Old 04-04-2014, 07:33 PM   #1
nissangooroo
nissangooroo's Avatar
nissangooroo is an unknown quantity at this point
S13 KA24DE, S14 KA24DE Parts PARTS PARTS.......
Located in Yakima,WA
Can Deliver(seattle area or lower valley)
Can Ship, and Can Send More Pics
Prices are Before Shipping and or Delivery
yes This is All Dual Cam Parts lol
Just Very OCD about things
Thanx for Reading
248/240 Stock S13 KA24DE Cams 45$
S13 6 Bolt Axle 30$
S13 KA24DE Water Pump 20$
S14 KA Water Pump 20$
NEW Nissan Transmission Shifter Rubber Boot 10$
S13 KA24DE Fuel Rail 20$
Rear Main Seal Set 10$
S13 KA24DE and S14 KA24DE Intake Mani's 20$ Each NO IACV's
S13 KA24DE Exhaust Manifold 20$
S13 180sx/ABS,Hicas Rotors 5$ Each
S13 Clutch Fan 10$
S13 180sx/Hicas,abs Front Sway Bar 25$
S13 KA24DE Igniter 20$
S13 Shift Boot Bracket Ring 10$
S14 KA24DE Bare Block 40$ Will need Hone thats it. 80k mile Block
S14 KA24DE Crank 35$
S13 KA24DE and S14 KA Knock Sensors 15$ Each
S13 and S14 KA24DE Oil Pumps 35$ Each (NO PICK UP TUBE)
S13 and S14 KA24DE Oil Filter Blocks 15$ Each
All Pulleys 10$ Except for Crank Pulley/Harmoic Balancer (15$)
S13 KA24DE Radiator 10$ its seen better days holds water tho
Muffler Silencer 10$
--------------Reading Quick Break lol------------------------------
Stock Rucas and Tension Rods and Toe Rods ALL for 25$
S13 Hood Brackets 15$
S14 KA and S13 KA Rear MAin Seal covers 15$ Each
S13 KA24DE Front Cover 15$
S14 KA24DE Intake Manifold Emisisons Hoses And EGR 25$
S13 and S14 KA Water Pump necks 5$ Each
S13 ABS Front Calipers They ARE BIGGER then stock
30$ Both total
S13 ABS Rear Caliper Piston and 2 Rear Caliper Brackets
Piston 20$ Brackets 20$
S13 ABS Power Steering Reservoir 20$
S13 HICAS Module(Message for info comes with lines all the way to the
rack)
S13 Motor Mount Brackets 25$
Just About ANY And All Motor Related Brackets Message for Info
Bottom Air Boxes Cold Start Crap and PCV Inlet Tube that goes on the intake 10$-20$
Pop Up Motors 5$ Each Have no CLue if They Still work
S13 Ka24DE and s14 KA Timing Chains and anything else timing chain related MEssage For More Info
I HAVE ALOT MORE STUFF Cant Post it all
----------- WHEELS-------------------
I Want TO TRADE MY 6 Wheels And 3 Tire Spares for Stock SE's Cash on TOP
i have 4 TSW 5 Spoke wheels and
TWO Sportmax Wheels
All are 16" and High Offset PLEASE ASK FOR MORE PICS ON THOSE
---------THANX YOU------------------
(O=O/ RPS13 \O=O)
nissangooroo is offline   Reply With Quote
Old 04-07-2014, 09:24 AM   #2
wsmiteh
wsmiteh's Avatar
wsmiteh is an unknown quantity at this point
do you have an egr tube for an s14 ka?
wsmiteh is offline   Reply With Quote
Old 04-07-2014, 04:15 PM   #3
nissangooroo
sold that with the exhaust manifold a while back all i have EGR related is the EGR. and watevers in the picture sorry
(O=O/ RPS13 \O=O)
Old 04-08-2014, 12:15 PM   #4
drk14
drk14 is an unknown quantity at this point
How much for just the 248 cam shipped to Athens Ga?
drk14 is offline   Reply With Quote
Old 04-08-2014, 03:47 PM   #5
nissangooroo
not parting cams sorry
(O=O/ RPS13 \O=O)
Old 04-08-2014, 09:10 PM   #6
jazy_fresh
jazy_fresh's Avatar
jazy_fresh is an unknown quantity at this point
interesred
How much to ship to 94565 for your s13 ka24de front cover?, will s14 front cover bolts fit on the s13 Cover? If not do you have them? Thanks
jazy_fresh is offline   Reply With Quote
Old 04-08-2014, 11:32 PM   #7
turbos14
turbos14's Avatar
turbos14 is an unknown quantity at this point
What is the crank pulley for s13 or 14.
Sent from my SGH-I747 using Tapatalk
turbos14 is offline   Reply With Quote
Old 04-09-2014, 02:43 AM   #8
inspire
inspire is an unknown quantity at this point
Can I grab that clutch fan and shroud if available
inspire is offline   Reply With Quote
Old 04-09-2014, 02:34 PM   #9
AustinTSI
AustinTSI is an unknown quantity at this point
Do you still have (and selling) the front HICAS rack? To 78754.
AustinTSI is offline   Reply With Quote
Old 04-09-2014, 03:14 PM   #10
nissangooroo
Hicas Rack is toast (car was in fire) But the front module thing that sends the fluid thru the lines to the back where the rack sits is mint........
Clutch Fan is available PM ME
Crank Pulley is off s14 KA
Front Cover Bolts should work for both motors And ITS pending Sale
(O=O/ RPS13 \O=O)
Old 04-09-2014, 03:49 PM   #11
turbos14
turbos14's Avatar
How much for crank pulley shipped 97007
Old 04-09-2014, 03:57 PM   #12
nissangooroo
Text me any questions....... i reply faster.. 509-961-5702
(O=O/ RPS13 \O=O)
Old 05-01-2014, 01:26 AM   #13
nissangooroo
Cams Sold
crank pulley Sold
Harmonic balancer sold
water pump pulley sold
one of the rear main seal covers Sold
(O=O/ RPS13 \O=O)
