Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Electronics
Old 02-18-2014, 12:07 PM   #1
[email protected]
Luis@sflautosports.com is an unknown quantity at this point
Send a message via AIM to Luis@sflautosports.com
♛♛ AEM EMS/AEM Electronics PromoSALE || RB, SR, KA, 1JZ, 2JZ, 13BTT ♛♛
Whats going on fellas?
After the warm welcome the fellow community has given us and the awesome support. We have decided to run a AEM Electronics products promo $ale.
I'll beat anyone's advertised price!
Available for MOST cars, Just ask!
PM me or Email me for more details!
[email protected]
AEM’s Series 2 Programmable Engine Management System is more powerful than its predecessor. In addition to more robust hardware, there are several improvements over the original EMS, noted in the chart below. Like its predecessor, AEM's Series 2 Plug & Play EMS plugs directly into a vehicle's factory ECU harness and requires no additional wiring or hardware. Windows™ compatible software (XP, Vista, Windows7) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. Our new AEMTUNER software is infinitely adjustable software and allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately delivers proper amounts of fuel and correct ignition timing for any boost level or operating condition.
  • Plugs directly into the factory harness. No rewiring necessary.
  • Uses all the factory sensors.
  • Includes start up calibrations.
  • System is fully enabled and unlocked - Never pay for upgrades!
  • Context sensitive help eases tuning process.
  • Maps can be password protected by the tuner to prevent unauthorized usage or sharing.
  • Runs on Windows-compatible software
  • Up to 12 peak and hold injector drivers.
  • Up to 8 direct-fire coil outputs.
  • Up to 16 general-purpose outputs.
  • Up to 8 definable switch inputs.
  • Up to 4 EGT inputs with fuel trim.
  • 1MB of internal data logging.
  • Electronic boost control.
  • Full idle control.
  • Programmable traction control.
  • Software definable knock control.
  • Two step launch control.
  • User configurable soft-cut rev limiters.
  • Wet or dry nitrous control.
  • Tune using new USB communication port or serial port.
  • Works with all AEM gauges.
Digital Gauges
WIDEBAND FAILSAFE GAUGE
Wideband Air/Fuel and Boost in One Gauge!
It actively protects your engine by constantly monitoring AFR curves and activating a user-defined failsafe strategy. It can save an engine from catastrophic damage.
Displays both boost or vacuum and AFR or Lambda simultaneously on the same gauge
Internal boost sensor
Bosch Wideband UEGO sensor and weld-in bung included
On-Board 3+ hour Datalogging capability at 20hz per parameter
Full color Organic Light Emitting Diode (OLED) Display in center, user selectable feature (boost/vacuum or AFR)
Intuitive set up software
No free air calibration required- ever
DIGITAL WIDEBAND AIR / FUEL GAUGE
A wideband air / fuel controller and gauge interface in one unit!
Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
Does not oscillate AFR reading like narrow band sensors
No laptop required for monitoring!
Bosch sensor included
TRU-BOOST GAUGE TYPE CONTROLLER
Combines digital accuracy with manual controller-like ease of use!
No external interface required for programming!
Complete system includes harness, boost hose, on-board 29 psig pressure sensor (external 75 psia optional), boost solenoid, gauge display and all necessary fittings
Quick connect technology eases the installation process
WATER TEMPERATURE DISPLAY GAUGE
A complete gauge system that includes a sensor and requires no additional parts.
Gauge temperature range 100-300F
Includes easy-to-install harness and sensor
Complete stand alone gauge requires no additional sensors or programs to operate
Ideal for both fuel injected and carbureted motors
LED displays provide precise reference to critical operating
TRANSMISSION TEMPERATURE DISPLAY GAUGE
FUEL PRESSURE DISPLAY GAUGE
Gauge pressure range 0-100psi
BOOST DISPLAY GAUGE
Gauge pressure range -30-35psi and -30-50psi
OIL TEMPERATURE DISPLAY GAUGE
Luis@sflautosports.com is offline
Old 02-19-2014, 01:39 PM   #2
[email protected]
All PM's and Emails replied too.
