SR20DET Z32 MAF swap issue HELP!
i've got an S13 with an SR20DET in it.
just picked up a GT2871R turbo, 740cc injectors, Enthalpy tune ECU, z32 maf I bought the whole set up from a guy in the states that was running it on his s13 as well. Put everything in the car and went to fire it up and the car runs rough at idle (5-600rpm surging) with MAF harness plugged in. When you unplug the MAF, the idle goes up to 1200 and holds smooth there. Seems to run better unplugged. I've checked on the ECU and it's not throwing a code for the MAF either... I've double checked my wiring for the MAF harness and from what i've read online, it looks to be sound. only thing i did was take the 2 black ground wires in the center of the z32 harness and tie them together into the single black ground wire on the s13 harness. If anyone has any ideas of what to try next, or ever ran into this problem, help me out please! thanks much |
![]() Join Date: Dec 2004
Trader Rating: (58)
Find a guide on a S13 SR to Z32 MAF plug swap and then make sure your timing is set properly, your TPS is set properly, and you IACV is set properly.
I've used the guide to check the wiring on the z32 maf. I've tried switching the 12v and 0.5v wires too. The car ran fine with the stock turbo on it before i swapped all this stuff. does the timing or IACV need to be adjusted after a swap?
#4 | |
![]() Join Date: Nov 2010
Also ask if the tune has any advanced timing. I've read threads where peoe have reported needing to advance to 20*
![]() Join Date: Jun 2007
Hopefully you already put an upgraded fuel pump in to compensate for the higher fuel demand.
Second, what you are describing makes me wonder if the previous owner truly ever had that stuff installed & tuned. I'd check with Enthalpy- did PO provide any receipts with the purchase?
#6 | |
Ive grounded the 1 ground wire to the chassis as well. ill try advancing the timing now. |
#8 | |
Trader Rating: (58)
ended up putting the car back to stock so i could make it to an event that night. I'm in contact with Martin from Enthalpy now, so when i try to install again, i'll get him to help me along. thanks all
Same issue
I'm having the same issue except mine also stalls most time with MAf plugged in.. Did you ever resolve your issue? Same set up with z32 except mine is a jwt tune...ur problem sounds like the wires you crossed...
#11 | |
Hope that helps |
I know this is an old thread but I am having a similar issue. I bought a new Z32 maf because i though my old one died it worked fine then one day my car went super rich 10:1 AFR i unplugged the maf while playing with the throttle so the car doesn't die then plugged the maf back in and the idle smoothed out and back to 14:7 AFR and ideas????? this has been happening lately and not sure why PLEASE HELP!!!!
