Old 12-17-2013, 01:56 AM   #2761
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Originally Posted by vJilly View Post
i could be half retarded or tired as shit considering i have exams tomorrow. so youre saying +15 def will NOT rub my fronts?
It wont rub your coilover. Will it rub other places? Yes, but thats what fender rolling/pulling and a big ass hammer will come into play if you're low.
CLICK HERE!!!
Old 12-17-2013, 02:01 AM   #2762
stephens14sr
stephens14sr is an unknown quantity at this point
+23 will rub, +15 shouldnt. if you have any sort of bigger breaks you may have issues there depending on wheel design. thats about it.
Full 2014 build progress www.handicapmafia.wordpress.com
stephens14sr is offline   Reply With Quote
Old 12-18-2013, 01:07 AM   #2763
derass
Originally Posted by badass8 View Post
So I have been searching for a good fitment and function for front wheels, for drifting.
I have been looking to upgrade my stock 15's I would like more grip and tire up front and something that looks a little better as well.
My eye is on the xxr 527 I know everyone has these but they are pretty cheap and they don't really look that bad.
The size I was looking at was 17x8.25 +25 I would like the offset at about +10 for these wheels but I have yet to find them.
I am also running this setup at the moment if that makes a difference:
PBM coils
s14 FLCA
s13 modded knuckles
tein inner tie rods
SPL tie rod ends
So my question is how well will these fit and should I change my route for a better front wheel size for drifting?
Sorry for the noobness I am researching as I go along.
Originally Posted by Black R View Post
That sounds like a horrible size.
At least go 9" wide on a 17" rim - at least!
If you're only going 8" wide, then you can do 16x8 rota grid offroad in et+20 or et +10.
With any sort of angle modifications, especially modded knuckles, front wheel sizing is very important. You need maximum inboard clearance to keep from rubbing the tension rods at full lock. I run 17x9 +20 with modded knuckles and they rub badly, this causes the front wheels to slow down and the car to spin. There is one guy running 16x9 -32 that clears but good luck getting that under stock fenders. I would definitely recommend that 17x8.25 you are looking at, with a 25-35mm spacer. I, myself am looking to change to 17x8 in the front and will try and get the offset as low as possible.
Old 12-22-2013, 12:04 PM   #2764
ComicArtist
ComicArtist is an unknown quantity at this point
Don't know if anybody will know here, but does anyone know if VS-XX lips will bolt up on a VS-KF? I'm trying to build a pair of KF's, but can't find lips anywhere
ComicArtist is offline   Reply With Quote
Old 12-22-2013, 02:11 PM   #2765
fliprayzin240sx
You tried WheelFlip?
Outer Lips | WheelFlip
CLICK HERE!!!
Old 12-24-2013, 05:32 PM   #2766
Kouki_200
Kouki_200 is an unknown quantity at this point
Hello!!
I got a question about Wheel fitment on Silvia s14 kouki. Stock fenders but going for a roll and pull. Running BC racing BR coils...
Looking for new wheels...
Found a set I really want but they come in 9,5x19 +22 front and 11x19 +25 rear.
Is it possible to fit this with just a roll and pull and without crazy amount of camber????
Got any pics on 11 inch rear on stock Silvias??
What tire specs do you guys recommend?? Want some stretch since I like that look.
Thanks!
Kouki_200 is offline   Reply With Quote
Old 12-24-2013, 06:21 PM   #2767
vipergtsr1000hp
vipergtsr1000hp is an unknown quantity at this point
Originally Posted by Kouki_200 View Post
Hello!!
Thanks!
215/35/19 on the 9.5.
235/35/19 on the 11.
You should fit those wheels fine with just a roll.
About -1.5 deg camber in the front and -2 deg camber in rear.
Might need a 7mm spacer for the front if you're running coilovers.
vipergtsr1000hp is offline   Reply With Quote
Old 12-24-2013, 08:59 PM   #2768
InsTanCeZ
InsTanCeZ's Avatar
InsTanCeZ is an unknown quantity at this point
Are 7mm slip on spacers safe without extended studs? I've heard they are, but I'm not sure.
ACE マジック HEART
InsTanCeZ is offline   Reply With Quote
Old 12-24-2013, 09:23 PM   #2769
Rich260z
Rich260z is an unknown quantity at this point
Yes, I'm using them on my s13
Rich260z is offline   Reply With Quote
Old 12-24-2013, 10:51 PM   #2770
fliprayzin240sx
Personally, I wouldnt run anything more than 5mm on stock studs. Anything more than that, I'd be too sketched out. But I have done 7mm before. Some people say that as long as you get 3 full turns on the lugs, that its okay.
CLICK HERE!!!
Old 12-24-2013, 11:01 PM   #2771
shift_down
shift_down is an unknown quantity at this point
92 s13 hatch
I am running +30mm fenders in front and +30mm rear overfenders
I am looking to buy 17 inch wheels
I am looking to run a 9inch wide in front and 10 inch wide in back
I want to run wide tires, something like 245s or 255s
Are my wheel widths suitable?
And if so,
What offset and tire size should I get to sit flush?
Ka24 t3/t04b + Z32MAF + 550 subys + Walbro 255 + enthalpy Tune + 91 octane
shift_down is offline   Reply With Quote
Old 12-24-2013, 11:41 PM   #2772
InsTanCeZ
InsTanCeZ's Avatar
I would try F:17x9-10 R:17x10+0 with 255/40 all around, but that's just an estimate and it also depends on how much camber you have.
ACE マジック HEART
Old 12-25-2013, 07:59 PM   #2773
ijarrold
ijarrold is an unknown quantity at this point
Alright guys, I've been using the search feature and haven't been able to find anything..
XXR 526 comes in 17x10 +20
My question is how would I get them to fit on my S14..I'm going 30mm wide fenders and going to use 25mm spacers up front. All tires are going to be 235/40.
Am I going to have to use spacers in the rear? How much pull? Should I just go overs in the rear?
ijarrold is offline   Reply With Quote
Old 12-26-2013, 12:45 AM   #2774
VegasDrifterS13
VegasDrifterS13 is an unknown quantity at this point
Originally Posted by shift_down View Post
92 s13 hatch
And if so,
225 or 235 fronts on a 9" wheel. 255 rears on a 10" wheel. Those will both fit just right. 228.6mm = 9in. 254mm =10in.
Offset really depends where your definition of "flush" is , your ride height and how much camber your running with your setup. You could be "flush" with about 20-25mm of window in offset depending on the above stated settings.
Dont do this. 255s look like silly on a 9"wheel. All huge, squeezed, and round. Let alone trying to turn the car after that. Rubbbbb City!
Sent from my SGH-T989 using Tapatalk 2
VegasDrifterS13 is offline   Reply With Quote
Old 12-26-2013, 03:49 AM   #2775
Nikzilla
Nikzilla is an unknown quantity at this point
Hi guys.
I'm saving up for MB Battles.
I've searched but I couldn't find a specific answer.
I've got stock setup except for BC BR Coilovers, will be aiming for -2 camber.
I have a choice of 17x9 or 17x9.5 for the battles.
Will they fit without pulling/rolling with no scrub?
Which width, offset and tire should I get?
Nikzilla is offline   Reply With Quote
Old 12-26-2013, 04:42 PM   #2776
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
What is scrub? Do you, by chance, mean rub? What do you want out of the car? Fitment or function?
I typed out all the info that would answer your question but decided to delete it because this question can be answered with a few minutes of research via google or this forum's search function or if you're that stumped a look through this thread, could've answered your question. ESPECIALLY the topic of MB Battles. They're a basic and essential piece to complete the Zilvia S-Chassis starter pack.
For Sale #1 | For Sale #2
zooopreme is offline   Reply With Quote
Old 12-26-2013, 04:44 PM   #2777
Nikzilla
Yeah I meant rub. And I'm looking for function.
But ok, I'll try search again.
Old 12-26-2013, 04:52 PM   #2778
zooopreme
Trader Rating: (38)
Because it is the holiday season and because you didn't respond like the typical Zilvia butthurt folk, I'm feeling giving so here's two things that'll point you in the right direction:
rimtuck.com
I'm assuming that you have a stock body and by function, you don't want stretched tires so on a S13, the only way you can really fit 9.5 +15 and be low is to run camber AND smaller tires which does not equate to function. So if you're looking for a square/wide tire set up and/or an alignment that isn't funky, 9.5 +15 will not work. If you have over fenders then you'll be alright.
Old 12-26-2013, 04:54 PM   #2779
Nikzilla
rimtuck.com
I don't have to run it low. Could I run the 9.5 with just rolling or pulling? Or will it have to be overfenders?
Old 12-26-2013, 05:07 PM   #2780
ijarrold
Anyone have an answe?
Old 12-26-2013, 06:18 PM   #2781
Drama
Drama is an unknown quantity at this point
I'm currently running 18x10 +11 in the rear with my fenders only rolled. I've ran 235/40s with the camber almost maxed out.
225/40s I have -4* camber. I could run less camber without the tire rubbing, but since I have 8k/6k rates with the coilovers maxed out, the lip of the wheel will hit the fender on bumps.
If you dont want that much camber, you will need a small pull, or you can go with overs.
my friend is running 18x10 +22 with a slight pull and like -2* of camber on 225/40s
You'll be fine with just rolling on 9.5 +15. Not sure how low you want to go, but you'll have about -2, -3* of camber from lowering and it'll fit fine with 225/40s.
Drama
Drama is offline   Reply With Quote
Old 12-27-2013, 08:16 AM   #2782
Nikzilla
Ok, thanks!
But, hypothetically, what's the biggest tire I could pull the fenders to fit that setup safely?
The setup I'm referring to is 17x9.5+15 with -2* camber, and it doesn't have to be low.
Will it fit a 235/40? Or a 245/40?
Old 12-27-2013, 09:14 AM   #2783
VegasDrifterS13
I had 17x10 +15 on the rear of my last S14. It stuck out about 20-25mm. So it will probably stick out about 15-20mm in the rear, and fronts will stick out super far with 25mm spacers.
The rear would look ok, a little camber and stretch and it would sit flush-ish. The front is way too wide. Were talkin 50mm sticking out, even with 30mm overs up front, it will be 20mm outside those.
If youre trying to get that Stretched Tire Huge LIP Look, then youre on the right track.
Old 12-27-2013, 09:18 AM   #2784
VegasDrifterS13
Ok, thanks!
I ran some XXR 527's in 18x9.5 +20 with 245/40's. It was slammed and tucked with -2* camber. Slight roll on the quarters
Old 12-28-2013, 03:05 AM   #2785
fliprayzin240sx
Shit dont make sense, why would you buy a square wheel setup, then run 25mm spacers up front?!?! You want the front to look wide as fuck but have skinny rears? If thats your goal, I guess you're going for the fwd drag look thats popular in Honda Tech.
CLICK HERE!!!
Old 12-28-2013, 06:29 PM   #2786
acslater9
acslater9's Avatar
acslater9 is an unknown quantity at this point
Would the driving expirence change if I go from 195/60r15 to 195/50r15? Just wondering what the difference would be.
acslater9 is offline   Reply With Quote
Old 12-29-2013, 04:20 AM   #2787
fliprayzin240sx
No but you're speedo will be off a lil since you're effectively changing your cars gearing.
CLICK HERE!!!
Old 12-29-2013, 05:48 AM   #2788
InsTanCeZ
InsTanCeZ's Avatar
This is actually very common in drifting because a wide front track is needed for more steering angle.
specs here are 17x9-35 (-10 w/ 25mm extended FLCAs) front and 17x9+15 rear I believe. lol
ACE マジック HEART
Old 12-29-2013, 06:19 AM   #2789
fliprayzin240sx
Umm...how would pushing the wheels further out big you more steering angle? If it anything, shit will be worst since you'll rub in anything and everything.
CLICK HERE!!!
Old 12-29-2013, 08:49 AM   #2790
VegasDrifterS13
Lol. Why do you think extending your LCA gives your wheel a different offset measurement. It Doesnt. Your still 17x9 -10 with a 25mm extended LCA. **NOT 17x9 -35 because of the LCA.** The offset is purely measured by the relation of where it mounts, it has nothing to do with suspension parts. FYI.
Dont need more noobs reading this believing your wrong info and then posting more ignorance thinking theyve learned something.
