Old 01-19-2014, 09:29 AM   #1
es ar 20
es ar 20 is an unknown quantity at this point
SR20DET Blow-by - Catch Can - etc Question pls help
Hi everyone
This is my first post and my first S14!
I just purchased the car and I notice where there would typically be a catch can- there isn't! Just an empty fitting Two of them to be exact. Forigive my ignorance on the matter but I have attached photos to illustrate my concern.
You'll notice two blue threadings on the right and left. Is it dangerous (or just dirty) to run the car as it is? And am I losing potential HP by not having those gases sans the oil re routed back into the system?
Thanks in advanced and again I apologize for possibly asking a stupid question.
es ar 20 is offline   Reply With Quote
Old 01-19-2014, 11:06 AM   #2
bmxer882x
bmxer882x is an unknown quantity at this point
Yeah um thats bad. Look at a picture of how its supposed to be. How is the little black oem catch can drain hole? Is it wide open as well? How it is now youll have oil shooting on ur manifold. Huge fire hazard. Not sure what fittings those are for but I wouldnt drive it until you get both sides hooked up.
bmxer882x is offline   Reply With Quote
Old 01-19-2014, 11:23 AM   #3
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Yeah both those lines should be routed to a catch can. I would not drive the car around like that. Google some photos of the stock setup, and copy that. It looks like whoever you bought the car from removed their setup before they sold you the car.
Since they already converted to a/n fittings you will either have to so the same, or buy another stock valve cover with the stock fittings and go from there.
Old 01-19-2014, 12:49 PM   #4
ultimateirving
ultimateirving's Avatar
The an fittings are nice so if I was you I'd try and find some hose and build it to fit. Get a catch can with the same an fittings and you'll be good to go
Z32 with lq4 swap
Old 01-19-2014, 01:26 PM   #5
es ar 20
Thanks so much guys for the responses! So both of those fittings should be routed to a catch can but what about the blow by? Should it just have an air breather and vented to the air or re routed back into the intake? Is there any benefits to either way?
Old 01-19-2014, 01:42 PM   #6
ultimateirving
Don't use any breathers. But one of the lines needs to go to the suction pipe. Aka turbo intake between maf and turbo. That way it evacuates the crankcase at all times
Z32 with lq4 swap
Old 01-19-2014, 02:42 PM   #7
es ar 20
Ok. Now it has a an fitting behind the air intake before the turbo. Is that a bad place to have it routed? Currently I just have it capped off. The maf is on the opposite side on the piping near the intercooler. It is a 300zx maf
Old 01-19-2014, 02:56 PM   #8
es ar 20
The first pic is of the an fitting behind the intake filter the second is the maf by the intercooler and the third is the overhead shot where the pipes go on the maf side
Old 01-19-2014, 03:00 PM   #9
MidwestMyriad
MidwestMyriad's Avatar
MidwestMyriad is making a name for him/her selfMidwestMyriad is making a name for him/her self
Kind of like this, but obviously yours would come from the existing fittings on the sides, the fitting you have capped currently should be your "vacuum" line from the catch can.
@MMyriad
MidwestMyriad is offline   Reply With Quote
Old 01-19-2014, 03:15 PM   #10
es ar 20
Gotcha! Thanks so much for the response!!
Old 01-19-2014, 03:16 PM   #11
es ar 20
Would you reccomend a kit that I can purchase that will work on my current fitting set up?
Old 01-19-2014, 10:23 PM   #12
Kaifd3s
Kaifd3s's Avatar
Kaifd3s is on the path to ruinKaifd3s is on the path to ruin
Tamarac? WERD?
Kaifd3s is offline   Reply With Quote
Old 01-24-2014, 07:38 PM   #13
es ar 20
Yea! I actually am in wpb now but moving to Tamarac next week!
