Old 09-07-2004, 11:27 PM   #1
kandyflip445
kandyflip445's Avatar
Lightbulb Stillen Pop Filter/Charger (or whatever they call it)
My car came with it and no upper airbox with the lower airbox intact. Occasionally when coming to a stop my car would bog down/try to die on me, usually after I had cleaned my air filter. Sometimes repositioning it would help. There was no bracket included with it so it sat on top of a foam block for the longest of times. So one day while servicing my car I started it without the air filter on (it was drying) to check for oil leaks (just changed the oil). I noticed that the engine wouldn't hold at idle for shit and it kinda puzzled me. I turned it off installed the filter and started again and had the same problem. So, I left it on and walked to the front and lifted the intake up a little out of the engine bay and it idled like a rock, stuck it back where is was and it started like crap again. The turbulence caused by the clutch fan was interfering with the intake so now I have a plate/wall built around it. Idles great now and when the car was warm before (fan spinning) in lower gears it would surge in the lower rpms. Now it's gone.
Cliff notes:
- Stillen Pop Charger w/K&N filter
- Bad Idle/Driveability
- Build a wall around the filter element seperating the filter from the airflow from the radiator clutch fan
My 240 vBgarage
Old 09-08-2004, 01:17 AM   #2
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
Very good. I had the same problem and did pretty much the same thing.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 09-08-2004, 08:29 AM   #3
projectRDM
projectRDM's Avatar
You could have also ordered the bracket for like $25 from Stillen.
FORMERLY R240NA
Old 09-08-2004, 01:00 PM   #4
kandyflip445
And there still would have been air turbulence.
My 240 vBgarage
Old 09-08-2004, 02:00 PM   #5
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
I just got rid of my clutch fan.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
Old 09-08-2004, 02:58 PM   #6
projectRDM
projectRDM's Avatar
Worked fine on my old S14 for 2 years.
FORMERLY R240NA
Old 09-08-2004, 04:00 PM   #7
kandyflip445
Dunno if it makes a difference but mine is a s13.
My 240 vBgarage
