Old 08-20-2013, 12:24 PM   #2941
Rambo slice
Rambo slice's Avatar
Rambo slice is on the path to ruinRambo slice is on the path to ruin
[/QUOTE]
The stance on this is nice!
Rambo slice is offline   Reply With Quote
Old 08-20-2013, 01:48 PM   #2942
WhiteS12+1
WhiteS12+1 is an unknown quantity at this point
Alright guys trying to address my traction issues now that my car is tuned and am looking into drag radials for better traction. Nothing outrageous just 350whp on a DD dyno with a 2871r setup.
Anyhow my current set up is 17x9 +22 front with 215/45/17 falken rt615 and 17x10+22 with 235/40/17 faken rt615 (I know, I know). I bought them years ago, without really knowing what I was getting.
I like the MT E/T streets, but don't know if 275/40/17 will fit on the back due to the offset of my rims? If they would I would move the 235's up front? Does anybody have any experience with fitting the 275 on a similar spec'd wheel?
Also I am open to any other suggestions/recommendations. I really want to to try and use the rims I have currently. The car is not a my daily, so I am not to concrned with wear. I thought about buying a spare set of rims to mount the drag radials on, but am also concerned with traction on the street.
I also thought about the Nittos in 245/45/17, but don't know if they would be ideal for traction on a 17x10. Any input or advice would be greatly appreciated.
WhiteS12+1 is offline   Reply With Quote
Old 08-20-2013, 04:17 PM   #2943
silviaks2nr
silviaks2nr's Avatar
If you really want traction get a pair of 15s, good rubber, and soft springs.
Old 08-21-2013, 08:01 PM   #2944
BraveFart
BraveFart is an unknown quantity at this point
Originally Posted by bnf View Post
17x9 +12 All round
255/40/17 Nitto NT-01 All round
Looks awesome sauce! What is the car used for? what are the alignment specs?
BraveFart is offline   Reply With Quote
Old 08-22-2013, 04:44 PM   #2945
bnf
bnf is an unknown quantity at this point
Thanks mate.
The cars used for just time attack here.
Im on -1.5 camber rear and -3.5 front
Caster is about 8 degrees
Does anyone know what the max tyre size i'd be able to run with +50mm rear over fenders?
I'll be running a 18x10.5 +15 rim
bnf is offline   Reply With Quote
Old 08-22-2013, 06:00 PM   #2946
S14DB
AFC #1
S14DB's Avatar
Thanks mate.
315 or 305 would probably be ideal.
Old 08-22-2013, 06:05 PM   #2947
BraveFart
I agree^ You could do some calculations for yourself
You could use this to start out with to kind of see where you're at Online Wheel & Tyre Fitment calculator. Offset, Tyre stretch and Rolling Radius calculator
But a 305 should fit easily
Old 08-22-2013, 06:31 PM   #2948
bnf
That was the exact answer I was looking for!
What would u guys recommend for fronts?
Ill be running 17x9.5 +12 with 40mm overs
I love my square setup, but doubt 305's will go on the fronts
Old 08-22-2013, 06:33 PM   #2949
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
I would say 265's
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 08-22-2013, 06:38 PM   #2950
niscur29
Location: Back IN FL, bring nice cars to the fail state!
niscur29 is an unknown quantity at this point
I running 18x9 +18 up front with +20mm fenders and with a 255/35 its really close to my stance coils but doesnt rub. So a 265 on a 9.5 should clear about the same depending on tire choice.
niscur29 is offline   Reply With Quote
Old 08-27-2013, 03:49 PM   #2951
BraveFart
I'm getting new wheels and tires very soon for my ls1 s14 stock body. I was thinking Enkei rpf1's 17x9+22 with hankook ventus rs-3 255/40 all around. I'm pretty sure I want to go with this square setup. Car will be used for street, autocross, and prob some other random shit. I just need conformation that the fronts will fit and not rub on the coilovers. Im quite sure it won't but would love some confirmation.
Any suggestions are welcome as well!
Old 08-27-2013, 04:07 PM   #2952
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
The fronts will fit, the rears are gonna take some fender love to clear.
e1_griego is offline   Reply With Quote
Old 08-27-2013, 05:06 PM   #2953
jr_ss
They should clear both front and rear without much massaging in the rear. Perhaps a roll and some cambering in will work just fine. The fronts "should" clear if you have slotted top knuckle holes. I'm unsure how much clearance you will have if you don't, but it will be minimal.
I have 10" wheels in the rear with 285's and +38mm offset, I rolled my rears for the needed clearance. You'll stick out 3mm more with the 9's at +22mm.
Old 08-27-2013, 05:29 PM   #2954
BraveFart
I don't have slotted top knuckle holes. I know the distance from the tire to coilover will be very close. But I'm crossing my fingers that it will work lol. what do you have on the front?
also, I plan on running between 1 and 1.50 degrees of camber in the rear. Your tires are a lot wider on the rear so maybe all I'll only have to roll the fenders?
Old 08-27-2013, 05:59 PM   #2955
jr_ss
I have 9's up front with a +23 offset. However, my KW's have slotted upper knuckle holes, so I can get more clearance.
Old 08-27-2013, 11:59 PM   #2956
BraveFart
Okay thanks for the info! I guess I'll just have to do it and find out. Worst case scenario I'll have to get a small spacer up front but that's not a big deal. Although I would like for them to just fit with no spacer.
Old 08-28-2013, 12:26 AM   #2957
mad-ass
mad-ass's Avatar
anyone have any experience with RE050A's?
I let my friend barrow my rear wheels/tires for Mazfest this last weekend, he said it started to get slippery on him.(18x10+38 275/35/18) when it got too hot, the tire mfg. date is 4511[still good tires] and wondering if that's just normal RE050A thing or not.
Thanks.
Old 08-28-2013, 05:18 PM   #2958
itsguyguy
itsguyguy's Avatar
itsguyguy is an unknown quantity at this point
Thanks.
IMHO I hate anything that comes from Bridgestone, especially the RE050A Potenzas. Sure, the rubber may last a few years and may be drivable all season, but for high speed grip, or grip in general, this tire is complete shit.
The feel of the tire is also shit when comparing to other competing brands (Continental, Michelin, Nitto) with a heavier price tag.
The tires are noisy.
Way too noisy after 15K miles, at least they were for me.
I'm assuming you have the run flats, which I previously had on my S13 coupe.
Hated them.
With a passion.
So badly.
Michelin Pilot Spot 2 or 3 are pretty damn good, which I approve over almost anything besides Nitto.
itsguyguy is offline   Reply With Quote
Old 08-28-2013, 06:16 PM   #2959
seagrasser
seagrasser is an unknown quantity at this point
^ ditto to what this guy said.
Hated them after 5K miles, but were too expensive to replace until they were worn.
S14 RB25
seagrasser is offline   Reply With Quote
Old 08-29-2013, 12:04 AM   #2960
mad-ass
mad-ass's Avatar
Glad I'm not the only one with such grip problem.
I will say though that they are fairly quiet, but can't really tell in a 240 anyways. LOL
Old 08-31-2013, 06:45 AM   #2961
Black R
Black R's Avatar
Black R is an unknown quantity at this point
Anybody finding wiiide tire deals lately?
I'm looking for 295's or wider. I'll even take 335's.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers
Black R is offline   Reply With Quote
Old 08-31-2013, 07:19 AM   #2962
CaptainVlad
CaptainVlad's Avatar
CaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really nice
I have a 265/35 on an 18x10 +18 with a 30mm overfender, and about -2.5 of camber is the least I could do, without having the tire right up against the overfender. (wanted -1.5)
Just add the 20mm difference in our overfenders sizes, and that should help you out.
CaptainVlad is offline   Reply With Quote
Old 09-04-2013, 03:24 PM   #2963
ShakotanGazelle
ShakotanGazelle is an unknown quantity at this point
Here's my Z!
Sitting on lowering springs for now, BC coils should be ordered soon
Setup out back is 18x10+15 BSA 215s with Goodyear 275/45s on slight rolled fenders. Fitment looks pretty good for stock body IMO
ShakotanGazelle is offline   Reply With Quote
Old 09-05-2013, 12:45 PM   #2964
Ruben240
Ruben240 is an unknown quantity at this point
s14.
Can I fit 18x10.5 +22 with 285/35 in rear and 18x9.5 +20 with 255/40 in front?
Got BC coils and 35mm overfenders all around. If I can't can you please tell me offsets to fit? Ty
Ruben240 is offline   Reply With Quote
Old 09-11-2013, 09:05 PM   #2965
BraveFart
Originally Posted by Ruben240 View Post
s14.
You might need a spacer in the front, but depends on the coilovers.
Old 09-11-2013, 10:31 PM   #2966
mad-ass
mad-ass's Avatar
well, plug these numbers into offset calculator.
my rear wheels are 18x10+38 with 275/35/18, tucking about 3/8th of tire, fender is pulled 3/4th inch, 0 camber. Just off my head, you shouldn't have any problem fitting that with 35mm over fenders. Front's you'll need about 5mm spacer to clear the coilovers, because my 9.5+15's are about as dangerous as it gets. LOL and step down on the side wall there, because the 255/40's are going to be super tall.
Old 09-12-2013, 11:32 PM   #2967
jamg
jamg is an unknown quantity at this point
quick question
17x9
+25 offset
will a 245/40 or 45 tire fit up front?
and that's the car being as stanced as possible.
i had a 17x9.75 +25 with a 245/40 tire, and i couldn't get it to fit. even with a 10mm spacer, it hit the coils.
jamg is offline   Reply With Quote
Old 09-12-2013, 11:38 PM   #2968
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Depends on the coil.
That's what I run in the front of my hatch. It fits fine for me.
Old 09-12-2013, 11:45 PM   #2969
WristWork
WristWork's Avatar
WristWork is an unknown quantity at this point
WristWork is offline   Reply With Quote
Old 09-13-2013, 05:59 PM   #2970
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
it seems somewhat difficult to run a 255/35 on a low offset 18x9.5 in the front of a s14, but I see many people run 17x10's and 17x9.5 with 255/40's in the front without an issue.
According to this calculator a 255/40r17 has the same width and overall height as a 255/35r18.
Tire Dimensions Made Simple - Discount Tire
I'm going to run a 18x9.5 +15 up front and a 18x9.5 +22 in the rear with 255/35r18 all around but I think I may have to use a 235/40 in the front for fender clearance..
spooled240 is offline   Reply With Quote
