Old 09-07-2004, 03:15 PM   #1
DRO916
DRO916 is an unknown quantity at this point
Send a message via AIM to DRO916 Send a message via Yahoo to DRO916
power door locks
not sure if i should call it power door locks, or some kind of actuator, but i remember on my LE when i opened the lock or locked it on my side of the door, it would do the same to the pass. side, but on my SE, no avail. so how can i fix this...also, will keyless entry work, or will there have to be some custom work....thanks in advance all
DRO916 is offline   Reply With Quote
Old 09-07-2004, 05:17 PM   #2
projectRDM
projectRDM's Avatar
What year is your car?
The 89-90 S13s used a 2-wire negative trigger door lock circuit, the timer is in the passenger kick panel, wires are IIRC gray/red and gray/blue.
91-94 cars use a single wire sytem, the wire is orange/blue.
S14s use the same 2-wire negative, colors are brown and light green/white.
Keyless can be added to any car with OE power locks.
FORMERLY R240NA
Old 09-07-2004, 06:01 PM   #3
DRO916
sorry, 93' SE HICAS, but thanks for the info...
OE power door locks? would you consider what my car has as powerdoor locks?
Old 09-07-2004, 08:40 PM   #4
projectRDM
projectRDM's Avatar
If you lock one and the other does too, that's power locks.
The single wire system only does it from the driverside IIRC, or something weird like that.
FORMERLY R240NA
