Old 02-07-2014, 10:16 PM   #1
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
S13 parts! Cheap exhaust, welded diff, 5-speed swap parts, door panels, MORE!!!
ALL parts are located in Simi Valley, CA. Prices are somewhat negotiable, but I'm not going to entertain lowballers. I will ship most items, unless otherwise noted. I would be willing to entertain package deal offers as well. I WILL NOT meet halfway, if you want the parts you've gotta come get them or pay for shipping. I am available evenings after 6PM, Sundays, and I have one rotating day off each week.
3" exhaust for S13
This is a full 3" DOWNPIPE BACK exhaust for an S13. It also DELETES the catalytic converter. It's crush bent muffler shop piping with a Megan muffler. Fitment is pretty good, not low hanging, and it sounds pretty good.
NO SHIPPING!!!
$70
S13/14 non-ABS welded diff
This is a welded differential and will fit either S13 or S14. If you want to use it on an S14 you would just need to swap the cover. The fluid has been drained and it's all sealed up, ready to bolt-in. I don't know who welded it, I just know it's welded, which is why it's so cheap.
NO SHIPPING!!!
$40
S13 manual black doorpanels
This is a pair of black doorpanels for any S13 with manual windows. The doorpanels are not perfect, but are in much better shape than a lot of them are. The upholstery is coming loose in a couple spots, but there are no rips, cracks, or burns.
NO SHIPPING!!!
$40
CLEAN S13 HVAC control unit
This is a SUPER clean HVAC control unit for any S13. All the buttons work correctly, lights work, barely any fading or light scratches. The clip that holds the cable in is also included and is taped to the bottom of the control unit.
$15
CLEAN S13 fastback stock tails
This is a SUPER CLEAN set of stock taillights for an S13 fastback. No chips, cracks, major scratches, or fading. All the light sockets and wiring are there and un-damaged.
SOLD!
S13 5-speed NON-ABS driveshaft
This is a stock S13 5-speed driveshaft for a NON-ABS car. It is in good useable condition, center support and u-joints are ok.
NO SHIPPING!!!
$50
S13 5-speed brake and clutch pedals
This is a pair of S13 5-speed brake and clutch pedals. Both pedals are un-damaged and in good useable condition. The pins and clips are also included. The clutch pedal is missing the rubber cover.
SOLD!
S13 5-speed flywheel w/exedy clutch and TOB
This is a recently machined stock S13 5-speed flywheel WITH a recently installed Exedy OE replacement clutch and the throwout bearing that came with it. This clutch, flywheel, and throwout bearing combo has less than 5k miles on it. NEVER drifter or abused, works PERFECTLY. NO BOLTS INCLUDED...
SOLD!
S13 clutchline w/hose, master, and slave
This is a COMPLETE S13 clutchline setup with the rubber hose, master cylinder, slave cylinder, and clutchline bracket. The vibration dampener is also still attached, but I would remove that pre-installation. All parts are in 100% good working condition and were recently removed from a running car.
NO SHIPPING!!!
$40
S13 5-speed crossmember
This is an S13 transmission crossmember for a 5-speed transmission. The crossmember is in good shape. No damage, just dirty.
SOLD!
S-13 5-speed upper shift boot
This is a S13 upper shift boot for a 5-speed transmission. It's not in very good shape, but it's better than a gaping hole in your center console. No major rips, just worn and fading.
$10
PBM hood risers
This is a set of silver PBM hood risers. This is a full set including ALL hardware.
SOLD!
China H4 headlights with bulbs
This is a BRAND NEW pair of Chinese H4 conversion lights with city lights and halo lights. ALL bulbs are included and EVERYTHING is BRAND NEW and in un-used condition.
SOLD!
S13 mudflaps
This is a set of OE mudflaps for any S13 chasis. They are not in the best shape, all the metal parts are rusted badly and one of the actual flap pieces is missing. Basically you would either have to use these as valances alone or make new flap sections out of plastic sheet, which isn't very difficult.
$40
Old 02-08-2014, 07:04 PM   #2
racepar1
racepar1's Avatar
First bump........
Old 02-08-2014, 07:52 PM   #3
Mack_didthat
Mack_didthat's Avatar
Mack_didthat is an unknown quantity at this point
pm'd…………...
Mack_didthat is offline   Reply With Quote
Old 02-09-2014, 11:22 AM   #4
jeremyuhh
Trader Rating: (51)
jeremyuhh is an unknown quantity at this point
Feedback Score: 51 reviews
Just PMed you.
jeremyuhh is offline   Reply With Quote
Old 02-09-2014, 08:22 PM   #5
racepar1
racepar1's Avatar
Last bump, added mudflaps!
Old 02-20-2014, 01:22 AM   #6
BubbaKIV
BubbaKIV is an unknown quantity at this point
Is exhaust an abnoxious or sounds pretty smooth ?
BubbaKIV is offline   Reply With Quote
Old 02-20-2014, 06:34 AM   #7
rangerjavi
rangerjavi's Avatar
rangerjavi is an unknown quantity at this point
Bump, for mud flaps.
Being a Floridian is a birth right!
rangerjavi is offline   Reply With Quote
