Old 11-08-2013, 10:59 PM   #1
shomo172
shomo172's Avatar
shomo172 is an unknown quantity at this point
Altima fan question
A friend of mine is giving me some Altima fans, but I've yet to look at these fans before so I'm not sure how they're wired and what not. Just want to get a basic idea. I really know nothing about wiring fans so any help is appreciated.
The previous owner of my car put really cheap ebay fans on my car which stopped working, but he did a good job wiring them with the relay and what not. Is it a simple task to just keep the Altima fans on high, wired exactly the same as my cheap ebay fans? Can I just cut the wires from the ebay fans and rewire them to the Altima fans with little work involved? Newbie question, but I'd appreciate the help.
Thanks in advance.
shomo172 is offline   Reply With Quote
Old 11-09-2013, 12:16 AM   #2
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
Searching can answer all your questions in much more detail than any of us wish to repeat. It has all been covered in great detail because this is an extremely popular swap.
If you can't find it here try Google.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 11-09-2013, 12:20 AM   #3
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
There are a number of write ups. Some keep the fan on high. Others use a thermo switch to kick on high. A good search on here and google will give you lets of information.
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 11-09-2013, 12:38 AM   #4
zerodameaon
I guess Google won't answer your question about the relay setup of the ebay junk. If it is sufficient to power the Altima fans which draw 30 amps and you are happy with how it is set up you can wire them into that setup. If you are not sure if the system can support the fans then it is best to rip it all out and wire it up with one of the many other choices out there.
Old 11-09-2013, 08:38 AM   #5
shomo172
shomo172's Avatar
Thanks. I've been searching but all the write ups I've been finding are wired up differently and I couldn't find a specific answer to my question, which is why I posted here in the first place. Was looking for someone who had a good knowledge of the subject matter and could tell me if it's enough power for the Altima fans.
Old 11-09-2013, 09:07 AM   #6
cotbu
cotbu's Avatar
There's really not enough info, for anyone to really suggest anything better than what was previously posted. Like are the fans always on? What gauge wire do you have, are there 2 relays, etc. Wiring them up to be on high only, is just a matter of finding the correct wires, having functional or wired correctly cooling fans is a different story, add In a redundancy and or failsafe well it get difficult quick. Just be specific about what it is you want.
Sent from my Highly Tune Galaxy S3.4!!!
