Old 09-23-2004, 12:36 AM   #1
SpdElemts
SpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of light
Opinions about ABS
What are your opinions about having ABS or not? I am very interested in this 93 s13 fastback, but it doesnt have abs and i dont know if i want a car with abs or not.
Thanks
SpdElemts is offline   Reply With Quote
Old 09-23-2004, 01:43 AM   #2
slideyourride
slideyourride is an unknown quantity at this point
u can look in the fuse box and look for the ABS fuse or u can search the net...
Slide Your Ride...
slideyourride is offline   Reply With Quote
Old 09-23-2004, 02:03 AM   #3
Naro182
Naro182 is an unknown quantity at this point
Send a message via AIM to Naro182
both my 240s do not have abs. I dont really notice the difference...
Just take some time to get used to it and know you cant slam on the brakes, because they will lock up. So take your car out and find the point where it locks up(depends alot on your tires) and be comfortable with that...
I wouldnt let it stop you from buying a good 240 though...
Naro182 is offline   Reply With Quote
Old 09-23-2004, 10:08 AM   #4
autobahNESSA
autobahNESSA's Avatar
autobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfection
Send a message via AIM to autobahNESSA
I hated my abs in my 91, ripped the unit out.
Sometimes it would not lock the brakes well, and felt like it extended my braking. Abs is suppose to lock the brakes and do the pumping for you. I found with mine it was not the case. Probably because I have one of the early generations of ABS. New cars I would want ABS in beacuse their that much better.
Another reason why I ripped it out is the abs unit began to leak.
autobahNESSA is offline   Reply With Quote
Old 09-23-2004, 10:20 AM   #5
aznpoopy
aznpoopy's Avatar
uh... abs PREVENTS you from locking your brakes. pumping = keep brakes from locking.
Old 09-23-2004, 02:19 PM   #6
evilimport
evilimport's Avatar
evilimport is an unknown quantity at this point
you cant drift with ABS either....
evilimport is offline   Reply With Quote
Old 09-23-2004, 02:47 PM   #7
MasterOFDrift
MasterOFDrift is an unknown quantity at this point
Send a message via AIM to MasterOFDrift Send a message via MSN to MasterOFDrift
^ what what and what?
check what you say before you post guys
MasterOFDrift is offline   Reply With Quote
Old 09-23-2004, 03:27 PM   #8
cttt300zx
cttt300zx is an unknown quantity at this point
if you are a good driver, and learn how to pump brakes you can actually stop faster than with abs. I hate abs. I take it out of all of my cars, whether it is new abs or not. It still lenghtens my braking distances. And you have much more controll without abs(again if you are a good driver)
email: [email protected]
AIM: CIPracing2
for all your 240 needs.
cttt300zx is offline   Reply With Quote
Old 09-23-2004, 03:30 PM   #9
aa87
aa87's Avatar
aa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant future
Send a message via AIM to aa87
Yeah, i almost got into an accident because ive locked up the shitty tires, just learn not to slam it and you should be good.
aa87 is offline   Reply With Quote
Old 09-23-2004, 03:38 PM   #10
AKADriver
AKADriver's Avatar
I don't care how good a driver you are, you can't pulse the brakes 20 times per second. Threshhold braking is effective, but ABS does allow the driver to brake just that last nth degree harder. Even professional drivers go faster around a road course with ABS once they get used to it.
The one situation where ABS won't improve braking is loose snow. In that situation you want the wheels to lock and "dig" into the snow.
Old 09-23-2004, 03:58 PM   #11
AlligatorBling
AlligatorBling's Avatar
AlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choices
Send a message via AIM to AlligatorBling Send a message via Yahoo to AlligatorBling
wtf
message length
AlligatorBling is offline   Reply With Quote
Old 09-23-2004, 04:35 PM   #12
Ritz S14
Ritz S14's Avatar
ABS kicks in when it feels like your car is going to skid while the brake is depressed.
So you're saying when you pump your brakes you will stop faster than a car with ABS? Hell no. Find a car that has ABS, then have them slam on their brakes to a complete stop and measure the distance they took to stop. Now you go and try that.
Engineers programed the ABS software to work a certain way, if your "way" was faster, i'm sure they would program that into the software.
I had another car with ABS, saved my ass from rear ending someone.. I know I sure as hell wouldn't been able to pump the brake 20times a sec to stop before touching the dude's bumper.
Ritz S14 is offline   Reply With Quote
Old 09-23-2004, 05:57 PM   #13
AlligatorBling
^ indeed. the first month i had my car i was going down my road a lil to fast and met a ups truck backing out.... fassssst stop. dead stop. im not dead.
Old 09-23-2004, 09:16 PM   #14
Marty
Marty's Avatar
Marty is an unknown quantity at this point
i like having abs in my car
Marty is offline   Reply With Quote
Old 09-23-2004, 10:45 PM   #15
XxJaPxOxNeEs23xX
XxJaPxOxNeEs23xX's Avatar
XxJaPxOxNeEs23xX is making a name for him/her selfXxJaPxOxNeEs23xX is making a name for him/her self
Send a message via AIM to XxJaPxOxNeEs23xX
what the heck i want abs on mine, does anybody want to sell me there abs system then if they dont want it.
XxJaPxOxNeEs23xX is offline   Reply With Quote
Old 09-23-2004, 11:31 PM   #16
kandyflip445
kandyflip445's Avatar
The earlier ABS might actually not be as good as a skilled driver. The new ones are definately better than any driver. It's just like with everything else, it takes time to perfect things and there is still always room for improvement.
My 240 vBgarage
Old 09-24-2004, 03:53 AM   #17
evilimport
evilimport's Avatar
never mind, apparently I was smoking crack when I posted that...
Old 09-24-2004, 02:46 PM   #18
autobahNESSA
"aznpoopy Quote:
uh... abs PREVENTS you from locking your brakes. pumping = keep brakes from locking "
ABS actually does lock the brakes for breif millisecond then it pulses the brakes to keep them on the virg of locking resulting in maximum braking. Problem with mine was that it did not do this well. the unit leaked, and did not function very well in emergency situations. I may have had an early gerneration, or it was messed up. ABS that I am used to is from late model cars which is far superior to what I had. I was uncomfortable with the way the brakes responded. And i saved probably 50lbs removing the heavy unit. S14 has good abs unit, if my brakes responded how the s14 did, I would have kept the abs.
You cannot stop faster then cars with abs unless they are very early versions, and you have r compound tires and it is a dry day. ABS is far superior to any human, it like stated before can pulsate the brakes 20times per second. ABS was banned from F1, cars were able to brake later, therefore going faster, much like traction control was banned. It may be allowed agian, I am not awware of it at this point.
Fact is ABS is more superior then any human, however something was wrong with my unit, and instead of spending lots of money to fix it, replace it, I got rid of it.
Old 09-25-2004, 02:31 AM   #19
SpdElemts
So should i look for another car with abs?
Old 09-25-2004, 10:48 AM   #20
aznpoopy
aznpoopy's Avatar
it really shouldn't be a make or break option. you know what ABS is, and you should know yourself well enough as a driver to make the decision.
Old 09-25-2004, 10:53 AM   #21
evilimport
evilimport's Avatar
Brake pads and tires stop the car but ABS helps none-the-less....kinda also depends on the climate in which you live too, if it rains a lot ABS might be a good idea to have, but if its a varrying climate you should be ok without....
decsion, ultimately, is up to your preferences alone...
Old 09-25-2004, 11:16 AM   #22
S14DB
AFC #1
S14DB's Avatar
I love ABS
Old 09-25-2004, 06:32 PM   #23
evilimport
evilimport's Avatar
^ Ha Ha... Me too!
