Easiest way to figure for your situation. Google search wheel offset calculators. Punch in the wheels you have now then punch in either one of those wheels. It'll tell you how many mm itll be sticking out further than what you have now. Then go to your car and measure it out to get an idea first hard.
CLICK HERE!!!
Old 08-11-2013, 04:07 PM   #2572
Kuma
Kuma's Avatar
I tried using those, but it kept changing my numbers I'd input (I'd input 17x9 -12 225/45, then by the time I'd calculate it would change itself to 17x9 -15 245/45) . Then I went searching through the fitment whore threads for 2 days and realized some people posting their specs were either ass backwards or running spacers and not mentioning that. So I finally broke down and asked.
Old 08-11-2013, 06:35 PM   #2573
fliprayzin240sx
This what i use...
1010TIRES.COM - Wheel Offset Calculator
As far as the 2 wheels you're thinking off (9j -12 and 10j +0), they're gonna poke about the same with 1mm difference between the 2. Basically itll come down to your preference. What's your current wheel spec and I can tell you via above to see the difference.
Personally, I wouldn't go with either one cuz they poke out too much.
CLICK HERE!!!
Old 08-13-2013, 02:16 PM   #2574
Kuma
Kuma's Avatar
This what i use...
I'm running 16x7 +6 currently. less than 2mm camber all around and wheels are even with fender up front, and sucked in approx 5mm from rear fenders. (I don't know the best way to measure)
From the calculator it said:
16x10 +0 will be 32mm less clearance inner and poke out 44mm
17x9 -12 7mm less clearance inner and poke out 43mm more than current set up.
I don't mind cambering the front, but I want traction in the rear for daily (235's or 245's with little camber). I can throw my 16x7's on when I drift.
Thanks for helping me figure this out.
Old 08-14-2013, 01:01 PM   #2575
Farkel
Farkel's Avatar
Location: B̷͈͇̠̗͔̼̝̓̎͛͂A̧̡̠̩̭̹̼̭͔̎̃̈́̍͂ͬͬ̚Y̯̜ͨ̒̾̽͊͘ ͈͙̰
Farkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura about
Send a message via AIM to Farkel
Question: Who has front wheel fitment where the tire comes right out to the fender and is totally flush?
It seems like generally on front wheel setups, the front tire is a little more sunk than the rear. For those who are flush at the front as well, how does it drive? Does it ever rub when you're turning and going over a dip?
★ ★ GRANDMIGHTY.COM ★ ★
Farkel is offline   Reply With Quote
Old 08-14-2013, 01:17 PM   #2576
sfg20t
sfg20t is an unknown quantity at this point
Going to be running chargespeed 50mm overfenders in rear and 30mm over fenders in the front on my s14. looking for minimal camber not more than -2/3 degrees in the rear. thinking of 18x9 0 in front and 18x10.5 -25 in the rear...too agressive for the camber spec i want? not very good with fitment...i rely on my wheel guru friend who's out of town.
sfg20t is offline   Reply With Quote
Old 08-14-2013, 03:29 PM   #2577
revat619
Retired General
revat619's Avatar
My car drives just fine. It rubs a tad at full lock but when i switch to 215/40s that will go away for the most part. Every totally flush set up will rub a little under hard cornering though. Just the nature of the beast.
It's not too aggressive. You won't need that much camber in the rear with 50mm overs. BUT, 18x9 0 offset with 30mm overs is gonna be sunk.
www.Jspec.com
Old 08-14-2013, 05:24 PM   #2578
sfg20t
Thanks, how much negative offset would you suggest for the front? my friend said either 0 or -3, but you make it sound like i'll need a lot more.
Old 08-14-2013, 06:01 PM   #2579
ov1989
ov1989's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
nvm the dudes up here clarified the specs
Old 08-17-2013, 07:58 PM   #2580
240ND
240ND is an unknown quantity at this point
I've been looking for a couple hours now and haven't been able to come up with much.
I haven't really looked too much into wheel offsets so please don't hate too much, but there is a guy local selling a set of 17x9 +17 offset and I'm running the maverick dual rear caliper setup which acts as a 8mm spacer. I have 225/45/17 tires for them as well. Would I need to roll and/or pull my rear quarters? I'm okay with rolling, but I don't want to pull them. I'm debating just ordering new wheels with a higher offset, but if these would work I'll go with them.
Sorry for the paragraph and I'd appreciate the help!
240ND is offline   Reply With Quote
