Old 08-30-2004, 10:46 PM   #1
nd240sx3
nd240sx3's Avatar
nd240sx3 is a well-known jackass
Send a message via AIM to nd240sx3
what the hell should timing be set at ka-t
i know i searched, but all i could find on what i will be using which is 370cc injectors and safc. timeing should be ~16 what the hell is that and what should i put imimg too thanx oh and one more question. when i look up pulley sets for my motor, all i can come up with is 95-98. why is that? i thought they are the same motor which they are so can i use them thanx again 91 s13 hatch
nd240sx3 is offline   Reply With Quote
Old 08-30-2004, 10:57 PM   #2
orion::S14
orion::S14's Avatar
That means base timing should be 16 degrees before top dead center. The retards the whole timing curve by ~4 degrees...which is not ideal, but a cheap way to run boost safely without retuned ECUs or MSD BTM.
The pulley has marks:
-5..0...+5..10..15..20
To set the base timing, car should be warm, and you have to unplug the TPS and set the idle to ~700. Only way to set base timing properly...these steps disable the ECU control and keep it from messing with the timing,
Using the pin near the pulley, set the timing to the intended degree by rotating the distributor.
Stock is 20, so you need to knock is back a few degrees...you have to eyeball it.
That's it, pretty easy.
- Brian
Old 08-30-2004, 10:58 PM   #3
orion::S14
orion::S14's Avatar
Oh...and the pulley's are the same...get an ASP from www.rpmoutlet.com for $100-110.
Old 08-30-2004, 11:01 PM   #4
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
stock is 20?
of all the SRs that i have worked with the base timing is a rough 15BTDC
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline   Reply With Quote
Old 08-30-2004, 11:33 PM   #5
papershot
papershot's Avatar
papershot is an unknown quantity at this point
Send a message via ICQ to papershot Send a message via MSN to papershot
Originally Posted by RedSuns
stock is 20?
ka-t...
message length.
papershot is offline   Reply With Quote
Old 08-31-2004, 12:55 AM   #6
AN89HATCH
AN89HATCH is a well-known jackass
Im also doing a kat (sohc), i set my timing to 14 degrees, but Im only running an 8:1 fmu, fuel pump, and stock injectors , and 6lbs of boost so i needed it to be alittle more safe. When I unpluged my tps, my idle did not change, so i set the timing, and pluged it back in, and my idle stayed the same around 700-730 rpm Is the ka24e stock timing 17 degrees?
slide your ride.com
AN89HATCH is offline   Reply With Quote
Old 08-31-2004, 10:44 AM   #7
orion::S14
orion::S14's Avatar
Stock KA24E timing is 15...plus, the static compresison ratio is lower, so you don't need to drop the base as much to keep it safe.
At 6psi, I'd bet you're OK with just a degree or 2 of base retard (13-14 BTDC)...
- Brian
Old 08-31-2004, 10:21 PM   #8
RedSuns
RedSuns's Avatar
Originally Posted by papershot
ka-t...
message length.
and the KA is that much different from a SR?
base timing is base timing....
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
Old 09-01-2004, 07:16 AM   #9
orion::S14
orion::S14's Avatar
YES!
Base timing is what the ECU uses to determine total timing advance...so if your base timing is off by 5 degrees, you'll either blow it up, or have no power.
Set your SR to 10 BTDC and see if you can make any decent power...even at 14psi.
Set your SR to 20 BTDC base and 14psi and you'll be buying a new block...
Base timing is CRITICAL for decent performance...
...and 1 degree of timing is actually a lot.
- Brian
Old 09-01-2004, 07:16 AM   #10
PSI240SX
PSI240SX is an unknown quantity at this point
Red Suns- You are an idiot. They are two totally different motors, and they use totally different base timing values. Can you not accept that?
SR 15btdc
KA 20btdc
End of discussion.
www.enjukuracing.com
PSI240SX is offline   Reply With Quote
Old 09-01-2004, 10:28 AM   #11
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
SOHC KA = 15ºBTDC
DOHC KA = 20ºBTDC
OT!!
Which leads me to believe that nissan was stupido for building the DOHC engine. They have a claimed 10 horsepower over the SOHC...but if you bumped the compression to what the DOHC has and up the timing 5 degrees, you'll find that extra 10 horses out of the single cam. All they had to do was re-design the cam for better high end.
Hi
Var is offline   Reply With Quote
Old 07-07-2005, 03:50 AM   #12
lrb_2000
lrb_2000 is an unknown quantity at this point
^^ I agree...but from what i've read, the dohc has a stronger bottom end.. but I could be wrong...
lrb_2000 is offline   Reply With Quote
Old 07-07-2005, 04:50 PM   #13
NismoDan
NismoDan's Avatar
NismoDan is an unknown quantity at this point
I heard that the SOHC's had weak heads, and that the threads tend to strip.
Just what I've heard, I'm happy with my DE.
C4L #34
NismoDan is offline   Reply With Quote
Old 07-09-2005, 05:04 PM   #14
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
I have determined that the cam journal is one very delcate part of the head, but regular oil changes will save that. Other than that the head is designed quite well. Intake and Exhaust ports only are already pretty smooth but have two casting lines in them. I believe in the 12valve SOHC and by spring I will get 300+ HP out of it.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 07-14-2005, 10:17 AM   #15
RedSuns
RedSuns's Avatar
SR 15btdc
KA 20btdc
End of discussion.
thanks for the fine comment
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
