Old 09-09-2004, 02:23 PM   #1
qvester
qvester is an unknown quantity at this point
SR Normal Operating Temp?
what is a normal coolant temprature for a redtop mine runs at about 210 is that too hot or what just wondering try to find out couldn't find anything about it ....thanx
qvester is offline   Reply With Quote
Old 09-09-2004, 04:19 PM   #2
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
my sr making 316 whp never goes over 195 degree, it is with cheapo electric fans and ka radiator with no shroud, ...now when i turno on the a/c thats another story . Normal operating temp is 180 - 210
ANTI-STRETCH NAZI
Vortech Supercharged Vh45de S14 V8nissans.com
gsracer is offline   Reply With Quote
Old 09-09-2004, 07:58 PM   #3
projectRDM
projectRDM's Avatar
Normal temp is 180-190, thermostat opens at 170. OE fan kicks on at 203, so 210 isn't unreasonably high, but you should verify the cooling system's components anyway. Engine starts to bog a little by 215, serious damage to hoses by 245 or so. Any more than that and the head gasket is gone.
FORMERLY R240NA
Old 09-09-2004, 11:49 PM   #4
qvester
i have stock ka radiator with just a electric fan on it no a/c hmmmm 210 doens't sound so good i use to ahve the stock sr fan on the motor with an electric fan but the fan clutch on the motor went out so i took it off should i put it back on? or is those temps too high? i have front mount no real mods done boost controler runnign 240whp let me know thanx...
Old 09-10-2004, 12:33 AM   #5
Johny5
Johny5's Avatar
haha, mine runs at 158F with koyo 2 row, nismo thermostat, nismo rad cap, 30/70 coolant water mixture and a 1/4 bottle of water wetter with oem clutch fan and e-fan. will this damage my engine over time being that its not operating at the right temp?
www.stewartleask.com
Johny5 is offline   Reply With Quote
Old 09-10-2004, 01:28 AM   #6
Bradman123
Bradman123 is an unknown quantity at this point
hmmm what if i dont have a actual water temp gauge but have the stock in dash gauge, where should my sr be running at..koyo radiator with flex a lite 14" fan...tonight it was running hot a couple times. about 2nd notch from HOT mark on the gauge. but when its warmed up and only driving for a while or on the high way its about 1/4 the way maybe a little more up the gauge.
Bradman123 is offline   Reply With Quote
Old 09-10-2004, 07:59 AM   #7
qvester
so with what i have would 210 be too high to run i just got done driving back from flordia 11hrs staight at average of 90mph at it stayed right around 190-210 so just wondering if that was bad or not and now that i don't have th clutch fan on anymore i am wondering if the temp will go up more but i dont' have a electric fan........
Old 09-10-2004, 09:15 AM   #8
projectRDM
projectRDM's Avatar
Johnny5- 158 isn't terribly bad, but in colder weather it may drop more, anything below say 140 and the ring/piston and cylinder tolerances are a little off because they're not up to operating temperature, which will cause a lot more blowby than normal.
Bradman123- the OE gauge is known for it's inaccuracy, middle way on the gauge is anywhere from 160-230, it won't show hot until you're already boiling off water. Get a real gauge to insure you don't damage something.
qvester- after a run down the freeway you should have seen cooler temps, double check the cooling system for air pockets or worn parts, unless you were running in a lower gears, turning more rpms, you should have been running about 185-190.
FORMERLY R240NA
Old 09-10-2004, 03:07 PM   #9
Johny5
Johny5's Avatar
russ, then would an oil catch can be a decent investment for me? i'd like to keep the blowby from going back into the intake if at all possible unless we're talking about the kind of blowby that gets burned up in the exhaust system?
Old 09-10-2004, 05:29 PM   #10
qvester
how do you check the system for air pockets? is there an easy way cause that would be a possiblity cause i lost some coolant when i isntalled my temp gauge and i then just toppped it off so i guess there would be a possibility let me know thanx.
Old 09-11-2004, 12:54 PM   #11
projectRDM
projectRDM's Avatar
Johny5- definitely invest in a catch can, you don't want the excess feeding back through and sludging up the intake. At least leave the port vented to atmosphere if nothing else, the more of that crap you pull in the quicker the manifold gums up.
qvester- jack the front end of the car up, high, run it, and crack the bleeder bolt. You should easily see air bubbles bleed out, check the fluid level periodically and add when required.
FORMERLY R240NA
Old 09-11-2004, 02:35 PM   #12
Bradman123
well my other guages are autometer sport comp, so i spose i would get one to match, how do those hook up. some how tap off the factory sender?
Old 09-11-2004, 06:39 PM   #13
Johny5
Johny5's Avatar
for what water temp? the best investment is the greddy upper rad hose adapter...
http://www.projectnissan.com/Product...&idproduct=566
greddy makes killer accessories for the gauges, probably gonna pick up and oil press and an oil filter sandwich to top off the line of crap on top of my dash.
hey russ, i was looking into catch cans and i like the design idea of cusco but they only make an s13 kit, will this fit s14? thanks again man!
Old 09-11-2004, 07:27 PM   #14
projectRDM
projectRDM's Avatar
Bradman123- most aftermarket gauges senders can be fitted in the spot for the OE gauge, no need to use a hose adapter.
Johny5- depends on where you mount the can, but any universal can with 15mm hose will work fine.
FORMERLY R240NA
Old 09-12-2004, 09:59 PM   #15
Bradman123
what size is the upper radiator hose on the sr? so i can get the right adapter size. i cant even see where the factory sensor even is on the thermostat housing to tap into it there or i would, it would look cleaner.
Old 09-12-2004, 10:01 PM   #16
Bradman123
my sr has a factory oil catch can, or you guys talking about something different.
Old 09-13-2004, 12:02 AM   #17
Johny5
Johny5's Avatar
your factory sensor location is at the front of the motor, above the upper rad hose water neck. it is hidden beneath two big plugs on my s14a iirc.
Old 09-13-2004, 06:49 AM   #18
Bradman123
and if im unable to tap into the factory sensor location what size greddy adapter do i buy?
Old 09-13-2004, 11:20 AM   #19
msaskin
msaskin is an unknown quantity at this point
Send a message via AIM to msaskin
Shoot me a PM...I've got one for sale
~matt
it's not turbo lag...it's foreplay
'01 Ford Excursion Limited.
Powerstroke Diesel
Coming in spring: ???
msaskin is offline   Reply With Quote
