Old 09-03-2004, 04:35 PM   #1
Will fastback SE
Will fastback SE is an unknown quantity at this point
Send a message via AIM to Will fastback SE
injector resistor box install on 240sx?
Has anyone done this on their KA? I couldnt find enough of the individual 10ohm, 10watt resistors so I took the route suggested by several performance shops= install a resistor box from a honda. I have already mounted it and ran the 4 injector wires (output) to the power side of the injectors. What is left is wiring the last wire (input). According to the person i bought it from, that input wire is supposed to go where the plug is that splits the single injector wire into 4. Anyone know where that is? If you have done it before, please share, i need to get my damn car running. By the way, the reason I am doing this is because I have top feed 50lb injectors which are low inpedance and the stock injectors are high impedance
Donations for MORE boost accepted here
Will fastback SE is offline   Reply With Quote
Old 09-03-2004, 11:52 PM   #2
Powashiftin
Powashiftin is an unknown quantity at this point
I would like to know this as well.
also, which top feed fuel rail are you using?
http://www.tempusband.com
Powashiftin is offline   Reply With Quote
Old 09-04-2004, 02:00 AM   #3
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
just test the box with a multimeter and see if you have the right resistance. It's rather easy.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
