#2791 | |
![]() Join Date: Jul 2006
wider front track is for stability and turn in the added camber is beneficial when you're at full lock.
DODOlogic.ca |
#2794 | |
Fronts will be close, depending on your brakes you might need a spacer regardless and they will rub if you have any angle mods. Sent from my SGH-T989 using Tapatalk 2 |
#2795 |
#2796 |
![]() Join Date: Feb 2012
True but it's mostly for inner fender/tension rod/FLCA clearance.
ACE マジック HEART |
#2797 | |
lolwut? More inner clearance = more steering angle and less rubbing. Pretty simple concept.
ACE マジック HEART |
#2798 | |
#2799 |
Okay I know that. lol I'm studying mechanical engineering for motorsports right now. And yes it's still the same fitment as having -35 offset. If you put on spacers and added the same amount of camber by slotting your coilover mounts it would fit the same. (Your scrub radius would be different though most likely). IDK why you are trying to argue about this. Now we're clogging up the fitment thread!
ACE マジック HEART |
#2800 |
Tire size suggestions please!
I have work xt7s, 17x9 +17s all around. Lowered right now on stance GR+ Suspension. I wanna be flush but I don't like the stretched look too much (No offense, just personal preference.) I hope I don't sound like too much of an idiot. Tire size has been driving be crazy bc jut trying to find a happy medium. Any suggestions please?
#2801 | |
#2802 | |
ACE マジック HEART |
#2803 |
I am wondering if I can fit SSR SP1's 17x9.5 +0 & 18x11 -1 on my s14 that is sitting on coils. What size tires do you recommend? Also would I have to do any mods such as rolling/pulling fenders, spacers, etc? Thanks!
#2804 |
I have a s13 coupe im thinking 18x9.5 +12 or +15. all around clear coils.
I want all four same size. maybe roll the fenders and thats it no widebody maybe slight pull. what would you suggest i have s13 silvia front. ![]() this exact look to where the wheel goes in the well just on a coupe. |
#2805 |
Man w/ CTSV & a Car Seat
You dont get it, you push the wheels further out with spacers or too low of an offset, you'd scrub anything and everything at full lock. Over fenders wont save you when your damn tires are touching your inner wheel bad enough that it locks the wheel while drifting, fastest way to spin your ass out.
#2806 | |
DODOlogic.ca |
#2807 |
I guess I was just asking what other rim sizes fit flush on coupe like the 18x9.5+12
I found nice varrstoens but they're 18x9.5+30 and that seems horrible fitment for front Sent from my SCH-I545 using Tapatalk |
#2808 | |
also see : rimtuck.com
DODOlogic.ca |
#2809 |
1010TIRES.COM - Wheel Offset Calculator and Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit seem to be the best resources. That's what I use sometimes.
ACE マジック HEART |
#2811 | |
Azenis RT615K | Falken Tire |
#2812 |
18x9.5 +30 will rub the strut up front. 18x9 +30(common sizing since R34 GTR wheels is this spec) is pretty much hit or miss as it is. Sometimes they'd clear, sometimes it wont.
#2813 | |
1. roll fenders all around 2. fronts: 215-35-17 on 17x9.5 with some negative camber (no pull) 3. rears: 235-35-18 on 18x11 with a lot of negative camber or pull+less negative camber 4. slam that shit |
#2814 |
^^^ What he said, except no one makes those tire sizes. I would go with 205/40-17 or 215/40-17 fronts and 235/40-18 rears and maybe look into rear over fenders unless you're set on keeping metal.
ACE マジック HEART |
#2816 | |
![]() Join Date: Aug 2009
Trader Rating: (77)
![]() Feedback Score: 77 reviews
Wheel Fitment Question Thread
Yes, it will, with camber and rolled/pulled fenders all around. Mine is 9.5 +12 front and 10.5 +15 rear with some room to spare. All with adjustable arms all around though. Edited**** Added Pic so you'll get the idea.... ![]()
#2817 |
I don't mind a roll but I really wanna keep my s13 quarters and silvia fenders from pulling. Any pictures of your fitment and thanks for reply.
#2818 | |
Trader Rating: (77)
My bad, I'll take the rolled/pulled all around back. No need to pull in the front, only roll. But did both in the rear. Need to find more fitment pics though.
#2820 | |
![]() Join Date: Sep 2012
With a 9 inch wheel in front and 30mm overs, am I safe to get a 0 offset adjust the flushness with spacers? Or will it be sticking out of the fender well. I am planning on using 0* of camber And should I go with a -10 offset for my 10 inch wheels in the back to achieve the same goals? Again, I am going to run 0* of camber, and maybe adjust as necessary.
Ka24 t3/t04b + Z32MAF + 550 subys + Walbro 255 + enthalpy Tune + 91 octane |
