Old 11-19-2013, 05:28 PM   #1
xninjaxkirbyx
xninjaxkirbyx is an unknown quantity at this point
paint job
hello folks. so i need a paint job on my car and i need to have my lip kit installed so i went over to a shop the other day to get a price. they said it would cost $4500 to paint the whole car the same color and to install the kit. is that normal price? i always thought a good paint job would only cost around like $2000.
xninjaxkirbyx is offline   Reply With Quote
Old 11-19-2013, 05:44 PM   #2
silviaks2nr
silviaks2nr's Avatar
i'm sure it's been said a zillion times... but you really do get what you pay for when it comes to paint and body... for $4500 i would expect the door jams and shut lines to be sprayed as well though.
Old 11-19-2013, 05:52 PM   #3
rellik27
rellik27 is an unknown quantity at this point
for that price by the paint and compressor yourself and learn something new. plus you will have a lot of money left over.
rellik27 is offline   Reply With Quote
Old 11-19-2013, 06:02 PM   #4
Dublj
Dublj's Avatar
Dublj is an unknown quantity at this point
To build a temporary booth and buy supplies and tools your looking to spend around 3000 plus stripping the car and changing color is time consuming your better of finding someone that does it on the side that knows what they are doing
Sent from my SM-N900R4 using Tapatalk
Dublj is offline   Reply With Quote
Old 11-19-2013, 09:33 PM   #5
crzsteveo
crzsteveo is an unknown quantity at this point
^or find a friend with a garage, put plastic sheets up.
crzsteveo is offline   Reply With Quote
Old 11-19-2013, 11:23 PM   #6
InsTanCeZ
InsTanCeZ's Avatar
InsTanCeZ is an unknown quantity at this point
Screw that, go get a paint job for $500, go drifting, blow up body kits, repeat. Unless you're building a show car people won't notice a difference unless they walk up 5 feet from your car. 240sx itself costs $4500. Personally I would never spend that much on paint unless it was purely a show car.
ACE マジック HEART
InsTanCeZ is offline   Reply With Quote
Old 11-20-2013, 01:08 AM   #7
Slippin'eight-nine
Slippin'eight-nine's Avatar
Slippin'eight-nine is an unknown quantity at this point
Sounds about right. Most shops around here said they wouldnt touch my car for less than 5k. They said it was close to 2500 in materials alone. Keep in mind thats for a complete color change. My calabash uncle owns a shop and he quoted me 3k for a same color respray.
Project cars: "Fail to plan, plan to fail"
Slippin'eight-nine is offline   Reply With Quote
Old 11-20-2013, 01:11 AM   #8
Dublj
Dublj's Avatar
You could always plastidip it covers flaws in the body any it's a lot less labor and cheap
Old 11-20-2013, 09:24 AM   #9
blkvrtswp
blkvrtswp's Avatar
blkvrtswp is an unknown quantity at this point
100% agree with this: "stripping the car and changing color is time consuming" - it took me 3x the hours I planned on.
But I setup a paint booth in my parents garage (total cost $65), bought a used compressor and cheap stuff form Harbor Freight and TCI Global and my total cost for full color change is currently sitting at $1000. Cheap HF gun works fine but wastes paint. I bought low cost paint from The Coating Store and it has been great too. Certainly not for everyone though due to the time and space needed.
blkvrtswp is offline   Reply With Quote
Old 11-20-2013, 09:51 AM   #10
silviaks2nr
It's possible to do an inexpensive but good job if you don't count your time as $$$. I painted my car outside, spent about $500 in materials using a decent production type paint system. I've painted half a dozen other cars this way with similar results.
4 years later
Check the "DIY paint and body thread"
http://www.southernpolyurethanes.com...ct%20paint.htm
Old 11-20-2013, 10:03 AM   #11
ReLiC
ReLiC is an unknown quantity at this point
4 years later
Perfect Paint Job
You didn't put a top on your paint booth?
ReLiC is offline   Reply With Quote
Old 11-20-2013, 10:09 AM   #12
silviaks2nr
There was no back or roof because I needed some ventilation. base/clear is forgiving enough that you can sand out most if not all trash that gets embedded in the clear.
here's another ghetto spray booth I've used
http://zilvia.net/f/builds-builds-on...r-project.html
Old 11-20-2013, 10:12 AM   #13
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
Those are great results... luckily my uncle owns a body shop and I can just use it whenever.
Originally Posted by Hoffman5982 View Post
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
Old 11-20-2013, 10:15 AM   #14
silviaks2nr
I'm building a paint booth at my new house/garage and can't wait to never deal with poly sheeting, wind, and no ventilation again haha.
Old 11-20-2013, 12:17 PM   #15
xninjaxkirbyx
thanks for the reply guys. i really wanted to try to paint the car myself as a project because this was suppose to be my project car. only problem is my garage is packed with junk so i dont have a location. i guess i will try to find someone cheap. im not going to do a color change and im not rich enough to make this a show car.
Old 11-20-2013, 01:51 PM   #16
erik05v
erik05v is an unknown quantity at this point
come by my shop im in rancho ill help you out. 10611 Fulton Ct Rancho Cucamonga CA 91730...check out my work on instagram erik05v
erik05v is offline   Reply With Quote
Old 11-20-2013, 01:53 PM   #17
crzsteveo
well if a project car might as well learn to paint on it. ive only spent about 300 for paint and all the supplies need to paint a car.
I used automotivetouchuppaint.com they have all the listings of OEM paint from all the years that 240s were made. so far the paint is holding up to cracks and rock chips
Old 11-20-2013, 03:13 PM   #18
xninjaxkirbyx
just texted you.
Old 11-20-2013, 03:14 PM   #19
xninjaxkirbyx
thanks for the info. i would totally love to paint my own car but i just dont have a place to do it. i wish my garage wasnt full of junk.
Old 11-20-2013, 03:34 PM   #20
OutlawLui
OutlawLui's Avatar
OutlawLui is a well-known jackass
uh oh.....Better Get Maaco!
OutlawLui is offline   Reply With Quote
Old 11-20-2013, 03:57 PM   #21
RedSiBaron
RedSiBaron is an unknown quantity at this point
First thing i did when i bought the car, well i fixed mechanical stuff to make it drive first, but this at most cost me $500. The success is all in the prep work.
RedSiBaron is offline   Reply With Quote
Old 11-20-2013, 06:29 PM   #22
InsTanCeZ
InsTanCeZ's Avatar
Maaco FTW. Who cares how good your paint job is? Color is color.
ACE マジック HEART
Old 11-20-2013, 09:27 PM   #23
silviaks2nr
Real people care.
Old 11-20-2013, 10:16 PM   #24
mechanicalmoron
Who cares how good anything is, as long as it exists.
You sir, suck dick at life.
Old 11-20-2013, 10:33 PM   #25
DJ-of-E
DJ-of-E's Avatar
DJ-of-E is an unknown quantity at this point
Say that to the guys who owns Datsun 510s or 240zs.
Personally I would pay that much for a paint job / color change as I care about my 240sx enough. At least it's better than seeing every other primered/crappy paint/mix panel color 240sx I'm seeing at the street.
Originally Posted by ocn View Post
its not "DRIFT" tax its a "IDIOT" tax Period!
DJ-of-E is offline   Reply With Quote
Old 11-21-2013, 12:54 AM   #26
InsTanCeZ
InsTanCeZ's Avatar
Was that really necessary? I've seen "real" paint jobs and Maaco paint jobs next to each other and couldn't tell any difference. I don't see why anyone would ever spend $4500 on paint unless they're building a trailer queen show car. Makes no sense.
ACE マジック HEART
Old 11-21-2013, 08:47 AM   #27
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
Agreed, there is an entire thread dedicated to MACCO paint jobs. Some are terrible, some are good, and some are great. Like everyone says it depends on the prep work and also choosing a good painter. SILVIAK's car looks great in every single picture of I have seen. The blue Kouki he painted also looks great so as you can see you dont need to spend $4k+ if you have the time and do the research. I wanted to have my Zenki painted LM2 and the shops here in NY are quoting me $4k+ and my car is in very good shape, no damage, no major scratches. Fuck that.....I will give body work and paint a try. At the very least I will give the body work a shot and take it to a painter for them to spray in a booth.
2muchboost is offline   Reply With Quote
Old 11-21-2013, 09:41 AM   #28
justindee88
justindee88 is an unknown quantity at this point
You get what you pay for! If you're going to do it yourself take the time and get VERYYYY familiar with a board file. A little trick that's good to use when starting out is to lightly mist some rattle can black over the entire car and sand it using a board file to find all your high/low spots. Prep work plays a major roll.
justindee88 is offline   Reply With Quote
Old 11-21-2013, 09:47 AM   #29
sleepyS14se
sleepyS14se's Avatar
sleepyS14se is an unknown quantity at this point
4 years later
Perfect Paint Job
this is exactly how we paint our cars and it works out great!
the whole ghettoness of it makes it even more worthwhile because the results are usually so damn good it is a rewarding feeling i guess lol.
95 S14 se RB25DET 348whp
sleepyS14se is offline   Reply With Quote
Old 11-21-2013, 10:46 AM   #30
xninjaxkirbyx
i am envious of all those who painted their own cars and it came out great. that is something to be proud of. sure does save a lot of money too.
