Old 08-17-2013, 05:31 PM   #1
PIN GIO 2
PIN GIO 2's Avatar
PIN GIO 2 is an unknown quantity at this point
Send a message via AIM to PIN GIO 2
LS1 Engine and T-56
I really hate post it for sale because i spent money on engine too much! i have to sell it due cant afford build 240sx drift track project. So i need to back to school and no time build this car. CPR is the one who build my engine port cnc 853 head cylinders with aluminum 5.3 block from 2007 silverado truck low miles. new beehive valve springs, new isky big camshaft, new camshaft Clevite bearing, new rod Clevite bearing, new crankshaft Clevite bearing, balanced ls1 crankshaft had 24x crank, new piston rings, new ls2 lifter, new ls2 timing chain, new katech rod bolts, new Melling oil pump, new gto oil pan with improved racing oil pan baffle and come with Oil Accsump, stainless steel lines, Oil Cooler Adapter and Oil Cooler brand new in box, make custom standalone engine harness with PCM tuning by CPR, i found low miles T-56 i was paid $1800 for it, come with new solid mount. you will have to get new clutch kit but i have flywheel. of course i will throw firebird ls1 accessory drive included. new water pump from c5. New rebuild ps pump, ls1 starter, 02 sensors front pair, new belts, ls1 intake maniold, new gasket kit, new head gasket, oh block have been deleted D.O.D. underneath block off and come with ls2 valley cover. pretty much enough info and i may forget add more. if u plan to ls1 swap into 240sx then i will give you my front subframe modified clearance gto oil pan and motor/trans mounts. sikky drive shaft. You will need buy egr block off and new clutch kits and clutch slave. also i have radiator and elec fans for sale as well.
i havent start it up so still zero mile fresh engine. i really sad to see it sell. im interesting in trade car or $6700 cash. text me 8 zero 5 551 57 five seven
trade car:
rx7 fd shell
e30
240sx s13 or s14
s15 shell
supra shell
look for rwd must be 5 speed
proof Anthony did build this CPR engine
PIN GIO 2 is offline   Reply With Quote
Old 08-18-2013, 12:05 AM   #2
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
Nice parts here. If you decide to part i would def be interested in taking some stuff off you. GL with sale.
2muchboost is offline   Reply With Quote
Old 08-18-2013, 12:36 PM   #3
PIN GIO 2
PIN GIO 2's Avatar
thank man i dont really want to part out
Old 08-19-2013, 06:49 AM   #4
2muchboost
Trader Rating: (33)
No problem....just throwing it out there in case you change your mind. GL with sale broski
Old 08-19-2013, 08:18 PM   #5
Joedrt
Joedrt's Avatar
Joedrt is an unknown quantity at this point
Me and 2muchboost are both in ny if you decide to part ill take the t56 figure it would cut the shipping cost down
Joedrt is offline   Reply With Quote
Old 08-19-2013, 09:54 PM   #6
PIN GIO 2
PIN GIO 2's Avatar
im afraid shipping would cause trouble because happened to me screw up w paypal
here add new pic
Old 08-19-2013, 10:36 PM   #7
itsmillertime
itsmillertime will become famous soon enoughitsmillertime will become famous soon enoughitsmillertime will become famous soon enoughitsmillertime will become famous soon enough
Who made the harness? I'd be interested in it and a a few other parts if you decide to part out.
http://zilvia.net/f/image.php?type=sigpic&userid=45657&dateline=125141  5581
itsmillertime is offline   Reply With Quote
Old 08-19-2013, 11:48 PM   #8
PIN GIO 2
PIN GIO 2's Avatar
CPR engine made custom harness.
Old 09-04-2013, 01:13 PM   #9
PIN GIO 2
PIN GIO 2's Avatar
Bump im interesting in drift car track or $7000 obo
Old 09-23-2013, 09:01 PM   #10
PIN GIO 2
PIN GIO 2's Avatar
Still for sale and trade
Old 11-14-2013, 08:02 PM   #11
PIN GIO 2
PIN GIO 2's Avatar
close this thread! i keep it and keep going build car.
