Old 11-27-2013, 01:00 AM   #2731
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
Currently I am unable to go to my S14 but does anyone know the length from the hub to the fenders in the rear?
Pretty sure its 5.15in but not 100% sure. Would be great if someone can look.
Working on a calculator for wheel size for the S14 and if anyone has the info for S13, could do that too.
thank you.
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline   Reply With Quote
Old 11-27-2013, 10:38 PM   #2732
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Originally Posted by jaaanrel View Post
looking to get some mustang sc reps for my hatch. what has to be done to fit 17x10's +25 all around? or 17x10 +25 rear and 17x9 +22 front? thanks
17x10 +25...you'll need spacers up front to clear suspension.
CLICK HERE!!!
Old 11-29-2013, 02:02 PM   #2733
badass8
badass8 is an unknown quantity at this point
So I have been searching for a good fitment and function for front wheels, for drifting.
I have been looking to upgrade my stock 15's I would like more grip and tire up front and something that looks a little better as well.
My eye is on the xxr 527 I know everyone has these but they are pretty cheap and they don't really look that bad.
The size I was looking at was 17x8.25 +25 I would like the offset at about +10 for these wheels but I have yet to find them.
I am also running this setup at the moment if that makes a difference:
PBM coils
s14 FLCA
s13 modded knuckles
tein inner tie rods
SPL tie rod ends
So my question is how well will these fit and should I change my route for a better front wheel size for drifting?
Sorry for the noobness I am researching as I go along.
badass8 is offline   Reply With Quote
Old 11-30-2013, 05:35 AM   #2734
Rich260z
Rich260z is an unknown quantity at this point
They'll look a hell of a lot better than stock, but don't expect perfect flushness. You might consider running a 7 or 10mm spacer also.
Rich260z is offline   Reply With Quote
Old 11-30-2013, 08:31 AM   #2735
Black R
Black R's Avatar
Black R is an unknown quantity at this point
PBM coils
s14 FLCA
s13 modded knuckles
tein inner tie rods
SPL tie rod ends
That sounds like a horrible size.
At least go 9" wide on a 17" rim - at least!
If you're only going 8" wide, then you can do 16x8 rota grid offroad in et+20 or et +10.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers
Black R is offline   Reply With Quote
Old 11-30-2013, 09:51 AM   #2736
KravingAKouki
KravingAKouki is an unknown quantity at this point
Originally Posted by KravingAKouki View Post
Would an 18x9 +15 squared setup for an s14 require any roll or pull of fenders if I were to have it flush with the metal? No tucking. If not, what sizes would work without having to roll and pull? Going to be buying FA 500, or stance coils if that matters. Preferred not to have spacers also. Thanks for the help guys
Anybody? Would a +15 be enough or would I need more positive offset like +18?
KravingAKouki is offline   Reply With Quote
Old 11-30-2013, 11:04 PM   #2737
Black R
Black R's Avatar
^ this guy is right.
It will probably require a 15mm spacer with approximately 3deg of negative camber.
Old 12-01-2013, 07:11 AM   #2738
Sileighty_85
Sileighty_85's Avatar
Just picked it up, How do I get this to fit on my R32???
lol
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-01-2013, 08:36 AM   #2739
tauntdevil
tauntdevil's Avatar
You will need to convert your R32 into a single bolt hub like an indy car xD.
Old 12-01-2013, 09:57 AM   #2740
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
Forgeline has conversion kits but its gonna cost major$$$$
WARNING: User has a low tolerance for stupidity. Post at your own risk.
redline racer510 is offline   Reply With Quote
Old 12-02-2013, 09:22 PM   #2741
MeGusta
MeGusta's Avatar
MeGusta is an unknown quantity at this point
18x10.5 +20 all around on s14 with coil overs
how much damage am i looking at to make them fit in the front?
pro's , con's of a x10.5+20 in front
MeGusta is offline   Reply With Quote
Old 12-03-2013, 10:01 AM   #2742
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Cons? Good luck turning and say good bye to full lock with stock inner fenders. Tubs or it will never happen. Camber and thin tires will not help you out either.
Pro's? There are none, 10" is the widest you will ever need or want to run on a S-chassis. Hacking and making more space isn't ideal and I don't see why people purposely do it.
For Sale #1 | For Sale #2
zooopreme is offline   Reply With Quote
Old 12-03-2013, 10:48 AM   #2743
fliprayzin240sx
Flush and not rolling the fender is dumb. I guess you'd like your tires to catch your front fender and rip the shit out of it. Rolling fenders is a MUST do unless you're running stock ride height with 9j rims. Roll the fenders, doesnt matter which offset you choose, 3mm difference is negligible. Your alignment/camber will make more difference on your fitment than offset between 15 and 18mm.
lol
You making a coffee table?!?!
This...wider the rims, the wider the tires you'd have to run, which in turn makes your fitment tighter than it already is.
CLICK HERE!!!
Old 12-03-2013, 05:26 PM   #2744
Sileighty_85
haha yeah its a Monolug so cant really do anything else with it.
Thought it would be cool for the Man cave
後輪駆動車1番
1986 SR86 - 200ish
Old 12-04-2013, 02:27 PM   #2745
KravingAKouki
Thanks Flip for dealing with my noobness. Haha I appreciate it man
Old 12-05-2013, 05:11 PM   #2746
Fearell
Fearell's Avatar
Fearell is an unknown quantity at this point
I have 18x10+13 wheels. I usually run 225/40/18's but got some 235/40's for cheap. How much of a difference will there be? Will I need to totally change my setup or will it not change much? This is on the rear of my S13 coupe.
IG: slideonkranze
Fearell is offline   Reply With Quote
Old 12-05-2013, 09:27 PM   #2747
SlidewayZ S14
SlidewayZ S14 is an unknown quantity at this point
hey guys if I can get some input asap.. s14 with kyb shocks, eibach springs. wondering wat will need to be done if anything to fit volk GTV 18x9 +17, 18x10+ 17
thanks
SlidewayZ S14 is offline   Reply With Quote
Old 12-05-2013, 09:48 PM   #2748
InsTanCeZ
InsTanCeZ's Avatar
InsTanCeZ is an unknown quantity at this point
Roll fenders at the least. Maybe a pull (optional, depends on tire size as well).
ACE マジック HEART
InsTanCeZ is offline   Reply With Quote
Old 12-10-2013, 09:21 AM   #2749
acslater9
acslater9's Avatar
acslater9 is an unknown quantity at this point
What tire size would be good for a r32 gts-t? I will be putting these on my s13.
specs:
diameter = 16"
bolt pattern = 5x114.3mm
offset = +40
width = 6.5"
center bore = 66.1mm
acslater9 is offline   Reply With Quote
Old 12-10-2013, 10:23 AM   #2750
zooopreme
Trader Rating: (38)
What type of fitment are you looking for? Your choices are virtually endless depending on what you want out of your fitment.
If you're planning on lowering the car and don't want that battle ship look: 30mm.
If you're on stock strut style, 15mm for the fronts, 17-20mm in the rear.
If you have money for better sized wheels for the S13, ditch the R32 wheels.
Old 12-10-2013, 11:22 AM   #2751
fliprayzin240sx
R32 GTS-T wheels...same specs as S14 SE.Z32 NA wheels but cost more due to the bling factor.
CLICK HERE!!!
Old 12-10-2013, 03:30 PM   #2752
acslater9
acslater9's Avatar
Well my car is straight up stock as of right now including my coils. So should I go with 195/65/R15? Really don't know that much about tires so tell me if that's good enough.
Old 12-10-2013, 05:22 PM   #2753
zooopreme
Trader Rating: (38)
Oh shoot, I just realized your question wasn't about spacers but about tire size. I thought you were looking for spacer size. My bad lol
Well, stock sizing for S14 wheels are about the same as R32 wheels like Flip mentioned in his post so that would be 195/55/16 (I believe or 205/50/16) so I would follow that. If you want to be relatively low, you'll need to not run stock balloon sizes. Decreasing the sidewall profile works but 16" just suck period. You may as well go with 17's, better selection for tires.
But anyway, back to my initial post, because the sizing is similar to S14 SE wheels, if you plan on going low, you will need spacers for which you can refer back to my initial post.
Old 12-12-2013, 08:51 AM   #2754
acslater9
acslater9's Avatar
Ended up getting Z32 wheels over the Gts-t wheels because the guy didn't respond to me. Anyways these are way cleaner the guy powder coated a nice grayish color on all 4 of them and I bought them for $150!
I have a question though the tire size on the rims are 225/50R16. Are they going to look too big on my s13? I'm riding with stock coils. Should I drop down to maybe 205? Thanks
Old 12-12-2013, 11:40 AM   #2755
DialedLife
DialedLife is an unknown quantity at this point
225/50 would look like a balloon. I would do 195/50. Or like you said, even 205/50 would look much better.
DialedLife is offline   Reply With Quote
Old 12-12-2013, 12:22 PM   #2756
Maiku240sxS14
Trader Rating: (37)
Maiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enough
Feedback Score: 37 reviews
I believe this is the correct thread to post my question.....
How much negative camber do the rear wheels become when under load?
Maiku240sxS14 is offline   Reply With Quote
Old 12-12-2013, 12:29 PM   #2757
InsTanCeZ
InsTanCeZ's Avatar
That's nearly impossible to answer. Way too many variables.
ACE マジック HEART
Old 12-16-2013, 08:24 PM   #2758
vJilly
vJilly's Avatar
vJilly is an unknown quantity at this point
which it would fit better and or not rub? 18x9.5 +15 or +23? s14 with coilovers.
vJilly is offline   Reply With Quote
Old 12-16-2013, 08:50 PM   #2759
fliprayzin240sx
+23 may or may not rub your coilover up front. I'd say +15 just to be on the safe side as far as clearance.
CLICK HERE!!!
Old 12-16-2013, 10:53 PM   #2760
vJilly
vJilly's Avatar
i could be half retarded or tired as shit considering i have exams tomorrow. so youre saying +15 def will NOT rub my fronts?
