Old 08-24-2004, 08:11 AM   #1
hotrodv
hotrodv's Avatar
hotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfection
Offset
What you think about this combo? (I cant put over 225 tires front and rear)
gram 57 pro
front 18x8 +22 disk B (about 58mm lip) clear coilocer and fender?
rear 18x9 +15 disk C (about 90.3mm lip) need roll or pull a little?
Thanx everyone!!
hotrodv is offline   Reply With Quote
Old 08-24-2004, 09:33 AM   #2
pruto
pruto's Avatar
pruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to all
how about 18x9, 18x10? =p
Paul
Black and Red
pruto is offline   Reply With Quote
Old 08-24-2004, 10:59 AM   #3
hotrodv
hotrodv's Avatar
Not possible here, only 225 is the f****ing law!!
Old 08-24-2004, 11:09 AM   #4
Levi@GTPRO
Levi@GTPRO's Avatar
Levi@GTPRO is an unknown quantity at this point
Send a message via AIM to Levi@GTPRO
You can fit a 225 on both front and rear. There will be streched just a tad bit. Those specs arent really aggressive you should be fine.
VisitGTPRO!
This post has been brought to you by LAND HO the fresh makers!
Levi@GTPRO is offline   Reply With Quote
Old 08-24-2004, 01:32 PM   #5
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
you can fit 215s on a 10, seemed to go on w/o a problem and it looks sick , so 225s will be fine.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 08-25-2004, 01:45 AM   #6
hotrodv
hotrodv's Avatar
What you think about offset?! is it good?? flush enough? lip enough??
Thanx !!
Old 08-25-2004, 02:20 AM   #7
ElKadetto
ElKadetto's Avatar
ElKadetto is an unknown quantity at this point
Send a message via ICQ to ElKadetto
The offset will be fine. I got 9,5x18 offset 15 around and i just have to roll the rear fender. In the front i use ings wide fenders but it was not necessary
The Stock rim was a 8x18 offset 37 around, with 225 tyres. And i can use 30mm spacers on each rim.
A 22mm offset will clear coil overs.
german S14 board
german S13 board
ElKadetto is offline   Reply With Quote
Old 08-25-2004, 07:43 AM   #8
KiDyNomiTe
KiDyNomiTe's Avatar
The offsets should be fine as long as you don't plan on running a lot of camber, you might want to just get 18x9s all around if you don't want 10s 18x8 just seems kinda small. 18x9 +20 front 18x9 +15 or just 18x9 +15 all around and have the option of rotating your wheels.
PROCEED
Grip Gambler
Old 08-25-2004, 11:26 AM   #9
hotrodv
hotrodv's Avatar
What I look for is also a good look (flush and lip) maybe a 18x8.5 front with + 22 or a 18x8 +18 , for the rear 18x9 +15 I think or is better a + 12??
Old 08-25-2004, 11:28 AM   #10
hotrodv
hotrodv's Avatar
@ elkadetto
I've doing the registration on sxoc.de 2 day ago..only problem don't know germany..so I translate it in english with babelfish..lol
I look for a S14A Zedition in good condition if you know anyone that sell it!!
Old 08-25-2004, 02:49 PM   #11
ElKadetto
ElKadetto's Avatar
You can write in english in the german board. But a Z Edition will be hard to find.
german S14 board
german S13 board
Old 08-26-2004, 03:11 AM   #12
hotrodv
hotrodv's Avatar
Damn!!! 2 week ago I've found one on mobile in Bayreuth, a red one with 70k km.. 10900€ but the shop don't reply to me!!!damn damn!!
Old 08-26-2004, 10:19 PM   #13
Tygma
Tygma's Avatar
Tygma is making a name for him/her selfTygma is making a name for him/her self
theres a fat thread on offsets, search man.
My review forum
Tygma is offline   Reply With Quote
Old 08-27-2004, 02:47 AM   #14
hotrodv
hotrodv's Avatar
I've read about 100 thread about offset but no one delete my doubt 'cause I can't go with bigger tires or rimes, unfortunately..
Now I've deicide..
Just the last thing!! HELP ME
Could a Gram Disck C clear the stock rear caliper?? please help me about this and I can start to sleep well!!!
Old 08-27-2004, 12:38 PM   #15
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
"Could a Gram Disck C clear the stock rear caliper??"
Yes.
Now, get 18x9.5 +12 Front and rear, it will look soooo good. ANd it will fit 225/40/18 NO PROBLEM!! You will have to roll your fenders (Heat gun and large hammer... from the outside in tap the lip flat against the inside of the fender). Remember to remove your fenderlining, that won't be necessary anymore.
And don't worry, it will clear coilovers, too.
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline   Reply With Quote
Old 08-27-2004, 01:53 PM   #16
OptionZero
OptionZero's Avatar
he's in italy, wheel size is limited or something
OptionZero is offline   Reply With Quote
Old 08-27-2004, 04:18 PM   #17
KiDyNomiTe
KiDyNomiTe's Avatar
While your at it do something with your harness on the driver side front fenderwell. I ate throught mine and my car would not turn off if the headlamp fuse was in, good for a laugh but bad for the car (car started with no keys, just turning my headlights on and off).
PROCEED
Grip Gambler
Old 08-28-2004, 06:51 AM   #18
hotrod
hotrod is an unknown quantity at this point
Thanx to everyone!! Our law say that the car can't be larger than original, tires is only the type write on the car book (205/55/16, I try to find the way to put the 225/40/18 but it's hard!!) and lot of other stupid restriction!!
Now I thin to go 8.5 + 18 front (or + 22) and 9 + 12 rear..that will give me good look effecte without problem with police..
hotrod is offline   Reply With Quote
