Old 09-05-2004, 09:48 PM   #1
Nissandriver714
Nissandriver714 is an unknown quantity at this point
Open atm BOV
My sr's stock bov's recirculated pipe (underneath stock intake) was disconnected, meaning it was basically kinda like an open atmospheric BOV. It did cause my car to run idle/run rich, but from butt dyno, somehow it feels much faster and there's less lag. When I shift, there was no hesitation either. This suprised me, could it be that I'm running lean right now and there's not enough fuel, but when it's open atmospheric, there's extra fuel so it makes my car faster? Here's my setup:
redtop sr, upgraded t28/t3 turbo, with .86 turbine housing, HKS actuator, full 3" exhaust, walboro fuel pump, running stock injectors, HKS actuator set around 11-12 psi. It's probably making around 250-260 flywheel. Am I maxing out my injectors? Your thoughts?
Nissandriver714 is offline   Reply With Quote
Old 09-06-2004, 03:00 PM   #2
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
If the recirc. pipe was disconnected then the intake pipe would have to be capped right after the maf or else that would be an intake leak. This would cause a lean condition since the maf wouldn't read the air.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
