Old 05-17-2014, 10:38 PM   #1
Blue91hatch
Blue91hatch is an unknown quantity at this point
please help quick! tach install
So I bought a shell that had no instrument cluster in it and I decided to make my own, I've got the car done and running and driving but have no tach, I bought an iequus tach from O'Reillys, I also installed the autometer tach adapter that I read you have to run and when I installed it the car wouldn't start anymore, I ran it in series with the blue/red wire leading to the coil pack subharness, I undid the splice and it fired right up, so I tried wiring it to the yellow/red wire from the ecu and it still wouldn't work, then tried wiring it to the ground side of one of the coils (that's what the tach instructions said to do for a c.o.p. car) and it still didn't work, there's a drift event tomorrow morning I'm trying to go to but would really like a tach, does anyone have any ideas? Thanks in advance!!
Blue91hatch is offline   Reply With Quote
Old 05-20-2014, 02:53 PM   #2
Blue91hatch
really no one has any ideas?????
Old 05-21-2014, 03:39 PM   #3
OnTheChip
OnTheChip's Avatar
OnTheChip is an unknown quantity at this point
If you connected it in series with a coil trigger wire, you probably fried the tach. It should be connected in parallel.
Did you follow the "cylinder setting instructions"?
OnTheChip is offline   Reply With Quote
Old 05-21-2014, 03:56 PM   #4
Blue91hatch
sorry i meant parallel it was late when i typed that haha, and yea i followed the cylinder setting instructions, when i wired in the tach adapter the car would no longer start even though it still had 12v going to the coil harness through the adapter
