Old 04-10-2014, 08:09 PM   #1
FourWeeks
FourWeeks is an unknown quantity at this point
Sputtering At Boost
Hi, just recently bought a S13 coupe with a blacktop SR20DET. Internals are all stock AFAIK, Walbro 255, stock turbo, recirc bov, ISIS 3" blast pipes with 3" test pipe.
The other day after having filled up my gas tank, I decided to drift around in a parking lot. After I was all done I decided to do a little pull and realized that as soon as I started to build boost around 3500rpm-4000 my motor felt like it was hitting fuel cut and attempting to build back up, kinda like what it feels like when you try to accelerate from a standstill in a high gear. The car won't sputter as bad if I ease into boost but if I go into it at WOT I feel like I'm bogging. Also, idle is a bit sporadic as in sometimes when I approach a stop, RPMs will dip down to 300rpm or lower but will go back up immediately.
I checked and my plugs and coil pack #3 have white residue on them which leads me to believe I'm experiencing lean conditions, so maybe a fuel delivery issue? I've since changed out the plugs and cleaned the coil pack and will be checking my fuel filter. In the meantime, does anyone have any insight? Car will not always start first key turn, but I blame it on the shrunken battery and cold weather. I can definitely hear the fuel pump priming though.
FourWeeks is offline   Reply With Quote
Old 04-10-2014, 09:11 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Since you said it happened while you're drifting, check the fender harnesses. Tire might have rubbed them out if they have not been relocated.
If thats good, my guess would be a boost leak.
CLICK HERE!!!
Old 04-10-2014, 10:49 PM   #3
EvoVIII808
EvoVIII808 is an unknown quantity at this point
Send a message via AIM to EvoVIII808 Send a message via Yahoo to EvoVIII808
sounds like you have a VAC leak of some sort, Fuel pressure or Spark Plugs..
Check Out My S13 Build
EvoVIII808 is offline   Reply With Quote
Old 04-11-2014, 05:10 AM   #4
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
check intake manifold gasket. My buddys bolts were loose and it was leaking from the middle.
Originally Posted by Hoffman5982 View Post
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
Old 04-11-2014, 05:54 AM   #5
aga
aga's Avatar
aga is an unknown quantity at this point
if it was a vacuum leak it would be rich, not lean. coilpack or sparkplug would be my guess. check the gap on your sparkplugs too.
My Build
aga is offline   Reply With Quote
Old 04-11-2014, 07:32 AM   #6
savages13
savages13 is an unknown quantity at this point
Also check the gap on the plugs. If the car hadnt been romped in much prior to you doing the drifty shenanigans you may have opened up the gap on the plugs causing a spark blowout in boost. Could also be an over boost situation. All the sudden heat could have nuked a vacuum line to the wastegate. Ideally if you have a boost gauge in the car monitor the levels. If boost levels are stock or close to it throw some plugs in it and gap them down to .028-.030. Go from there
savages13 is offline   Reply With Quote
Old 04-11-2014, 10:30 AM   #7
FourWeeks
Thanks guys. I bought BKR7E's and have them gapped down to .030 right now but a fellow SR owner suggested I get BKR6E's and gap them down to .025 to see if that will make a difference.
Old 04-11-2014, 11:20 AM   #8
Driftwire
Driftwire's Avatar
7E is a colder plug. 6E is going to be hotter.. I would recommend the 7E
Old 04-11-2014, 11:28 AM   #9
Thomas0zero
Thomas0zero's Avatar
Thomas0zero is an unknown quantity at this point
im pretty sure a boost leak will cause a lean condition.
Thomas0zero is offline   Reply With Quote
Old 04-11-2014, 11:52 AM   #10
aga
aga's Avatar
nope. cause you are losing air that the airflow meter has measured, so you are getting more fuel than you re supposed to.
My Build
Old 04-11-2014, 12:08 PM   #11
Thomas0zero
You know, you're right. Im thinking it was a vac leak i had, it was so long ago. But i had cap blow off the port on the TB under 17psi, caused a hellacious lean condition and the car ran like crap. Capped it and never had an issue again. completely stock Redtop SR20DET.
This guy needs to invest in a Wideband. Sure makes your life easy when diagnosing problems, and an extra layer of security.
Old 04-11-2014, 12:29 PM   #12
FourWeeks
Yeah, I'm thinking about getting a wideband. Where would be the best place to put one?
Old 04-11-2014, 12:35 PM   #13
Thomas0zero
Modern
They usually have the absolute best prices on genuine AEM stuff.
Old 04-11-2014, 12:40 PM   #14
FourWeeks
Modern
lol thanks but I can get them pretty cheap as well. I was asking about what the best location on my car would be to put the wideband on
Old 04-11-2014, 12:47 PM   #15
EvoVIII808
Be sure to check you FPR as well. I just replaced one on my friends KA-T. He was having the same exact problems you are.
Old 04-11-2014, 01:10 PM   #16
aga
aga's Avatar
in the downpipe, somewhere near the firewall so you can run the wires to the cabin. it has to be around 2 feet from the head. if you get the AEM, it has specific fitment instructions in the leaflet. (the instructions are also on their website in pdf's)
My Build
Old 04-11-2014, 02:42 PM   #17
Thomas0zero
oh my bad. i though you said buy. haha. On the downpipe, for sure. Directions state, 36" from the turbo but honestly, ive had them 1" from the turbo for years without problems. just put it in a location thats convenient for you and wont get knocked off by road debris.
Once you get you a wideband and assuming your setup is stock-ish, get a AEM Tru-Boost controller and crank that boost up! I was running 17-18psi on factory fuel support with 10.9 afrs, all the way to redline. 10.9 is actually still very safe, anything past 11.5 is to lean. The boost controller really brings the car to life. Did the same thing to my buddies SR. The T25 cant flow more than 10psi at 7.5k RPMs. So you can hit 17psi at 3k, the boost falls perfectly and you maintain perfect AFR's.
Old 04-11-2014, 09:39 PM   #18
FourWeeks
Turns out the piping that goes down into the SMIC had come off the coupler completely. Don't know how I missed that... But on the bright side I'm able to get sideways again thanks to all that helped!
Old 04-11-2014, 11:30 PM   #19
DJ 21o3
DJ 21o3 is an unknown quantity at this point
Sorry but that is not correct. Yes your MAF meters the air from the intake and that determines the fuel, but you got the rest backwards. When you have a vacuum leak, the engine is a vacuum pump and sucks air into the engine from the leak giving you more air than what the MAF read causing a lean condition.
No offense, just letting you know and so others don't read that and get confused. The solved problem proves that it was a giant ass vacuum leak. lol
DJ 21o3 is offline   Reply With Quote
Old 04-11-2014, 11:36 PM   #20
aga
aga's Avatar
you are wrong. i'll prove it to you :
1. the air coming OUT of the leak, is pressurised. so its coming out, with the force of 1 bar, rather than weakly sucked in by the engine
2. the sputtering was happening under boost, which means again, that the pressurized air was lost, otherwise it would happen on cruising etc. too.
come on, that's basic stuff. also, it's happened to me and i've got a wideband...on cruising the AFR was almost identical to normal, when boosting, the car would hit full rich.
My Build
Old 04-12-2014, 12:44 AM   #21
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
Bazingaa!!!
Key word is "under boost"
smoked240 is offline   Reply With Quote
Old 04-12-2014, 07:34 AM   #22
curo72
curo72 is an unknown quantity at this point
I'd check your fuel pressure. Longer crank time and a lean condition can both be attributed to a low fuel pressure condition.
curo72 is offline   Reply With Quote
Old 04-14-2014, 12:18 AM   #23
20thbryce
20thbryce is an unknown quantity at this point
So this happened to me and ended up being one of the plugs in the intake tube popped out.
20thbryce is offline   Reply With Quote
Old 04-17-2014, 08:31 AM   #24
kat7
kat7 is an unknown quantity at this point
I would check either your fuel pressure(might be your fuel pump) or a vacuum line.
kat7 is offline   Reply With Quote
