17x8 +15 F,18x9 +20 R on s13coupe
My cousin is thinking about ordering a set of work meister s1's in
17x8 +15 front and 17x9 +20 on the rear.Will these wheels go on without no fender rolling/rubbing? and he is running 20mm wider frontfenders.Also he's thinking about getting a tire package so what would be a good size to get without getting too wide that it will rub.He wants the wheels to fit flush as possible without rolling the fenders and minamal/no rubbing Im thinking something along the lines of 225 or 235. thanks
I shatter dreams like Jordan, assault and batter your team |
![]() Join Date: Jul 2003
if he has 20mm wider fenders in front. then i would go with more offset than +15... my guess would be something more like +5 or maybe even 0 offset with a stretched tire and decent amount of camber. as for the rear... +20 on 9inch wide wheel will look weak... def go with +0 or maybe even more... and roll/pull the fender and the obvious stretch tire and neg. camber....
if were my car i would go with 17x9 +0 all around since u have the wider front fenders. then use like a 215/45/17 tire then set up whatever camber u wanna use then pull the fenders acordingly so that it fits like a glove... getting extended studs and dont forget the use of small 5mm spacers isnt bad... small spacers are good tool for clean fitment. just make sure u get extended studs so u have enough thread on the lug nuts. good luck
hi. |
#7 | |
![]() Join Date: Apr 2002
IF he ROLLS the rear fenders he could fit the 17x9 +20 with a 215/45 and about 2-3 degrees of negative camber. IF he still doesn't want to roll the fenders (although there is no reason not too) then 17x9 +25 w/215/45 with 2-3 (maybe more) degrees of negative camber. It will probably be really close though.....
89 S13 hatch/////98 Subaru 2.5RS |
I see now tim, yeah He doesnt want it pulled then ...i was using rolled in terms of pulled.So yeah no pulling of the fenders are wanted.
#11 | |
There are lot of people getting confused lately about pulling/rolling fenders.
#16 |
If the car didn't have the kit I think it would look kinda funny in the rear.
Since you went with wide fenders up front why didn't you go with the 17x10 +12 235/45 all around? That size looks awesome but I think it looks weird when only the rear has the sunken spokes and not the front..... Just my opinion though ![]()
#18 |
![]() Join Date: Oct 2003
17x10 +12 will not clear coilovers in the front, will need to be around 0 offset, at this point car needs to run 4-5 deg of negative camber to get the wheels to fit. Also at full lock and full compression, the wheels are so wide that it'll rub. The white silvia is our wiring guru's(Eric) daily driver.
#19 | |
![]() Join Date: Jan 2003
thats like sying you want to drive around with 1,000hp all the time... sweet specs, yet totally uneccessary |
#20 | |
17x10's in front is overkill...but then it's overkill in the rear as well. Especially since you have to run 235's to make them fit (although with a little more pull you could probably go with wider tires but whatever) I don't know. At this point I think it's all opinionated and more of a appearence issue anyway. But I didn't know that they wouldn't clear the fronts...
