Old 09-09-2004, 05:19 PM   #1
vanquish2
vanquish2 is an unknown quantity at this point
Send a message via AIM to vanquish2
s13 Do you really need dampening adj. for drag?
That's basically my question. I am under the impression that if the car is strictly for drag...then spring rate is most important....as long as it's a good shock...I'm considering either the nismo coilovers or the tanabe s-oc type II's...that way I can customize the spring rate by changing the spring if I need too. What are your guys thoughts?
[email protected]
www.VanquishMotorSports.net
92 S13 SR20det
338whp
1.55 60'
11.87@114
vanquish2 is offline   Reply With Quote
Old 09-09-2004, 06:59 PM   #2
kidinthehall
kidinthehall's Avatar
kidinthehall is an unknown quantity at this point
if your primary interest is drag racing, the last thing you need to spend money on is coilovers. people have been in the 1.40-1.50 60ft range with STOCK shocks.
Softer=Better
90 S13:............fitter, happier, more productive.
04 Yamaha R1: 210rwhp on gas/161rwhp on motor
kidinthehall is offline   Reply With Quote
Old 09-11-2004, 09:02 AM   #3
vanquish2
so your saying that spring rate is everything??? what spring rate would you recommend?
[email protected]
92 S13 SR20det
338whp
1.55 60'
11.87@114
Old 09-11-2004, 12:40 PM   #4
kandyflip445
kandyflip445's Avatar
Your stock springs.....
My 240 vBgarage
Old 09-11-2004, 12:42 PM   #5
Var
Var's Avatar
Send a message via AIM to Var
can you please give us a general idea of how much power and traction you have, and what your estimated et's will be
Hi
Old 09-11-2004, 01:26 PM   #6
vanquish2
OK.....basically stock sr with 3" exhaust turbo back 11lb' boost...probably about 210 at the wheels...best time is a 13.7 at 99....lots of wheel spin because I have to use crap tires....if I use sticky tires I wheel hop...sportline springs, stock shocks, sub-frame spacers...what is my best bet to be able to put the power to the track?
[email protected]
92 S13 SR20det
338whp
1.55 60'
11.87@114
Old 09-11-2004, 06:18 PM   #7
Var
Var's Avatar
basically unless you have enough power to spin the best tires out there i dont think you should even bother setting your car up for drag.
Hi
Old 09-11-2004, 09:51 PM   #8
TheSnail
TheSnail's Avatar
TheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to all
Thats where I come in...
TheSnail is offline   Reply With Quote
Old 09-12-2004, 10:08 PM   #9
vanquish2
please explain...
I don't understand your thinking....
I am very competitive in my class and have placed as high up as second...
If I could get the susp. that would help my traction issues, 1st would be easier achieved....
[email protected]
92 S13 SR20det
338whp
1.55 60'
11.87@114
Old 09-12-2004, 10:11 PM   #10
HaLo
from Canada, eh!
HaLo's Avatar
humm softer is better?
-> HaLo
Race Car: '98 E36 BMW M3
SOLD: 01 GPW Honda S2000
Old 09-13-2004, 05:37 PM   #11
vanquish2
can anyone give me a straight answer or is this a drift only forum?
[email protected]
92 S13 SR20det
338whp
1.55 60'
11.87@114
Old 09-13-2004, 05:45 PM   #12
Var
Var's Avatar
Originally Posted by vanquish2
please explain...
If you want to be able to run better tires, get some solid subframe bushings(to reduce wheel hop), or the cheaper alternative which is subframe collars. If you go with the subframe bushings(which are more expensive and harder to install), then you can also take advatage of the tilt spacers. You can tilt your subframe to increase squat for better drag launches. IMO it's not worth it if you're running 13's. Even if you come 1st in your class you're slower than a stock camaro so who cares? If you start running 11's then i'd invest in a full drag setup.
Get your subframe spacers/collars/bushings here
Hi
Old 09-13-2004, 05:49 PM   #13
HaLo
from Canada, eh!
HaLo's Avatar
People have been giving you a straight answer: softer is better...
BTW, not everyone likes drift...
-> HaLo
