Old 01-01-2014, 01:03 PM   #1
dil han
dil han is an unknown quantity at this point
Real RHD S14 Silvia Zenki North GA
This car is registered and I will disclose the information to interested buyers in person. I will not argue what is legal and what is not. I've been pulled over for antagonizing the fuzz and never received a ticket. Tagging this car was not a problem. I can not speak for states or city's outside GA.
I've owned this car for about 2.5 years. I bought the BARE shell and put the whole car together myself. It was fun and expensive finding parts in a dozen different country's that this was missing. Everything is perfect and I can proudly say this is one of the nicest s chassis' you will ever see or drive in the country. Although it doesn't have paint, it has been well taken care of and each typical problem on these cars has been addressed and fixed. It drives like a Lexus and never, never, never has left me stranded. After assembling the car I drove it for about 1 year without a single problem before upgrading the clutch and more upgrades. This car has never been to a drift event or a drag strip. It makes about 270 hp on a dyno dynamics @ 13.9 lbs, and gets about 260 miles to a tank flooring it around the city and 310+ on the hwy. It is a conservative tune that will allow the motor max life. There is not a single clip, bolt or nut missing on this car. Nothing rattles or vibrates.
If not sold before I paint it, I have already purchased a gallon of Blue Raspberry Metallic which is one of the colors found on the 2013 Honda Fit. It is a bright teal that I absolutely love.
Friend's of mine have bought $7200-$14,500 USDM 240's that have a hand full of "nice" parts but all of them have a years worth of problems if you don't find anything else wrong while diving in. You will not find a street car of this kind that needs less work.
Located in Ga
PM,call or text 770-714zero134
PRICE: $15,000 painted
$12,500 unpainted
$10,500 without wheels
I DO NOT WANT TO TRADE!
Chassis:
1995 Nissan silvia s14 base model (no sun roof and originally 4 lug)
126,000 KM on chassis
Clean frame rails
No water leaks
Passes emissions with good cat
Silvia grill
Navan OEM front bumper with all grills
Navan OEM side skirts
Navan OEM rear valances
Greddy rear wing
New OEM Nissan euro glass head lights
OEM Nissan corner lights with LED bulbs
6k or 8K HIDs
All body panels are OEM metal
New Circuit Sport LED red/clear tails
Power folding mirrors
New S14 OEM silvia window visors
Has front fender liners
Rear wheel wells have minor tub for wheel clearance
Rear quarters have been rolled, flared and fiberteched for smooth finish
I have front and rear Silvia emblems
Suspension:
BC coilovers
Cusco rear camber arms
Cusco rear toe arms
Beefy front tension arms, Unknown brand but very nice, anodized green
New OEM steering rack bushings
New MOOG outer tie rods
New OEM Nissan front lower control arms
Brakes:
5 lug conversion
350z base model front brake calipers
350z slotted front rotors
Hawk HPS pads front and rear
Motul RBF600 brake fluid
Stock lines on now, Have braided in basement
New NAPA rear rotors
Tucked brake lines under hood
Wheels:
Wed Sport TC 105N 1 owner
18x9.5 +12 in front 225/40/18
18x10.5 +10 in rear 245/40/18
Cheap daily beater tires only 2,000 miles max on them. No road noise and rides smooth
Muteki black extended open face lugs
Engine:
S14 sr20det with 80,000 miles when purchased, 100,000 currently and rising everyday
No leaks, no leaks, no leaks, no leaks
New OEM valve cover gasket
New OEM water pump
New OEM rear main seal
STI yellow top 550cc injectors
No maf, converted to speed density with AEM EMS tuned by world class tuner Scott Seigel.
Thick no name turbo manifold
Stock s14 sr turbo
New turbo gaskets
Megan racing turbo elbow
Megan racing down pipe
New ISIS black turbo lines
New OEM Nissan engine and trans mounts
All new Gates drive belts (3)
Motul 8100 engine oil
OEM oil filter
Shurken 10 lb battery
Mishimoto big radiator
Evans waterless coolant, they advertise you never have to change it for a life time
Clean OEM over flow tank with no cracks
Working A/C R134a
Working P.S. / New Nissan fluid
CX Racing intercooler kit black piping with front mount
Oversized Greddy BOV with flange
HKS oil cap
Custom intake I made for turbo inlet painted wrinkle black, Aluminum
Walbro fuel pump
APEXI 3.5" cat back exhaust $1000
No name test pipe
Drivetrain:
SPEC clutch stage 2 with new throw out bearing and pilot bearing
New 5 speed trans, last one was whining
New blue blood racing gear oil in trans 75w90
Trans has zero leaks and shifts smooth
C's short shifter
Factory VLSD diff 4.08 ratio no leaks
Motul 90PA mineral oil in diff
New OEM diff bushings
Factory silvia driveshaft of course
Interior:
All interior present except rear floor mats
Auto up and down driver window
Working hood, trunk and fuel door release cables
All OEM Nissan glass
Slick black dash with no air bag prevision. Apparently rare
350z steering wheel
350z base model front seat, Driver currently installed, will install pass side when time permits
S15 rear seats
Front silvia mats, Zenki not Kouki
Original gauge cluster
Digital climate control with AUTO
Clean carpet
New Sony double din radio, current top of line this year with mirror link, XM and nav
Hands free and Iphone cable and Blue tooth
New DB audio speakers front and back
OEM turbo timer, HKS salesmen from Japan came to my former shop and loved it, took picture with JDM Iphone
Coin holder
PBM drift botton
JDM flare hold with no flare
Full trunk interior with wooden floor wrapped in carpet, factory cardboard just collapses.
AEM UEGO wideband sensor
I have lots of parts I can throw in for my asking price of sell separately. Up to the buyer.
ARP head studs
Solid trans mount
HKS fuel rail
Stainless braided brake lines
More I'm forgetting
As I own 5 cars and I'm a mechanic for a living I can not find time to do everything. This car does have the following problems.
1) fuel gauge is not accurate
2) the window tint should be replaced in my opinion
3) no horn
4) I would prefer cleaner door panels
dil han is offline   Reply With Quote
Old 01-01-2014, 01:08 PM   #2
Nategreat923
Nategreat923's Avatar
Nategreat923 is making a name for him/her selfNategreat923 is making a name for him/her self
Whether legal or not, still superrrrrrrrr cool. GLWS
Nategreat923 is offline   Reply With Quote
Old 01-01-2014, 01:28 PM   #3
QuickSpoolSR
QuickSpoolSR's Avatar
QuickSpoolSR will become famous soon enoughQuickSpoolSR will become famous soon enoughQuickSpoolSR will become famous soon enoughQuickSpoolSR will become famous soon enough
If it's a jdm car and not originally a us 240sx it's illegal and will always be illegal here even after the 25 year rule passes on the car since it was brought here illegally. None the less, sick car very well done, would love to see it painted glws
QuickSpoolSR is offline   Reply With Quote
Old 01-01-2014, 02:08 PM   #4
JetS500
JetS500's Avatar
JetS500 is an unknown quantity at this point
Oh My got damn this is fresh
JetS500 is offline   Reply With Quote
Old 01-01-2014, 02:10 PM   #5
hks4life
hks4life is an unknown quantity at this point
bump for a good guy and a super clean ride, seen it plenty of times! idk why he doesnt paint it and asks for more
hks4life is offline   Reply With Quote
Old 01-01-2014, 02:12 PM   #6
hks4life
yeah worthless post when he even ask not to be bother by these type of post..
Old 01-01-2014, 02:28 PM   #7
rb27dets14
rb27dets14 has a little shameless behavior in the past
Cars all win...then I saw that wing and taillights.....
Quote Originally Posted by andresr20
ffffffuuuuuuuuuuuuukkkkkkkkkk HONDAS
rb27dets14 is offline   Reply With Quote
Old 01-01-2014, 04:25 PM   #8
Bullitt_180sx
Bullitt_180sx is an unknown quantity at this point
It does not matter if he asked not to be bothered by these type of posts. It's valid information that needs to be put out there for potential buyers that may not be aware of the details. I feel like your post was more useless, and so is mine, but I felt the need to rant.
To the OP, awesome car and good luck with the sale.
Bullitt_180sx is offline   Reply With Quote
Old 01-01-2014, 06:49 PM   #9
shotcaller1681
In time-out for misbehaving.
shotcaller1681 is an unknown quantity at this point
Does it have a normal title? And my last 240s fuel gauge didn't work and it wasn't a problem at all just In case someone was wondering
shotcaller1681 is offline   Reply With Quote
Old 01-01-2014, 09:52 PM   #10
vw203
vw203's Avatar
vw203 is an unknown quantity at this point
Send a message via AIM to vw203
I want this in the worst way. And btw if someone is plans on buying any jdm without knowing the risks then they shouldn't be in the market in the first place.
スカイライン
vw203 is offline   Reply With Quote
Old 01-01-2014, 10:30 PM   #11
spicoli
spicoli is an unknown quantity at this point
Send a message via AIM to spicoli
This car is the bees nees. I would buy this sucker in a heart beat. I would trade my q45 for this lol.
spicoli is offline   Reply With Quote
Old 01-01-2014, 10:41 PM   #12
vw203
vw203's Avatar
Shit I know you said no trades but if you change your mind I have forged built cammed turbo G35 on volks and less then 100k on it that'd I'd trade. Worth a bit more then your asking straight across.
スカイライン
Old 01-02-2014, 12:52 PM   #13
bigdnno98
bigdnno98 is an unknown quantity at this point
wow. great job. that is an amazing looking car.
bigdnno98 is offline   Reply With Quote
Old 01-02-2014, 01:04 PM   #14
Juantwo3
Juantwo3's Avatar
Juantwo3 is an unknown quantity at this point
NICE!!!!!!!!!!!!!!
did you make custom rails for the 350z seat?
GO DUCKS!!!!!!!!!
Juantwo3 is offline   Reply With Quote
Old 01-02-2014, 02:06 PM   #15
hks4life
my fucking point,people act like they need to say something.. like he is not going to tell the buyer what needs to be done..
Old 01-02-2014, 09:01 PM   #16
Bullitt_180sx
The point is that there is nothing "to be done" it's illegal to drive this car on US roads period. Sure people in most states will never have a problem with the authorities, but that doesn't make it legal.
Old 01-02-2014, 10:58 PM   #17
vw203
vw203's Avatar
And that doesn't make anyone give a flying shit what you say^. Gtfo of here if your not interested.
スカイライン
Old 01-03-2014, 08:23 AM   #18
bosozokujin
bosozokujin is an unknown quantity at this point
lol niggas policing and stuff.
bosozokujin is offline   Reply With Quote
Old 01-03-2014, 09:07 AM   #19
RitzY33
RitzY33 is an unknown quantity at this point
Nice and clean GLWS
People need to understand not every vehicle listed for sale is something that needs to be daily driven, a family wagon, or a grocery getter.
RitzY33 is offline   Reply With Quote
Old 01-05-2014, 02:32 PM   #20
dil han
Originally Posted by Juantwo3 View Post
NICE!!!!!!!!!!!!!!
I modded the front tabs and built my own rear feet off the 350z rails to bolt to the floor.
With the 350z seat, wheel and front brakes the car feels like new. Love it
Old 01-05-2014, 07:22 PM   #21
TrunkStyle
TrunkStyle is an unknown quantity at this point
I would love to see this thing finished. Good luck m8! That Gracer wing is sex
TrunkStyle is offline   Reply With Quote
Old 01-06-2014, 11:54 AM   #22
dil han
Thanks a lot, I've been driving it all over the city and back last week, its a highway cruiser for sure. Perfect.
Old 01-06-2014, 12:34 PM   #23
TrunkStyle
I needed to see this. It makes me want to get a Zenki again. Damm.
Old 01-07-2014, 04:22 PM   #24
my750
my750 is an unknown quantity at this point
That has to be one of the cleanest interiors I have ever seen glws
my750 is offline   Reply With Quote
Old 01-08-2014, 10:32 PM   #25
dil han
Thanks, it honestly looks better in person. It's not vacuumed or wiped down in these pictures.
Old 01-08-2014, 10:59 PM   #26
sterlinge
sterlinge's Avatar
sterlinge is an unknown quantity at this point
Clean zenki! This thing would be mint with fresh paint. I doubt you could even consider selling it if you had it painted.
sterlinge is offline   Reply With Quote
Old 01-09-2014, 11:09 AM   #27
Drewsjdm
Drewsjdm is an unknown quantity at this point
Hey I'm Aaron's buddy can you call me at 770-402-5679
Drewsjdm is offline   Reply With Quote
Old 01-09-2014, 07:39 PM   #28
youradumb1
youradumb1's Avatar
youradumb1 is an unknown quantity at this point
damn fun car .. not worth the price .. can get a legal on in a few years for half .... but super nice seller ....if you cant wait .. this is the car for u
just better than you
youradumb1 is offline   Reply With Quote
Old 01-09-2014, 09:30 PM   #29
shotcaller1681
So by few you mean 6 years? And by half the price you mean 7500?
Old 01-10-2014, 12:22 PM   #30
Carina240sx
Carina240sx is a glorious beacon of lightCarina240sx is a glorious beacon of lightCarina240sx is a glorious beacon of lightCarina240sx is a glorious beacon of lightCarina240sx is a glorious beacon of lightCarina240sx is a glorious beacon of lightCarina240sx is a glorious beacon of lightCarina240sx is a glorious beacon of lightCarina240sx is a glorious beacon of lightCarina240sx is a glorious beacon of lightCarina240sx is a glorious beacon of light
Your username suits you very well. 👌
And if/when these cars ever become legal. I don't see them being listed for anything under 10k STOCK.
The UPGRADES ALONE on this thing makes it completly worth the price.
I don't even need to say good luck with sale on this. It will sell for asking price no problem.
Carina
http://i7.photobucket.com/albums/y251/MyCockerIs4U2NV/Cats/Sig.jpg
Carina240sx is offline   Reply With Quote
