Old 01-05-2014, 08:20 AM   #1
niGht_kraWler
niGht_kraWler is an unknown quantity at this point
1995 Ka24de Jim Wolf Technologies ECU
1995 Ka24de Jwt Ecu - 9.5:1 compression(stock), Nismo 555cc (yellow tops), z32 maf, raised rev limit, no speed limit -
$280 shipped to the lower 48 states.
Not on here much so email me @ [email protected]
niGht_kraWler is offline   Reply With Quote
Old 02-26-2014, 03:10 PM   #2
niGht_kraWler
upppppppppppppppppppppppppppp
Old 05-02-2014, 02:06 PM   #3
niGht_kraWler
someone needs this? yah
Old 05-06-2014, 11:37 AM   #4
yaldizzle
yaldizzle is an unknown quantity at this point
how much more power did this add? and whats the rev limit set at? what other mods do we need to do to run this? is it tuned for headers and exhaust as well?
yaldizzle is offline   Reply With Quote
Old 05-06-2014, 12:08 PM   #5
niGht_kraWler
This tune is for a turbo ka24de. All you need to run this setup is a z32 maf and the Nismo 555cc injectors. I believe rev limit is set at around 7600 rpms. Power wise, it depends on how much you boost, this ecu uses the maf to measure intake air volume for calculations so there is no limit on how many psi you can run until the maf or injectors maxes out.
Old 05-06-2014, 12:28 PM   #6
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
i have this exact ecu and mine hits the rev limit at 7000rpms.
I've ran this on a bone stock ka and it there is a noticeable difference in hp/tq and throttle response.
It's a great ecu, GLWS
spooled240 is offline   Reply With Quote
Old 05-06-2014, 12:42 PM   #7
niGht_kraWler
You might be right about 7k rpms. Its been awhile since I spoke with Ben at JWT. You're the first person I've heard of using it on a N/A setup, but it makes sense since the inputs from the MAF. Adding headers, intake, etc will only make more power since its a bit higher flowing.
