Old 01-06-2014, 09:35 PM   #1
jchandler21
jchandler21's Avatar
jchandler21 is an unknown quantity at this point
Running cold
Hey guys. RB25DET s14, car only runs at 67 degree Celsius with fans off and cruising, and 67 degrees celsius with fans on at a stop, which only allows a tiny bit of heat. Any ideas on how to get it a little bit warmer so I can get more heat in the car?
jchandler21 is offline   Reply With Quote
Old 01-06-2014, 11:16 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Are you running a thermostat? Have you tested it to make sure it's not stuck open?
Old 01-06-2014, 11:30 PM   #3
jchandler21
Sorry I forgot those details. New thermostat, new water pump, a koyorad, and one push one pull fan.
Old 01-07-2014, 01:23 AM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Damn, I wish my RB would run that cold...my shit gets up to 90-95* cruising. Are you running a Nismo thermo? Also, how are you seeing your temp? Using a PFC via the OEM sensor or an after market gauge? If aftermarket, where do you have the sensor hooked up at.
CLICK HERE!!!
Old 01-07-2014, 10:39 AM   #5
jchandler21
I hate to say this but I bought the car, and was told that all that stuff was new. So is it really new? who knows. Not sure if its a nismo thermostat or not. I'm reading it off my Apexi controller. The stock gauge doesn't get up into the normal operating temperature range unless I sit at a stop with the fans off.
Old 01-07-2014, 10:59 AM   #6
DJ-of-E
DJ-of-E's Avatar
DJ-of-E is an unknown quantity at this point
Isn't it like a blizzard @ NJ right now?!?!
With that radiator, you most likely have a "colder" thermostat, hence why it is stuck on such cold temp.
Originally Posted by ocn View Post
its not "DRIFT" tax its a "IDIOT" tax Period!
DJ-of-E is offline   Reply With Quote
Old 01-07-2014, 11:03 AM   #7
jchandler21
hahaha it's definitely cold. Us New Jersians aren't used to negative temperature wind chills haha, but this was still the case back in November when it was in the 50's
Old 01-07-2014, 11:27 AM   #8
aymaeid
aymaeid's Avatar
aymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-known
replace your thermostat. like you assumed, the seller probably lied to you.
Originally Posted by racepar1 View Post
Talking shit is half the fun of zilvia.
aymaeid is offline   Reply With Quote
Old 01-07-2014, 11:30 AM   #9
brndck
brndck's Avatar
Place a sheet of cardboard across the front of HALF your radiator. Tape it in place. Disconnect fans. Drive in stop and go traffic. See if engine reaches full temp.
Old 01-07-2014, 11:33 AM   #10
jchandler21
It will reach full temperature just sitting there letting it idle. As soon as i start moving it cools off gradually back down to 67*. Last night when it was real cold, it was at 64*, but once i got to a stop light and sat for a bit, it would rise.
Old 01-07-2014, 11:41 AM   #11
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
Be at high RPM's.
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline   Reply With Quote
Old 01-07-2014, 03:16 PM   #12
brndck
brndck's Avatar
When you say full temp you mean like 90*C? What are the ambient temps while you're driving around? I suspect that it's just fucking cold outside and your cooling system is working fine.
Old 01-07-2014, 05:38 PM   #13
unreal-
unreal- is an unknown quantity at this point
That means your coolant system is actually WORKING! If it never got to operating temp under ANY circumstance, then you would have a problem.
I suspect the same thing. Even with a KA-T with stock rad in this weather i rarely see temps higher than 65-68*C according to Nistune. Highest ive seen my coolant temps climb to is 160F after driving around for a while. Its just that its REALLY REALLY COLD outside. Its been in the teens-->single digits for the past week in NJ.
OP:
unreal- is offline   Reply With Quote
Old 01-07-2014, 05:51 PM   #14
badbob2121
badbob2121's Avatar
badbob2121 is an unknown quantity at this point
I had a similar problem with my SR last winter.. so I pulled out my thermostat..
Yeah... problem was found..
FOLLOW ME ON INSTAGRAM = BOBBY_LS13
badbob2121 is offline   Reply With Quote
Old 01-07-2014, 09:15 PM   #15
jchandler21
yea full temp meaning 90*. When i first got the car it was in the 70's. It may be that everything is fine, i just didnt know if it was normal or incorrect.
OP:
True true. I may just check the thermostat just in case i WAS lied to.
Now I'm definitely gonna check the thermostat. haha
Thanks guys!
Old 01-07-2014, 09:42 PM   #16
brndck
brndck's Avatar
what the shit???
i've never seen that before.
Old 01-08-2014, 02:28 AM   #17
unreal-
High Performance thermostat
