Old 01-26-2014, 09:51 PM   #1
stunnaben
stunnaben is an unknown quantity at this point
1JZ Epic Partout (two motors)
Alright, deciding to part ways with my 1JZ motorsets. I'm going to go another route so I figure this would be the best way to do it..... Everything is for sale.
1JZ Healthy Bottom End - $500 (comes with Oil Pump that hasn't been touched
1JZ Spun Bearing Bottom End - $200 (Just block and Crankshaft. Repairable)
1JZ Front Sump Oil Pan Setup - $300
1JZ Rear Sump Oil Pan Setup - $250
1JZ Used Oil Pump - $100
1JZ Assembled Head - $250 (no cam sensors)
1JZ Disassembled Head - $200 (no cam sensors)
1JZ Cam Sensors - $40 each
1JZ Ignitor - $125
1JZ Crank Position Sensor - $50
1JZ Valve Covers - $100 per set
1JZ Soarer ECU - $250
1JZ Soarer Engine Harness - $200
2JZ - GTE Map Sensor - $100
1JZ Turbos - $200 per set (I have 2 complete sets)
1JZ OEM Rods and Pistons set w/ used rings - $150 (set of 6 but one has a spun rod bearing)
1JZ Hydrofan water pump - $50 each
1JZ NST Crankshaft Pulley - $50
1JZ Assembled Intake Manifold with Throttle Body - $200
1JZ Disassembled Intake Manifold with Throttle Body - $175
1JZ Coilpacks - $200 for set
1JZ Coilpack Cover - $100
S14 KYB GR-2 with stock springs - $75
S14 Apexi GT Spec - $200
S14 OEM Exhaust - $80
This is the rest of the parts from the head that I tore down to clean. Everything is labeled and bagged.
Cam Caps for disassembled head, Upper Oil Pan Bolts, and Flex Plate Hardware
Great Condition Front Sump Upper Pan
Decent Condition Oil Pump
Same as above
Oil Pump still attached to good engine block
Top of Cylinders on good engine block
Bottom End of good engine block. All bearings meet specs for thrust tolerances. I have these values if necessary.
Bottom of Rear sump (Had a dent but I beat it back out. It's a steel pan, it can take some abuse.)
Assembled head but in good condition. No scoring on caps or cams.
stunnaben is offline   Reply With Quote
Old 01-26-2014, 09:51 PM   #2
stunnaben
Rear Sump Upper Oil Pan great condition just dirty. I can clean up if you're picky.... I hate dirty parts myself.
This is a picture of #6 rod journal on the crankshaft. A good polish should remove the bearing material that has fused to it. Shouldn't require cutting.
The bottom of the spun bearing block
Bottom of the good block as it sits on the engine stand. Haven't cracked the rod or main bolts.
Look how clean that water/oil heat exchanger is
This is the top view of the head I disassembled for cleaning. It will need new valve stem seals that come with engine gasket set
Combustion Chamber of disassembled head
KYB GR-2 for S14 with OEM springs I believe but don't quote me
Pictures of S14 Apexi GT Spec Exhaust
Dents on bottom of GT Spec Muffler
Scrapes on bottom of GT Spec Piping
Old 01-26-2014, 09:52 PM   #3
stunnaben
Dents on bottom of GT Spec Piping
Dents on bottom of GT Spec Canister
Apexi GT Spec for S14 and OEM S14 Exhaust
1JZ twins w/ wastegate actuators, OEM Y-pipe, OEM manifolds as well as a 2JZ oem manifold and 1JZ engine mount and bracket
2X Oem 1JZ Hydrofan waterpumps can't buy these in the states
2nd set of OEM turbos with OEM manifolds, OEM Y-pipe, and OEM 02 sensor
1JZ valve cover set number 1
1JZ camshafts that go to disassembled engine
NST 1jz Crankshaft pulley
1JZ ignitor
Old 01-26-2014, 09:54 PM   #4
stunnaben
1JZ Intake manifold with throttle body attached and IACV
2X 1JZ injector portion of intake manifold, 1JZ Fuel Rail, 2JZ jdm fuel rail, various 1JZ turbo piping, connectors, and OEM bov
1JZ Coilpacks
1JZ pistons, rods, and bearings from spun bearing 1JZ engine
1JZ Soarer ECU AT
1JZ Soarer ECU AT
1JZ Valve Covers and Camshafts from Assembled head
Semi-disassembled intake manifold w/ throttle body and camshaft pulleys
Various 1JZ turbo tubing and coolant tubing
1JZ Coilpack Cover
Old 01-26-2014, 09:55 PM   #5
stunnaben
1JZ Front Sump Pickup and Splash Shield
1JZ Timing Belt Retainer Plate goes behind Camshaft Pullies
1JZ Timing Belt Cover goes over behind Crankshaft Dampener
Old 01-27-2014, 08:29 AM   #6
rune1241
rune1241 is an unknown quantity at this point
How much for the oem bov?
rune1241 is offline   Reply With Quote
Old 01-27-2014, 05:31 PM   #7
Contract_Killer
Contract_Killer is an unknown quantity at this point
pm me your price for the good bottom end and good parts too go on it... basically a good motor that just need assembeled and ecu
Contract_Killer is offline   Reply With Quote
Old 01-28-2014, 09:11 AM   #8
stunnaben
I messaged you both. Thanks for interest b
Old 01-28-2014, 09:16 AM   #9
PolarBear1JZ
PolarBear1JZ is an unknown quantity at this point
How much for a 1jz starter
PolarBear1JZ is offline   Reply With Quote
Old 01-28-2014, 09:16 AM   #10
stunnaben
No starter.
Old 01-28-2014, 09:31 AM   #11
EthanR
EthanR is an unknown quantity at this point
Send a message via AIM to EthanR
Do you have an idle air control valve? I have a JZX90 1J if that helps at all, not sure which are compatible.
EthanR is offline   Reply With Quote
Old 01-28-2014, 09:35 AM   #12
stunnaben
I have two IACVs.
Old 01-29-2014, 01:11 PM   #13
stunnaben
Bump to the top. I still have everything. A lot of interest in the good bottom end and head. I would love to get rid of everything in one lump sum if possible. Will make someone a great deal going this route. Interested in a complete S14/S15 sr swap or an LS swap. Other parts I'm interested in are JDM Kouki bumpers, OEM Kouki rear bumper add ons, Origin Stylish Kouki body kit, or potentially quality KA-t parts such as forged rotating assemblies, new ARP head/main studs, quality manifolds, turbos, etc.
Old 02-03-2014, 10:54 PM   #14
stunnaben
Let's get this stuff gone so I can party hardy.
Old 02-03-2014, 11:02 PM   #15
sr84
sr84 is an unknown quantity at this point
Pm me a price for the good motor and good parts
sr84 is offline   Reply With Quote
Old 02-03-2014, 11:31 PM   #16
stunnaben
Not a Problem. PM en route.
Old 02-05-2014, 06:09 PM   #17
stunnaben
Bump up ladies. I'm keeping the good block, the disassembled head, and an intake manifold.
Old 02-05-2014, 06:39 PM   #18
Night drifte89
Night drifte89's Avatar
Night drifte89 is an unknown quantity at this point
Good stuff. Bump glws
Night drifte89 is offline   Reply With Quote
Old 02-07-2014, 09:03 AM   #19
findmea240
findmea240 is an unknown quantity at this point
Will buy head asap. Please text me 5707680806
findmea240 is offline   Reply With Quote
Old 02-07-2014, 09:51 AM   #20
stunnaben
Text sent. Let me know.
Old 03-21-2014, 09:34 AM   #21
stunnaben
Assembled cylinder head sold.
Old 03-25-2014, 08:52 PM   #22
erik324
erik324 is an unknown quantity at this point
do still have an iacv?
erik324 is offline   Reply With Quote
Old 06-29-2014, 07:48 PM   #23
XxS13LifexX
XxS13LifexX's Avatar
XxS13LifexX is an unknown quantity at this point
Is the intake manifold your not using vvti or non? Does this one include a throttle body and iacv?
XxS13LifexX is offline   Reply With Quote
Old 07-02-2014, 07:10 PM   #24
B-Rock
B-Rock is an unknown quantity at this point
Any r154s for sale?
B-Rock is offline   Reply With Quote
