Old 03-24-2014, 06:12 PM   #1
jamg
jamg is an unknown quantity at this point
SR20 starts with no fuel, doesn't start with fuel
I have an enthalpy ECU.
Today, i installed another FPR from a nismo adjustable because i didn't have the tool to test the psi.
the car starts because of the flooded cylinders. (with the FP fuse pulled)
but when i put the fuse back, and try to start the car, it just turns over and over.
injectors have been tested and cleaned by dwerks. so they are good.
it's a stock FPR, but i dont feel the likely hood of it being bad is the problem.
any other solutions?
jamg is offline   Reply With Quote
Old 03-24-2014, 06:37 PM   #2
ultimateirving
ultimateirving's Avatar
Hey dude. I had a similArissue, unplugged fuel pump fuse and it actually started and idled but wouldn't drive. Put fuse back in and it died.
Turned out to be a massive vacuum leak.
So either check ur maf and wiring or boost leak test all your couplers
Z32 with lq4 swap
Old 03-24-2014, 06:50 PM   #3
jamg
the car started and ran last week.
i have not messed with any vac lines at all, since then.
Old 03-24-2014, 06:56 PM   #4
ultimateirving
Ok do you have the gauge now to see what the psi is while priming?
Z32 with lq4 swap
Old 03-24-2014, 06:56 PM   #5
jr_ss
Do you have a torn Oring on your injectors? That would cause both a fuel and a vac leak... Enough fuel to "flood" the engine.
Old 03-24-2014, 09:15 PM   #6
jamg
no, i took it off and put on the stock FPR for that reason.
Old 03-24-2014, 09:15 PM   #7
jamg
i have not touched the injectors since last week.
injectors were also sent to dwerks for test flowing and rebuilding.
Old 03-24-2014, 10:19 PM   #8
ultimateirving
Ok well you understand a vacuum leak doesn't mean vacuum lines, it means your car is sucking in unmetered air.
And even though it was running last week your symptoms sound like a major vacuum leak.
So once you finish the boost leak test, then you can say that wasn't the issue
Z32 with lq4 swap
Old 03-25-2014, 03:50 AM   #9
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Check to make sure you didn't swap the fuel lines
