Old 09-07-2004, 10:43 PM   #1
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
KA Throttle Body
I got a 91 240sx and decided to clean the throttle body. I took it apart and one of the coolant lines that goes to the throttle body cracked. So i just decided to bypass the coolant from the throttle body. Then i found this other small hose. It has about a 5mm opening that goes to the throttle body. It is inbetween the coolant inlet and outlet on the throttlebody. Anyone know what that line goes to? It didn't have any clamps so i was thinking it is a vacuum line. I didn't connect it back and later I got a CEL. Don't know if it is related but it read EGR code 32. Also is there a throttle body gasket because i just used the liquid stuff.
Jung918 is offline   Reply With Quote
Old 09-07-2004, 10:55 PM   #2
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
exhaust gas recirculation, look around your exhaust manifold for where it goes
wootwoot is offline   Reply With Quote
Old 09-07-2004, 10:56 PM   #3
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
there IS a throttle body gasket. DO NOT use the liquid stuff. The other hose is vacuum. The coolant lines you don't need to worry about. I have mine bypassed too.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
Old 09-08-2004, 06:29 AM   #4
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
why bypass the coolant lines, whats the point of having them there in the first place then?
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 09-08-2004, 08:05 AM   #5
orion::S14
orion::S14's Avatar
^^^ To keep the throttle from freezing and sticking open while driving in really cold climates...
Not and issue down here in FL, maybe it is where he's from in CA...?
- Brian
Old 09-08-2004, 09:11 AM   #6
twitchy
twitchy's Avatar
maybe where im from in northern ontario, driving in minus 40 degrees (same farenheit as celsius) in a blizzaard----ill keep mine.
