Old 09-16-2004, 11:39 PM   #1
bkfill
bkfill is an unknown quantity at this point
problems i've been having *pics*
http://mysite.verizon.net/bkfill/sr/
if the pics don't load plz wait a a little bit and click refresh verizon isn't great but it works
WARNING! ENGINE BAY MAY BE FULL OF TIE WRAPS N VERY MESSY
so bare with me
this is why i MAYBE had the major boost problem i coudn't hit 14lbs
s14 motor
when i put the wastegate to the hotpipe with out the blitz solinoid it boosted at 5 wtf
set the boost controller at 14PSI it only did 10 max 10.4 10.5 etc.
so heres some pics and i need a little help here thank you
if it aint broken, fix it(95 240/96 sr20)
bkfill is offline   Reply With Quote
Old 09-16-2004, 11:53 PM   #2
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
and i thought my engine bay was messy
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
Old 09-17-2004, 12:43 AM   #3
S14DB
AFC #1
S14DB's Avatar
#4 would be your MAP sensor
You have a vacume line nightmare.
Old 09-17-2004, 03:37 AM   #4
evilimport
evilimport's Avatar
evilimport is an unknown quantity at this point
WOW. So many hoses and wires...everywhere. And you dont need anything associated with your charcoal canister....and do you have working AC?
evilimport is offline   Reply With Quote
Old 09-17-2004, 03:47 AM   #5
bkfill
working ac see the line in the back and see next to the cold pipe it looks like a fuel pump lol
the harness is screwed up tho but its on high cool, i can't change
Old 09-17-2004, 08:27 AM   #6
bkfill
Heavy throttle said the map is not used cause of the maf
k! another problem solved
Old 09-17-2004, 09:39 AM   #7
s14srpilot
s14srpilot's Avatar
s14srpilot is an unknown quantity at this point
Send a message via AIM to s14srpilot
so bare with me
s14 motor
The stock bov has been known to leak so I would check if it is working correctly. You are right, your engine bay is a mess! Clean it up so that you could at least confirm that everything is hooked up correctly.
s14srpilot is offline   Reply With Quote
Old 09-17-2004, 09:59 AM   #8
autobahNESSA
autobahNESSA's Avatar
autobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfection
Send a message via AIM to autobahNESSA
Id recomend you spend a day and rip out all the vaum lines, and then re hook them up and rout them nicely. you only need vacum line to the fpr, wastegate, bov. Since you ripped out the carbon canister thier are no other vacum sources that i can think of off the top fo my head.
But seroiusly clean that engine bay and make the lines look nicer, easier to diagnos if you have leaks and just plain work on the car.
Is the A.c. suppose to have a vacum line to it, the a.c canister? I dont think i ever saw hat before, but then its been 2 yrs since I've had A.C.
autobahNESSA is offline   Reply With Quote
Old 09-17-2004, 11:04 AM   #9
projectRDM
projectRDM's Avatar
Good lord. Where's the rat?
FORMERLY R240NA
Old 09-17-2004, 05:36 PM   #10
bkfill
does it matter witch hose i use from the intake to the bov?
i used 1 i took from the charcol can, and holy crap man i finaly hit 13Psi
now i have a bigger problem i don't know whta happen but outta no where the car ran like sh*t, i gave it a little gas it started popping like crazy i need help any opinions? and the car barely moves when i give it a little gas teh exhuast gos pop popo popop popop smells very rich
at idle its steady. anything over 2k rpm will go pop pop pop pop(studder studder studder)
Old 09-17-2004, 07:30 PM   #11
evilimport
evilimport's Avatar
well, then, you are running richer than a moe-foe for some reason...did you mess with your FPR?
Old 09-17-2004, 08:31 PM   #12
bkfill
explain what a FPR is
i'll upload videoclips in a few
Old 09-17-2004, 08:42 PM   #13
ThatGuy
Admin Asshole
ThatGuy's Avatar
FPR My guess would be "Fuel Pressure Regulator".
Old 09-17-2004, 09:03 PM   #14
mrmephistopheles
mrmephistopheles's Avatar
that shit runs?
Old 09-17-2004, 09:04 PM   #15
mrmephistopheles
I don't think a rat could've done all that.
Old 09-17-2004, 10:27 PM   #16
bkfill
YESSSSS 14.5PSI!!
Problem fixed the maf got unhooked some how, car runs so sweet its not funny, tires won't stop spinning out either, the RPMS FLY! now, back then it was horrable man the stock BOV was under the fusebox and never saw that it was still hooked up, and it was maybe 1/4th open and the turbo flutter'd cause the bov(blitz) wasn't opening correctly, and the stock bpv was leaking boost + recuculating
THANK YOU FOR YOUR HELP
Old 09-18-2004, 03:55 AM   #17
S14DB
AFC #1
S14DB's Avatar
Then why the hell is it there?
Run your car on the Dyno with wideband. I would love to see your fuel curve under load.
Old 09-18-2004, 05:31 AM   #18
The Riot Hero
Banned from the Marketplace
The Riot Hero is on a distinguished road
Send a message via AIM to The Riot Hero Send a message via Yahoo to The Riot Hero
im confused...
whats this about a MAP sensor....
and youre running a blitz BOV and a stock bypass?
wtf is going on!
clean your engine bay man, do it!
The Riot Hero is offline   Reply With Quote
Old 09-18-2004, 02:35 PM   #19
bkfill
? i need it?, who else thinks i should hook it up, i need more opinions
Old 09-23-2004, 04:35 AM   #20
Skaterjunky8
Skaterjunky8 is on the path to ruinSkaterjunky8 is on the path to ruin
You need to shoot who ever did that swap for you.
Skaterjunky8 is offline   Reply With Quote
Old 09-23-2004, 09:34 AM   #21
projectRDM
projectRDM's Avatar
Welcome to being intelligent.
The MAP/BARO sensor is part of the OBD-II system on S14s, it's not used for anything else, and especially on an SR swap. Unplug it and throw it away.
FORMERLY R240NA
Old 09-23-2004, 10:35 AM   #22
Var
Var's Avatar
Send a message via AIM to Var
The Map/Baro sensor along with the ECT is what your computer uses to set the short term fuel trim on startup and will make a difference at different alititudes.
Hi
Old 09-24-2004, 10:34 PM   #23
90sr
90sr is an unknown quantity at this point
Talking
oh man i dont even know whats going on in there, far as vacuum lines i just ran one from the intake to the canister and the one from the wastegate to the bov, done car runs perfect. that car needs a bath, take care of her, shes a beautiful thing.
chris's sr
90sr is offline   Reply With Quote
Old 09-25-2004, 08:49 AM   #24
silviadriftr
silviadriftr's Avatar
silviadriftr is a well-known jackass
Send a message via AIM to silviadriftr
Are you still running the factory bov along with the blitz? if so unhook
the factory valve and see if it gets back into boost quicker after shifts.
silviadriftr is offline   Reply With Quote
Old 09-25-2004, 09:57 AM   #25
bkfill
used to have both of em and had no idea the pbv was open so i was leaking boost and recucuilating it, but fixed since i got the new intercooler,i coudn't put the blitz on cause i needed the flange so i used the stock pbv, i heard most cars run better with it recuiculated so back to bpv
Old 09-25-2004, 09:58 AM   #26
bkfill
lol the guy who did my ac said he wants to meet the guy who did my swap
i asked why? he said so he can kick his ass
