Old 12-23-2013, 06:43 PM   #1
windingroad86
windingroad86's Avatar
windingroad86 is on a distinguished road
For Trade: 1987 Toyota Cressida MX73 90K miles
CRESSIDA:
Car Details:
1987 Toyota Cressida with 91k miles on original motor. Automatic transmission with Overdrive and Electronic Control Transmission (ECT). Car has a CLEAN TITLE and I have the Carfax/Autocheck to verify this.
I recently had the water pump/timing belt, alternator, etc. replaced at a reputable shop CORNER3 GARAGE in Laguna Hills. They also did a full tune-up. I replaced the rotors and pads last month. I've spent about $2000 on maintenance the last couple months. I have the receipt/itemized invoice for all the work done.
* NEW OEM Alternator
* NEW OEM Timing Belt
* NEW OEM Water Pump
* NEW OEM Idler
* NEW OEM Drive Belt
* NEW OEM Air Filter
* NEW OEM Fuel Filter
* NEW OEM Engine Oil Filter
* NEW OEM Engine Oil Drain Washer * NEW OEM Spark Plugs
* NEW OEM Ignition Cap
* NEW OEM Ignition Rotor
* NEW OEM Ignition Wire Set
* NEW Intake Piping
* NEW Front and Rear Slotted Rotors * NEW Front and Rear Ceramic Brake Pads
* NEW PIAA Headlight Bulbs
Passed smog with flying colors and registered til September 2014. Motor runs strong. The car idles perfect with no shake/hesitation whatsoever.
Fully opted EXCEPT no sunroof. Luxury items include electronically controlled leather driver AND passenger seats. NO RIPS/TEARS ON THE SEATS AND NO CRACKS ON THE DASH. Even has 3 memory presets for the driver seat and heated side mirrors.
** $4k FIRM w/stock wheels **
windingroad86 is offline   Reply With Quote
Old 12-23-2013, 07:14 PM   #2
namawon
namawon's Avatar
namawon is an unknown quantity at this point
Wish you were in Fl..
glws
I'd walk a thousand miles with a broken spine before i'd
change my mind.
namawon is offline   Reply With Quote
Old 12-27-2013, 01:47 PM   #3
windingroad86
Thx man. Location is South Orange County.
Sent from my SM-N900V using Tapatalk
Old 01-10-2014, 01:43 PM   #4
windingroad86
Original post edited 2/22/14 12 pm.
Old 02-22-2014, 12:58 PM   #5
windingroad86
$4k FIRM w/stock wheels. 😃
Old 02-23-2014, 11:45 PM   #6
DeviousGTI
DeviousGTI is an unknown quantity at this point
bump....... looking into one now from original owner. seems legit. How do you like driving the car. The car is stock and I do need a daily. Oem and super mint.
DeviousGTI is offline   Reply With Quote
