Old 01-17-2014, 07:22 AM   #1
S13alldayyo
S13alldayyo's Avatar
S13alldayyo is an unknown quantity at this point
Ignition problem
I have to shake my key to turn on my car everytime, will switching out the switch itself with a new key solve my problem?
S13alldayyo is offline   Reply With Quote
Old 01-17-2014, 07:56 AM   #2
S13alldayyo
Anyone
Old 01-17-2014, 08:36 AM   #3
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Does the key easily open the doors and trunk? If so then get a new cylinder.
Old 01-17-2014, 08:40 AM   #4
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Because Florida.
What do you mean "shake" your key? Like you hafta cycle it a few times in the cylinder before the starter will crank?
Most likely it is a worn contact in the cylinder, but they're pretty easy to replace.
Old 01-17-2014, 09:38 AM   #5
S13alldayyo
Since brndck is so lost let me clarify what I'm trying to say. Key to engine start, nothing, key to engine start but I shake the key around in there, it turns on perfect. Thank you Cody always helping me out can't wait to get your external wastegate setup on my stock exhaust manifold
Old 01-17-2014, 09:49 AM   #6
brndck
brndck's Avatar
Was that not helpful?
There's just so many common sense threads here. Hey my window switch doesn't work, should I replace it? Hey my left brake light doesn't work, should I check the bulb? Hey I don't have any fuel pressure, should I check if my fuel pump is getting voltage?
Hey if I put the key in the cylinder and turn it to the crank position and nothing happens, should I check continuity in the cylinder?
Old 01-17-2014, 09:51 AM   #7
S13alldayyo
Just wanted to make sure before I spend the little money I have left after buying almost a full type x kit in 1 month
Old 01-17-2014, 09:52 AM   #8
S13alldayyo
Thanks for your help though, it is appreciated. I will buy a new one.
Old 01-17-2014, 11:26 AM   #9
brndck
brndck's Avatar
I would just go get a used one. You can probably find one on the marketplace for like $25
There's a one in eight chance your key will work in it anyways or you can always have a locksmith re-key it.
Old 01-17-2014, 12:50 PM   #10
S13alldayyo
I have a guy that's going to give me a new one for 30$ because he didn't need it
