Old 11-01-2013, 02:05 PM   #1
Derko
Derko is an unknown quantity at this point
s13 1991 240sx ka24de brown gunk
my car has been overheating even if i drive for 5 minutes. I checked the cams, and dipstick for white milk shaky fluids hoping its not a blown head gasket. There wasn't any so it seems ok. I try and bleed the cooling system but water wont come out, so I'm guessing the radiator is clogged or the thermostat isn't opening. I took out the radiator and thermostat and find brown gunk in there, and all over the hoses. I'm wondering what is the cause of this and is there any way to fix it?
-Thanks in advance
Thermostat
Where the thermostat sat
Where the 2 Radiator hoses go
Radiator Cap and where it sits
Derko is offline
Old 11-01-2013, 02:19 PM   #2
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
That is called rust. It is the by-product of iron oxidizing...
DUH!!!
Your cooling system looks like that because whoever has owned your car, including yourself, has NOT maintained the cooling system WHATSOEVER. It was probably filled with only water, no coolant. It's been run low on water regularly. Basically your cooling system is fucked up and needs COMPLETE maintenance. Thermostat, radiator, cap, flush system, check hoses and replace as necessary, etc... It is COMPLETELY possible that your headgasket is blown as well. With as shitty as it looks I would be concerned.
racepar1 is offline
Old 11-01-2013, 02:30 PM   #3
Gamma
Gamma is an unknown quantity at this point
Go to Autozone or any parts store and buy a flush system liquid buy 2 hopefully this helps with not overheating tell u gather up some money and buy everything racepar said including a water pump... And feel it up with coolant not water good luck...
The answer is in the math. HP = (TQxRPM)/5252
Gamma is offline
Old 11-01-2013, 03:15 PM   #4
Jesus_lopez405
Jesus_lopez405's Avatar
Jesus_lopez405 is an unknown quantity at this point
Its rust!!
Jesus_lopez405 is offline
Old 11-01-2013, 03:40 PM   #5
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
Yeah rust in the system, and by the look at the engine, looks like nobody tried to maintain it, but I could be wrong.
andisan is offline
Old 11-01-2013, 03:41 PM   #6
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
Looks like rust, so instead of distilled water or coolant, someone probably filled it up with water from a hose which is shitty. I would run flush sluid only, just buy a lot of it and fill the radiator with it, run that for a few months, do it again, run for a few months, then go to coolant with half flush fluid.
That has worked for me quite a bit on a 240 I had a long time ago that was near this bad but depends how much money you want to spend.
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline
Old 11-01-2013, 03:48 PM   #7
IROYLE1
IROYLE1 is an unknown quantity at this point
DUH!!!
Did you really need to go ham on him for this lol
IROYLE1 is offline
Old 11-01-2013, 03:59 PM   #8
Derko
thanks everyone
Derko is offline
Old 11-01-2013, 04:07 PM   #9
racepar1
racepar1's Avatar
You mean for not being able to identify RUST...
...yeah, I did have to...
racepar1 is offline
Old 11-01-2013, 05:30 PM   #10
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
Question answered, thread is now locked!
dorkidori_s13 is offline
brown, gunk, ka24de, radiator, s13
