Old 09-03-2013, 08:42 PM   #1
S13alldayyo
S13alldayyo's Avatar
S13alldayyo is an unknown quantity at this point
Isis true 3' turbo outlet/turbo elbow
I bought the isis true 3' turbo outlet/ or exhaust elbow, just wanted to know, it bring a 5 bolt gasket for the turbo to exhaust elbow. I think i herd that people say there exhaust gasket blow within like a week of use. Just wanted to know if it was true or if i can use the gasket safely ans spend money elsewere in my build. Thanks guys!
S13alldayyo is offline   Reply With Quote
Old 09-03-2013, 09:17 PM   #2
Thomas0zero
Thomas0zero's Avatar
Thomas0zero is an unknown quantity at this point
If its one of those perforated metal gaskets with graphite in the middle, you can bet it wont last long. Now im sure MANY people have had plenty of luck with them, but i personally havent. They dont seal well and if your running a cat or anything that will restrict exhaust flow, theres a good chance it will leak. Now you shouldnt "blow out" an o2 housing gasket unless something is seriously plugged up or loose.
Thomas0zero is offline   Reply With Quote
Old 09-03-2013, 09:34 PM   #3
S13alldayyo
I would post pics but my iphone doesnt allow me, do you recomend a different type of gasket?
Old 09-03-2013, 09:55 PM   #4
s14boy
Trader Rating: (26)
s14boy is an unknown quantity at this point
Feedback Score: 26 reviews
get a metal gasket
s14boy is offline   Reply With Quote
Old 09-03-2013, 10:18 PM   #5
Thomas0zero
honestly, you should have gotten a trusted brand. I purchased my Megan Racing o2 housing from TheNismoShop.com for $115 and its 100% genuine and came with some NICE gaskets. It uses almost identicle gaskets that the Nissan uses.
This is the gasket i would buy. Its identical to the one i got with my Megan Racing part and it seals perfectly.
Nissan Factory JDM 5 Bolt Turbo / Turbine Outlet Gasket 14445-26E00 - Nissan SR20DET T25
I steer clear of products that use these kind of gaskets. If they use cheap gaskets i cant imagine how cheap the part is.
Old 09-03-2013, 11:02 PM   #6
derass
I would get the OE multi layer gasket, do it once, do it right. There are 2 different part numbers for T25 and T28.
Old 09-04-2013, 06:00 AM   #7
Def
Megan Racing a trusted brand now... how things change over the years......
DEFSPORT
Old 09-04-2013, 06:59 AM   #8
Mikester
Mikester's Avatar
Mikester is a well-known jackass
^^LMAO^^
As long as it's a metal gasket, it should be fine if properly torqued.
In this location, a paper/grafoil gasket will blow quickly due to the amount of heat the turbine puts out... which is why even the OEM 5-bolt outlet gasket is metal.
On that note, OEM is the best possible bet.
As for any other gasket in the exhaust system (besides 4-bolt turbine manifold flange), the regular grafoil gaskets are fine so long as the exhaust system is properly hung & secured.
Weird that there are different PN's for the T25/T28 5-bolt gaskets... IIRC, that flange is a standard size. I run the OEM gasket from OEM S13 blacktop rebuild kit with a Tomei M8270- works nicely. Not calling BS, just saying that it's unsurprisingly weird.
Mikester is offline   Reply With Quote
Old 09-04-2013, 10:15 AM   #9
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
Originally Posted by Mikester View Post
^^LMAO^^
There is a slight difference in the location of one of the studs on the t25 vs the t28, you will notice on all aftermarket dump tubes one hole is slightly enlarged/oval'd to accommodate both turbines
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 09-04-2013, 12:08 PM   #10
Mikester
Mikester's Avatar
Learn something new every day
